Question about Mercedes C-Class Exterior Pillar Posts Trim Set
My 2003 c320 drivers seat blows fuse when headrest,recline or memory buttons pushed. Does not blow when forward/rear slide adjust used. Any ideas??
Blows 30a fuse in left side fuse block.
paul fairbanks
    Genius:
  • Mercedes-Benz Master
  • 1,147 Answers
Sounds like you have trapped/chaffed wiring under seat or around seat recline hinge, remove seat and have a close look at the wiring. disconnect battery first because airbags in seat and seat belt pretensioners i think are fitted to this car. good look
Posted on Sep 17, 2015
On 2004 pontiac montana what does fuse 7 control
7-BATT MAIN 1
60A
Fuses: •
CIGAR/DLC/APO FRT
• CLUSTER BATT
• CTSY LAMP
• ON STAR
• PWR LOCK
• PWR MIRROR
• RAP RELAY
• RR PWR SCKT
look below for above listed componet's , pull those fuse's one at a time till arc stop's ,then you found your problem circuit . Do you know where the I/P fuse box is ?
Fuse Block- I/P
Right side of the I/P, in the right front door opening
Fuse Block-I/P Label
Fuse Block-I/P Application Table Fuse/Circuit Breaker
Rating
Description
BCM PRGRM
10A
Body Control Module (BCM)
ENHANCED EVAP/AWD
15A
Evaporative Emission (EVAP) Canister Vent Solenoid, Clutch Pump Check Valve
CIGAR/DLC/APO FRT
20A
Auxiliary Power Outlet-Front, Cigar Lighter, Data Link Connector (DLC)
CLUSTER/BATT
10A
Instrument Panel Cluster (IPC)
CRUISE
10A
Cruise Control Module (CCM), Cruise Control Release Switch, Cruise Control ON/OFF Switch
CTSY LAMP
10A
DRL
10A
Daytime Running Lamps (DRL) Control Module
HVAC/DIC/DRL/HEATED SEAT
10A
Air Temperature Actuator-Left, Air Temperature Actuator-Right, Daytime Running Lamps (DRL) Control Module, Driver Information Center (DIC), Mode Actuator, Rear Window Wiper/Washer and Multifunction Switch (Heated Seat Switch), Recirculation Actuator, Relay Block (Rear Window Defogger Relay)
ELC/TRAILER
25A
Auto Level Control (ALC) Air Compressor, Auto Level Control (ALC) Air Inflator Relay, Auto Level Control (ALC) Sensor
FRT HVAC HI BLWR
30A
Blower Motor Resistor Assembly
FRT WPR/WSHR
25A
Windshield Wiper Motor, Windshield Wiper/Washer Switch
HAZARD
15A
Turn Signal/Multifunction Switch
HEADLAMP
20A
Daytime Running Lamps (DRL) Control Module, Headlamp Dimmer Switch, Headlamp Switch
HTD MIRROR
10A
Outside Rearview Mirrors-Left, Right
HVAC/BLOWER
25A
HVAC Control Module
IGN1
10A
Body Control Module (BCM), Instrument Panel Cluster (IPC), Left Rear Side Door Actuator Control Module, Rear Object Sensor Control Module, Right Rear Side Door Actuator Control Module, Stop Lamp Switch
LH HEADLP HIGH
10A
Headlamp High Beam-Left
LH HEADLP LOW
10A
Headlamp Low Beam-Left
LH T/LP
10A
Tail Lamp-Left, Trailer Rear Wiring Harness
MALL/CLUSTER
10A
ON STAR
5A
Vehicle Interface Unit (VIU)
PASS KEY
10A
Theft Deterrent Control Module
PCM/ABS
10A
Electronic Brake Control Module (EBCM), Fuse Block-Underhood, Powertrain Control Module (PCM), Park/Neutral Position (PNP) Switch
PCM/CRANK
10A
PCM/PASS KEY/CLUSTER
10A
Instrument Panel Cluster (IPC), Powertrain Control Module (PCM), Theft Deterrent Control Module, Instrument Panel Cluster (IPC), Powertrain Control Module (PCM)
PWR LOCK
20A
PWR MIRROR
10A
Outside Rearview Mirror Switch
PWR QTR VENT
10A
Auto Level Control (ALC) Air Compressor, Auto Level Control (ALC) Sensor, Rear Quarter Window Switch
PWR/HEATED SEAT PSD
30A
Driver Seat Assembly, Passenger Seat Assembly
PWR SLDG DR
30A
Left Rear Side Door Actuator Control Module, Right Rear Side Door Actuator Control Module
PWR WDO
30A
Window Switch-Driver, Window Switch-Front Passenger
RAP RELAY
10A
Relay Block (RAP Relay)
RH HEADLP HIGH
10A
Headlamp High Beam-Right
RH HEADLP LOW
10A
Headlamp Low Beam-Right
RR HVAC/TEMP CONT
25A
