My washing matching is not working it show E41. I have a Electrolux top loader EWF 1074
Family error code E40 is visible to customers and (could be E41,E42,E43,E44 and E45 only visible in service mode) means problem with open door or door interlock.
I suggest rapid reading alarm code when appliance is in normal operating mode (e.g. during the execution of the washing
programme):
Press and hold down START/PAUSE and the nearest option button simultaneously for at least two seconds: the LEDs initially switch off, and then display the flashing sequence corresponding to the alarm.
The alarm sequence continues as long as the two buttons are held down.
E41 - Door open
E42 - Problems of door closure
E43 - Interlock power supply triac faulty
E44 - Door interlock sensor faulty
E45 - Door interlock sensing circuit triac faulty
Possible causes:
Door interlock faulty, wiring faulty or PCB faulty.
Dado
Posted on Sep 24, 2015
SOURCE: Hi i have a electrolux ewf 1074 front loader. it
Press and hold the 'Delay' and 'Extra Rinse' buttons together and it will 'unlock' your control panel (this is a tamper proof feature for the kiddies)
Posted on Jun 11, 2009
SOURCE: Electrolux EWF 1074 get a lock icon
you need to hold the option and extra rinse buttons simultaneously for 6 seconds...you will see the padlock symbol go and then use your machine as usual
Posted on Aug 19, 2009
SOURCE: electrolux ewf 1090, have an electrolux ewf1090
ewf1090 washing machine not working?
error E50 is displayed?
but no reference in manual that helps.
Posted on Jan 26, 2011
SOURCE: Hi, I have an Electrolux EWF 1074 front loader.
Go back and check your connections. If you had the machine working previously and none of these issues were there before you cleaned out the drain area of the unit then your first step would be to check the connection to the pump as well as your connections going from the control to the door area as well. If after you have checked all your connections to the pump the door lock assembly, the control and the touch pad the unit is still doing the same thing then message me back. Before you do any of the checking of connections in the unit first hold down delay and extra rinse buttons together for 3-5 seconds. This usually will unlock the control if the control is locked on the unit. Also if the delay and extra rinse and the checking of your connections does not solve your issue then also message me back with the number of times the pause button is flashing and how often it flashes as well. If you have any further questions message me those back as well. I await your reply Thanks again Rick
Posted on Jul 18, 2011
SOURCE: Electrolux EWF 1074 - the white plug won't come
Just had the exact same problem. Thought maybe it wasn't supposed to budge, but I got the pliers in there, and out it came!
Posted on Oct 04, 2011
