Motherboard ID Dell Dimension 8200, pentium4, 2.5 GHz, 512K, 533 FSB Orig. purchase says - PLANAR(MOTHERBOARD)..850E, TRANSFORMER SKY DIVE MINITOWER.., DIMENSION.. Dell techs say - "Intel" 850E Intel Lists - 5E's D850MV D850MD D850GB D850EMV2 D850EMD2 I have phoenix BIOS so no identifier programs work. Please note that I bought this system in 2002 and it is still quite fast and reliabal. The board is capable of running @3 Ghz. I need to update AGP motherboard chipset drivers, IDE ATA/ATAPI controllers,etc.. Is "Planar" a company or is it a model number/name for an Intel MB?Does the "D" in the above list stand for "dimension", "dell", or "pentium D"?And what does MV, MD, GB, EMV2, & EMD2 stand for? Any input on the above items would be deeply appreciated. Thanks
Posted by rafx on
Thomas Christopher
    Genius:
  • 1,601 Answers
Try running Belarc advisor to check the motherboard manufacturer.
Lots of companies use Intel chipsets
Posted on Nov 16, 2007
What is the maximum ram capacity of dimension 8200 motherboard
2 gygabytoes are usually the max, you could upgrade the OS to maybe Windows XP 64 bit, but this isn't worth it in such an olde machine! Throw it out and get yourself an ASUS laptop with Windows 7 64-bit, a solid state HD and 4 or more gigabytes of ram instead!.
http://www.crucial.com/upgrade/Dell-memory/Dimension+%2F+Dimension+XPS/Dimension+8200+Series+%28400MHz+FSB%29-upgrades.html
Mar 16, 2013 | Dell Dimension 8200 AUD System Board...
What type of dual core processor can I use for my dc7600?
The motherboard for the dc7600 has an Intel LGA775 processor socket. However, not all LGA775 processors are compatible with the motherboard. For the small form factor, the following CPUs are supported: Intel Celeron D Processors:
Intel Celeron D 331 Processor (2.66-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 336 Processor (2.80-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 346 Processor (3.06-GHz, 256K L2 cache, 533-MHz FSB)
Intel Pentium 4 Processors with HT Technology:
Intel Pentium 4 521 Processor (2.8-GHz, 1-MB L2 cache, 800-MHz FSB) , Intel Pentium 4 524 Processor (3.06-GHz, 1-MB L2 cache, 533-MHz FSB) , Intel Pentium 4 541 Processor (3.2-GHz, 1-MB L2 cache, 800-MHz FSB), Intel Pentium 4 620 Processor (2.8-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 630 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 631 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 640 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 641 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 650 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 651 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 661 Processor (3.6-GHz, 2-MB L2 cache, 800-MHz FSB) or
Intel Pentium D Dual Core Processors:
Intel Pentium D 805 Dual Core Processor (2.66-GHz, 2x1MB L2 cache, 533-MHz FSB), Intel Pentium D 820 Dual Core Processor (2.8-GHz, 2x1MB L2 cache, 800-MHz FSB), Intel Pentium D 915 Dual Core Processor (2.8-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 925 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 930 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 940 Dual Core Processor (3.2-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 945 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 950 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800 MHz FSB)
Unfortunately, these are old processors and I don't see any available new. Newegg.com lists a couple available as refurbished. You may be better off getting a new computer with either a Intel I3 or current AMD processor.
I wish that I had better news for you.
(do not attempt to use a CPU that your motherboard doesn't support. It probably won't boot.)
Mar 30, 2012 | HP Compaq dc7600 Small Form Factor PC...
Trying to find the Jumper that controls FSB on a dell dimension 8200. Either that or some form of overclocking software that will allow me to get the full 2.8 out of my P4
modern Boards Auto-Detect FSB speeds, usually determined By CPU fsb And Memory/Ram speeds. It may be Wise to see if theres A user manual/guide for this board. or a possible bios update to support the CPU. also check the boards fsb speed ratings charts. overclocking is not recommended, as this can damage cpu/ram and motherboard.
Mike @ Compurepair.