Air Temperature Actuator-Auxiliary, Blower Motor-Auxiliary, Blower Motor Relay-Auxiliary, HVAC Control Assembly-Auxiliary, Mode Actuator-Auxiliary
RR DEFOG/ HTD MIRROR
30A
Window Defogger Relay-Rear
RR FOG LP
10A
Fog Lamp Relay-Rear
RR PWR SCKT
20A
Auxiliary Power Outlet-Rear
RH T/LP
10A
Tail Lamp-Right, Trailer Rear Wiring Harness
RR WPR/WSHR
20A
Window Wiper Motor-Rear, Rear Window Wiper/Washer and Multifunction Switch
SIR
15A
Inflatable Restraint Sensing and Diagnostic Module (SDM)
STOP LAMP
15A
Stop Lamp Switch
SWC BACKLIGHT
2A
Steering Wheel Controls-Left, Right
T/SIG
10A
Turn Signal Switch and Backup Lamp Relay
Jan 09, 2018 | Pontiac Cars & Trucks
Where is the fuse for my driver seat? Does it operate both seats
Fuse Block - Rear
Left side of the luggage compartment, behind the left rear wheel well
.1
PSG SEAT Fuse -
30A
Seat Adjuster Switch - Passenger
DRV SEAT Fuse
30A
Seat Adjuster Switch - Driver
Feb 14, 2016 | 2008 Chevrolet Chevrolet Malibu LTZ
The AC in Rear want blow in my2002 Escalade
Yes there are two fuses and there are relays in the blower motor resistor assembly ! One fuse is located in the under hood fuse / relay box marked RR HVAC Fuse #21 30A Rear Heater, Rear Blower Relays. The other is located in the left Instrument panel fuse block marked IGN 3 10 amp. Fuse # 2. The Blower Motor Resistor Assembly - Auxiliary is In the right rear side panel above the wheel well ! The Fuse Block -Left I/P is On the lower left side of the I/P.Fuse Block - Underhood At the left side of the engine compartment near the battery .
Feb 11, 2015 | 2002 Cadillac Escalade
I need a fuse panal diagram for the 2013 VW Jetta, my 12 volt power ports are not functioning
Here you go. Fuses on E-box, on left in Engine Compartment
Fuse 1 - Not assigned
Fuse 2 - 10/15A - Engine control unit
Fuse 3 - 5A - Radiator fan control unit
Fuse 4 - 5/10/15A - Lambda probe heater,
Lambda probe 1 heater after
catalytic converter
Fuse 5 - 10A, 20A - Lambda probe heater1,
catalytic converter,
Fuel system diagnostic pump,
Charge pressure control solenoid
valve,
Exhaust gas recirculation cooler
change-over valve,
Crankcase breather heater element,
Vacuum pump for brakes
Fuse 6 - 5A, 10A,15A - Fuel system diagnostic pump,
Throttle valve module,
Activated charcoal filter system
solenoid valve 1,
Continued coolant circulation pump,
Auxiliary air heater heating element
Fuse 7 - 20A, 5A - Ignition transformer,
Fuel pressure regulating valve,
Fuel metering valve
Fuse 8 - 10A - Throttle valve module,
solenoid valve 1
Fuse 9 - 5A - Automatic glow period control unit,
Electric fuel pump 2 relay,
Fuel pump relay
Fuse 10 - 5A - Speedometer sender,
Brake light switch
Fuse 11 - Not assigned
Fuse 12 - 5A - Coolant circulation pump
Fuse 13 - 5A - Water pump
Fuse 14 - 5A - Engine control unit
Fuse 15 - 30A - Voltage stabiliser
Fuse 16 - 30A - ABS control unit
Fuse 17 - 30A - Automatic gearbox control unit
Fuse 18 - 20A - Automatic gearbox control unit
Fuse 19 - 1A - Onboard supply control unit
Fuse 20 - 30A - Onboard supply control unit (AW0)
Automatic intermittent wash and
wipe relay (AW1)
Fuse 21 - 50A - Secondary air pump motor
Fuse 22 - Not assigned
Fuse 23 - 40A - ABS control unit
Fuse 24 - 50A - Trailer detector control unit
Fuse 25 - 50A - Terminal 15 voltage supply relay 2
Fuse 26 - 60A - Automatic glow period control unit
Fuse 27 - 60A - Radiator fan
Fuse 28 - 40A - Onboard supply control unit (AW1)
Fuse 29 - 40A - Onboard supply control unit (AW1)
Fuse 30 - 50A - Terminal 75 voltage supply relay 1
Fuse 31 - 30A - Amplifier
Fuse 32 - Not assigned
Fuse assignment - Interior Fuse Panel
Fuse 1 - Not used
Fuse 2 - 5A - Electronic steering column lock control module
Fuse 3 - 10A - Instrument cluster control module
Fuse 4 - Not used
Fuse 5 - Not used
Fuse 6 - 10A - Vehicle electrical system control module,
