SOURCE: NO ALT,WEATHER DISPLAY
Dreco,
I was changing my battery and ran into a small problem, too. I know where one spring goes, but I have another similar spring that may have fallen out of the watch (I was working on another different watch before, so I'm not sure if the 2nd spring belongs in the watch). One spring contacts the small speaker on the metal cover and will not affect the LCD display.
How many springs do you see in yours, if any?
SOURCE: nike watch
In TIME mode - not ALARM - top right hand button marked "START/LAP" toggles hourly beep on/off. As not in ALARM menu, easy to put on unintentionally.
SOURCE: Need help replacing battery in my nike Imara
1. Use a coin turn the battery hatch one-quarter turn counter-clockwise
2. Remove old battery from compartment. Keep plastic cradle and replate with 395/SW927R battery. Replace the new battery positive side facing up in the plastic cradle into the metal compartment in the watch. Ensure all three little tabs line up and twist cradle to lock into place. Make sure the O-ring is in proper placement on the cover and replace the battery hatch ensuring it is sealed completely!
Testimonial: "THanks"
SOURCE: nike triax watch strap needed wg48 4000 grey strap
I'm having the same problem with the same model. Were you able to find a replacement strap? Thank you.
SOURCE: I need a replacement strap
Log in to Nike website and click support button. You should be able to ask them how to obtain the part you are after.
Testimonial: "Thanks"
