Cars & Trucks Logo
c
chris Posted on Sep 12, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Overheating no roostertail nothing clogged in the inpeller
Claude Kayser
Level 3:
Top Expert:
  • Cars & Trucks Master 9,098 Answers
  • Posted on Sep 12, 2015
Claude Kayser
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5067349
Points
28436
98 Yamaha xl760 overheating Page: 1 - iboats Boating Forums ' 438973
forums.iboats.com/forum/.../438973-98-yamaha-xl760-overheating
Aug 10, 2010 - 9 posts - ‎4 authors I have a 98 Yamaha xl760 that overheats at full throttle, but is fine I ... Also noticed that there is almost no water shooting up in the roostertail. Roostertail in Wake-- Crownline 242 Page:
Dodge Durango new water pump but still heating up
Check for a clogged radiator. Also check for proper fan operation. Do not mess with the cap. That has nothing to do with overheating.
1helpful
2answers
On a 93 jeep Cherokee 4.0 if the catalyst converter is clog can it cause overheating?
First the dash gauge is not that accurate. Yes if you have excessive back pressure from the catalytic converter then the temperature can rise on the engine.
2helpful
Changed thermostat in auto 2 weeks ago car stopped overheating . Last night car was overheating again. Could the thermostat be defective?
wild guess , clogged rad tubes.
wild guess 2, pump impeller , rusted to near nothing
lots more,,, why guess, get the car serviced.
What does the ported vacumm switch do and could it be related to overheating
Overheating is caused by the following:
1. Defective thermostat
2. Clogged radiator with deposits due to age
3. Antifreeze that has not been changed for several years
The ported vacuum switch has nothing to do with the cooling system of your car. It just controls when vacuum gets to a particular part or not.
Upper hose hot lower hose cold has good heat in car not overheating runs fine just lower hose not hot even after tstat opens
The lower hose shouldn't be as hot as the top. If your not having overheat problems I wouldn't worry about it. If the radiator was clogged, it would overheat.
Ignis 1.5 sport 04
post all signs of overheating.
  1. dash guage
  2. STEAM eruptions>?
  3. AF (antifreeze ) leaks?
  4. CHeck engine light sticks on running?
  5. Scan tool shows way hotter than 200F? "ECT PID" parameter.
  6. oil in the AF? cold you see oil floating in the neck of the rad cap off?
  7. AF found on the A/T tranny dip stick end?
  8. Loosing coolant (drops) all the time, Check rad directly cold.?
  9. engine pings, (knock/detonation) ?
  10. lost power. from engine.
  11. shaking of engine. as it misfires.
  12. car heater makes this odd gurgling sound?
those are the signs but. what about precondtions.
overheats only parked< and never moving fast>
yes, bad RAD fan, (or its controls)
over heats all the time>?
fan belt fell off or slips?
clogged, rad tubes. (inside)?
water pump bad, blades, rusted to nothing.?
thermostat died, as most do way before 10 years,,,,,,,
clogged system from not doing the 2year service.
Filled radiator with antifreeze and it overheated,also cold air seems to be comming out of the heater vents
2 things,radiator partially clogged,and/or bad heater core.Fan clutch could also be bad.
OVERHEATING ( SOMETIMES)1996 460 RUNS HOT ON TRIP 200 + MILES LOST NO FLUID --NEXT DAY EVERYTHING OK--DROVE 3000MILES OVER 3 WEEKS NOTHING HAPPENED. PARKED FOR APROX 1 AND HALF MONTHS-RUNS HOT--CHANGED...
Possible fan clutch..Usually if its a fan clutch it will run hot sitting still but cool off once going down the road..If it takes a while to run hott then i would suspect a clogged radiator..When you drain it did it look like all the antifreeze came out..Ive seen half the radiater clogged up where half of it drained but the clogged section stay in the radiator
2answers
Runs hot with ac on
Make sure radiator fan is working....if not check fan fuse, if fuse is good check fan relay, if relay is good fan motor may be bad, replace
Also, may need to change thermostat.
Check coolant levels
1helpful
VW Cooling System
Hi Lori . Sorry but it sounds like your water pump inpeller (The internal part that circulates the water) has broken off or come lose . But i would recomend changing the cambelt and tensioner as well . Regards VW Audi tech
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