Interior ceiling lights,
Tail lights
Fuse 7 - 5A - Fog lamp relay,
Instrument panel and switch illumination dimmer switch,
License plate lamps,
Fuse 8 - 7.5A - Windshield and headlamp washer pump switch,
Windshield washer pump
Fuse 9 - 5A - Airbag control module
Fuse 10 - 10A - Right steering column switch
Fuse 11 - Not used
Fuse 12 - Not used
Fuse 13 - 5A - Automatic dimming interior rearview mirror,
Light recognition sensor,
Parking aid control module,
Air quality sensor,
High pressure sensor,
Climatronic control unit,
Tire pressure monitoring button,
Back-up lamp switch,
Left washer nozzle heater,
Right washer nozzle heater,
28-pin connector
Fuse 14 4- 10A - Left steering column switch,
ABS control module,
Light switch,
Airbag spiral spring/return spring with slip ring,
Fuel pump control module,
Data bus on board diagnostic interface
Fuse 15 - 10A - 16-pin connector (diagnostic connector),
Headlamp range control adjuster,
Auxiliary heater operation relay,
Mass airflow sensor,
Positive crankcase ventilation heating element,
Left front headlamp,
Left headlamp beam adjustment motor,
Right front headlamp,
Right headlamp beam adjustment motor,
Fuse 16 - 10A - Engine control module
Fuse 17 - Not used
Fuse 18 - 15A - Left front headlamp
Fuse 19 - 15A - Right front headlamp
Fuse 20 - 10A - Automatic transmission control module,
Selector lever sensor system control module,
Tiptronic switch,
Ignition/starter switch
Fuse 21 - Not used
Fuse 22 - 10A - Ignition/starter switch,
Converter box,
Alarm horn,
Interior monitoring sensor,
Alarm horn relay,
Dual tone horn relay
Fuse 23 - 10A - Vehicle electrical system control module,
Light switch,
Rain/light recognition sensor,
Compass magnetic field sensor,
Fuse 24 - 10A - Vehicle electrical system control module,
Access/start authorization control module
Fuse 25 - 15A - Automatic transmission control module,
Multifunction transmission range switch
Fuse 26 - 15A - Brake system vacuum pump
Fuse 27 - Not used
Fuse 28 - 40A - Auxiliary heater operation relay
Fuse 29 - 1A - Vehicle electrical system control module,
Fuse 30 - 20A - Cigarette lighter,
12 V socket,
12 V socket 2,
Blocking diode
Fuse 31 - 30A - Light switch
Fuse 32 - 20A - Light switch
Fuse 33 - 40A - Heater/heat output switch,
Fresh air blower relay,
A/C control module,
Fresh air blower switch
Fuse 34 - 15A - Left front headlamp,
Fuse 35 - 10A - Steering column electronics control module,
Instrument cluster control module,
Signal horn activation,
Fuse 36 - 25A - Vehicle electrical system control module
Fuse 37 - 15A - Left front headlamp DRL
Fuse 38 - 15A - Right front headlamp DRL
Fuse 39 - 15A - Low beam relay
Fuse 40 - 15A - Towing recognition control module
Fuse 41 - 15A - Towing recognition control module
Fuse 42 - 20A - Towing recognition control module
Fuse 43 - 30A - Front passenger door control module
Fuse 44 - A25 - Rear window defogger relay,
Fuse 45 - 30A - Driver door control module,
Fuse 46 - 30A - Left rear door control module,
Right rear door control module
Fuse 47 - 15A - Fuel pump control module,
Fuel pump relay,
Fuel primer relay
Fuse 48 - 20A - Vehicle electrical system control module,
Fuse 49 - 20A - Climatronic control unit,
A/C control module
Fuse 50 - 30A - Front seat heating control module
Fuse 51 - 30A - Power sunroof control module
Fuse 52 - 20A - Dual tone horn relay
Fuse 53 - 15A - Front seat heating control module
Fuse 54 - 15A - Fog lamp relay
Fuse 55 - 20A - Light switch,
Fuse 56 - Not used
Fuse 57 - 15A - Radio,
Radio/navigation display unit control module
Fuse 58 - 1A, 30A - Telephone transceiver
DC/AC converter with socket, 12V-230V
Fuse 59 - 30A - Amplifier
Fuse 60 - 30A - Auxiliary heater control module
Jul 20, 2014 | Vw Mk1 Rabbit Caddy Jetta Pickup Golf 1.6...