Oct 29, 2009 | Dell Dimension 8200 PC Desktop
ASUS P4S333-M What is the maximum CPU this bouard will run
P4S533-MX
The following table shows the support for CPU / Motherboard
CPU
Since PCB
Since BIOS
Note
Celeron 1.7 GHz (400 FSB, L2 cache:128KB) ALL
ALL
Celeron 1.8 GHz (400 FSB, L2 cache:128KB) ALL
ALL
Celeron 2.0 GHz (400 FSB, L2 cache:128KB) ALL
ALL
Celeron 2.1 GHz (400 FSB, L2 cache:128KB) ALL
ALL
Celeron 2.2 GHz (400 FSB, L2 cache:128KB) ALL
ALL
Celeron 2.3 GHz (400 FSB, L2 cache:128KB) ALL
1005
Celeron 2.4 GHz (400 FSB, L2 cache:128KB) ALL
1005
Celeron 2.5 GHz (400 FSB, L2 cache:128KB) ALL
1006
Celeron 2.6 GHz (400 FSB, L2 cache:128KB) ALL
1006
Celeron 2.7 GHz (400 FSB, L2 cache:128KB) ALL
1006
Celeron 2.8 GHz (400 FSB, L2 cache:128KB) ALL
1006
P4-1.4 GHz (Socket478, 400 FSB, L2 cache:256KB) ALL
ALL
P4-1.5 GHz (Socket478, 400 FSB, L2 cache:256KB) ALL
ALL
P4-1.6 GHz (Socket478, 400 FSB, L2 cache:256KB) ALL
ALL
P4-1.6A GHz (Socket478, 400 FSB, L2 cache:512KB) ALL
ALL
P4-1.7 GHz (Socket478, 400 FSB, L2 cache:256KB) ALL
ALL
P4-1.8 GHz (Socket478, 400 FSB, L2 cache:256KB) ALL
ALL
P4-1.8A GHz (Socket478, 400 FSB, L2 cache:512KB) ALL
ALL
P4-1.9 GHz (Socket478, 400 FSB, L2 cache:256KB) ALL
ALL
P4-2 GHz (Socket478, 400 FSB, L2 cache:256KB) ALL
ALL
P4-2.20 GHz (400 FSB, L2 cache:512KB) ALL
ALL
P4-2.26 GHz (533 FSB, L2 cache:512KB) ALL
ALL
P4-2.40 GHz (400 FSB, L2 cache:512KB) ALL
ALL
P4-2.40B GHz (533 FSB, L2 cache:512KB) ALL
ALL
P4-2.50 GHz (400 FSB, L2 cache:512KB) ALL
ALL
P4-2.53 GHz (533 FSB, L2 cache:512KB) ALL
ALL
P4-2.60 GHz (400 FSB, L2 cache:512KB) ALL
ALL
P4-2.66 GHz (533 FSB, L2 cache:512KB) ALL
ALL
P4-2.80 GHz (533 FSB, L2 cache:512KB) ALL
ALL
P4-2A GHz (Socket478, 400 FSB, L2 cache:512KB) ALL
ALL
P4-3.06 GHz (533 FSB, L2 cache:512KB, HT, C1/D1) ALL
ALL
Since PCB 2.0 or later support HT Function
Jun 22, 2008 | Computers & Internet
Motherboard blew up
I would recommend buying a replacement computer, and install the Dell IDE drive in an external 3.5" IDE hard drive enclosure. This way you can pull your information off the the Dell hard drive, and then blow it away.
Keep in mind that new computers use a SATA drive, your old Dell '8200 has an IDE drive. Also keep in mind that your Dimension 8200 drivers won't work on the new computer.
You might be able to install your Dell drive as a slave if you have an open IDE channel available.
Good news is, your old Dell uses RAMBUS memory, which is worth a lot. It's a good parts computer, and most people who look for computer parts know of the bad capacitor issue on Intel made Dell motherboards from that era.
May 15, 2008 | Dell Dimension 8200 PC Desktop
Replacement Video Card - Dell 8200 w/ NV25
I have a couple of graphics cards that will do the trick. Email me back and I will help you out.
May 14, 2008 | Computers & Internet
New processor needed
Hi, For Dimension 3000 system here are your options. Pentium IV 3.2 GHz 533 / 800 MHz FSB Pentium IV 3.0 GHZ 533 / 800 MHz FSB Pentium IV 2.8 GHz 533 / 800 MHz FSB but what i'm worried about is the socket where the process goes into. for thermal issues it is expected for the socket to CHIP CREEP. Chip creep refers to the problem of chips that, over time, would work their way out of the socket. Chip creep occurred due to thermal expansion; the contracting and expanding during system heat up and cool down. you might end up replacing the mobo as well.
Oct 04, 2007 | Dell Dimension 3000 PC Desktop
Computers & Internet Logo
634 people viewed this question
Ekse
Marvin
Marvin
