Televison & Video Logo
s
sandi Posted on Sep 13, 2015
Is the tv shot or just a bulb? it went out suddenly
Tv is appx 2004. was sound and no pic. now no sound or pic. attached to cable box. channel 3/standard and /full show on screen. nothing else.
1helpful
2answers
No sound on channel 3
Maybe the cable signal is defective not your tv.the other channel is ok.if you tv has a defect all channel has affected.
2answers
Can't receive pic and sound with the converter box.
The tv should be on channel 3. Otherwise, you can go to menu on tv, then find "autoprogram" and it will search all available channels. Usually tv should be on channel 3 if hooked up with a coaxil cable and aux or AV or Input if you are using rca jacks.
Sony KV-36FV27 too dark, pink or green tint, 5 blink error,
Fuzzy,blury picture in CRT tv tube.Tv in long use not repairable.Tv tube is dying,it junk.
Suddenly no sound & no picture overnight: is my TV dead?
If you have static siugnal, sure TV is not dead.
Check the aerial cable, ensure it is well plugged in and getting signal.
If you are using a receiver box, check cables to TV and receiver (freeview, sat, cable etc.), try setting channels on receiver again, if it does not work but you get static, then either the cables or receiver are defective.
Test the TV on standalone , connecting it to an external antenna.
Tune again the channels, and save the preset.
If still no signal then the antenna socket on the TV may be defective.
Try using the TV with a DVD.
If you can watch DVDs, and TV is not keeping channels preset, and you tried all the above, at this point htere may be a fault in the tuner card inside tv.
Call the phone number listed on tv user manual to get support, and eventually repair it.
LCD TV no pictures but sounds
cheak cables try other cables old style yellow to see the pic then go in box tell it hdmi output or coumpunt whatever uuse try differnt ports
2helpful
2answers
Haier Plasma Tv Screen went black
This model has several defective boards and eprom chip. There is an upgrade kit. I'll attach the kit part number and upgrade instructions. http://service.haieramerica.com/documents/SB-TV-0003.pdf
2answers
No audio
try to reprogram the channel. it seems that your tv's sound circuit is fine.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
