Question about Breville Kitchen Appliances - Others
I have a Breville Express Cooker exc15 and I have never used it as I need an instruction manual. Where can I get one from, please?
Just needed instructions on using my appliance also recipe book if available, thank you, Sandy.
Posted by Sandra Dickson on
David Payne
    Top Expert:
  • Breville Master
  • 14,162 Answers
5 Related Answers
Anonymous
SOURCE: Breville express cooker instructions
I would like a manual for a breville expresss cooker please
Posted on Aug 10, 2008
Anonymous
SOURCE: Breville Express Cooker EXC15 Manual
I phoned Breville this morning and the lady emailed me a copy straight away!
Posted on Jan 18, 2009
Mark Egan
  • 1214 Answers
SOURCE: instruction manual needed for breville rice cooker- rc18
It looks like manuals are avaiable for free at
http://www.breville.com.au/products_results.asp?div=1&cat=6&subcat=38
You will need to enter your contact info.
Reply back if you have any further questions.
Posted on Feb 05, 2009
Kavitha R
  • 217 Answers
SOURCE: Instructions needed for MicroMaster pressure cooker - missing
http://www.seenontvproducts.net/micromaster/index.html
Posted on Jul 15, 2009
jennable
jennable
  • 24 Answers
SOURCE: I need instructions to use salton yogourt maker gm5
Basic Yogurt Recipe
4 cups (1 quart) milk - whole, 2 %, 1% or skim
1/4 - 1/2 cup instant non-fat dry milk powder
1/2 cup plain yogurt (with live cultures) or yogurt from a previous batch
  1. In a saucepan, combine milk and dry milk and heat over medium heat, stirring frequently to just below the boiling point. Remove the milk from heat and allow to cool until lukewarm (about 100 degrees). To cool the milk quickly, place the saucepan into the refrigerator or a sink of cold water, stirring occasionally to cool evenly. This takes about 20 minutes.
  2. Pre-warm the yogurt maker's heating base by plugging the cord into an electrical outlet. The signal light will glow when base is plugged in.
  3. Add plain yogurt to the warm milk, stirring gently to blend. Do not beat or whip. Pour the mixture into the yogurt container, secure the lid and place the covered container into the heating base. Cover the Yogurt Maker and process undisturbed and out of drafts for 4-10 hours, depending on tartness desired. Yogurt should be partially set after processing and will thicken further after refrigeration.
  4. After processing, unplug the cord from the outlet. Remove the cover and lift the covered yogurt container out of the heating base. Place the container in the refrigerator and chill at least two hours to thicken. If desired, remove 1/2 cup of the yogurt to use as a starter for future batches, before adding any fruit or flavoring. Keep yogurt refrigerated until use.
Posted on Aug 24, 2009
Where do i get a manual for breville express pressure cooker exc15
Search internet for:
Make + Model + the word "Manual"
or contact manufacturer support.
May 01, 2016 | Breville Kitchen Appliances - Others
Breville express exc15
I would search on ebay for someone who has got one.
Jul 14, 2014 | Sunbeam SUN-4710 5-Cup Rice Cooker
I need a manual for our revile express cooker exc15.
Hi there.
Try http://www.breville.com for Owner's Manual download.
Regards.
Jul 09, 2011 | Breville Kitchen Appliances - Others
Where can I get a copy of a Breville Express Cooker (EXC15) manual? I had a cooker given to me but alas no "how to use" instructions.
Hi I have the same model - I absolutely love it. The only problem is that the seal is broken and because Breville no longer supply parts I'm using it more as a slow cooker!
It's pretty simple to use:
The basics:
1. Pull the handles apart (note you must have the 'pressure lock - the only sliding knob on the lid) in the 'unlocked position'.
2. Set the temperature on Max (only until the meat, onions etc are brown, then turn down to 1 or 2- just enough to keep the orange button 'popped' on the top of the machine
3. turn the timer (bottom dial on the front of the cooker) to an hour (you can always turn the dial more if needed, but not reduce time) by the time you've browned meat & chopped veges, etc that will be about 10-15 gone. I've never had it pressure 'cooking for more than an hour for anything'
3. re timing - casserole takes about 40 min from when the orange button on top 'pops' up (ie. steam build up enough pressure to cook quickly)
4. don't over fill - there's a little cast iron bump about an inch from the 'top' inside the cooker - that's about the max.
5. if you're cooking meat dishes have the dial on the top 'pressure release dial' on 3 - lighter dishes (e.g. soups) have on 1 or two.
6. until you get use to it keep an eye on the orange button - you get to know what temp to put it on by how much steam is released - it it's hissing away, turn the temperature down.
7. makes great casseroles, rissotto, soups (even with dried beans, only about 40 min)
if you ever find a supplier for seals, post an answer!
May 19, 2010 | Microwave Ovens
Instruction manual needed for breville rice cooker- rc18
Feb 05, 2009 | Breville Gourmet Rice Cooker -...
Manual for Breville Express Cooker EXC15
you will get the manual here. Just send them a request.
Nov 23, 2008 | Kitchen Appliances - Others
Jul 03, 2008 | Kitchen Appliances - Others
Ring Breville, they emailed me one this morning!!
Nov 19, 2007 | Sunbeam SUN-4710 5-Cup Rice Cooker
Kitchen Appliances - Others Logo
543 people viewed this question
Top Breville Kitchen Appliances - Others Experts
Marvin
Marvin
Anthony Ward
Anthony Ward
Irene Tulloch
Are you a Breville Kitchen Appliances - Other Expert? Answer questions, earn points and help others