Fuse for the alarm system
Here is the full list of fuses for you! and for the car.
catalytic converter
valve,
change-over valve,
solenoid valve 1,
Fuel metering valve
solenoid valve 1
Fuel pump relay
Brake light switch
wipe relay (AW1)
Fuse 1 - Not used
Fuse 4 - Not used
Fuse 5 - Not used
Tail lights
Fuse 11 - Not used
Fuse 12 - Not used
Air quality sensor,
28-pin connector
ABS control module,
Light switch,
Fuse 17 - Not used
Tiptronic switch,
Fuse 21 - Not used
Converter box,
Alarm horn,
Alarm horn relay,
Light switch,
Fuse 27 - Not used
12 V socket,
12 V socket 2,
Blocking diode
A/C control module,
Fuel pump relay,
Fuel primer relay
A/C control module
Fuse 56 - Not used
Hope this helps
--N
May 31, 2014 | 2010 Volkswagen Jetta
2004 Chevrolet Avalanche driver side heated seat switch with pedal adjustment and memory does nothing, doesn't light up or anything. The passenger side heated seats work perfect. Does this sound like
The left I/P fuse block also contains the 25A LT DOORS CIRCUIT BREAKER which could be defective (no 12V on ORG lead). The I/P relay block contains the 30A SEATS CIRCUIT BREAKER which, if defective, would affect the memory seat module (also no 12V on ORG lead). The pedal adjust circuit receives power through the 15A EAP FUSE in the underhood fuse block.
Mar 13, 2014 | Chevrolet Avalanche Cars & Trucks
Car only blows heat on passenger side, Drivers side still cold even after replacing the actuator. What else could it be?
If the blower motor is running, that means the 30A HVAC BLOWER fuse is OK. The HVAC control module obtains power through the 10A DIC/RKE fuse in the right instrument panel junction block and the 10A A/C CRUISE fuse in the left instrument panel junction block. Output from the HVAC control module controls the mode actuator and the recirculation actuator. You replaced one of the two. The other one may be defective or the replacement one may be defective. Also, the HVAC control module may be defective and not producing door control output
Sep 30, 2012 | 2005 Chevrolet Impala
2001 mustang v6 automatic convertible keeps blowing fuse #10 (park, tail lamps)
The fuse doesn't blow till you turn on the light switch? If it blows before turning on light switch, look for a short to ground between fuse box and light switch.
If it blows after turning on light switch, I believe they make a short finder tool.
Jan 15, 2018 | 2001 Ford Mustang
84 celica supra doesnt get any power to the power windows. I have two repair books, but both books tell me nothing about were the fuze or relay is for the power windows.
My information is from a Haynes manual for toyota celica supra 1979-1992. the wiring diagram on page 12-31 shows that the "gauge" fuse controls the window power relay. There is also a 30A "power" circuit breaker that feeds power through the relay. The gauge fuse is located under a panel on the left side of the dash on 1982-1986 models. The power window relay is located under the driver's side dash in a "kick" panel fuse box on the left outboard sidewall. The 30A "power" circuit breaker could be located in one of the two aforementioned places, in a fuse block on the passenger's side kick panel, or there is a "specialty" fuse block under the hood next to the air flow meter---the manual isn't clear on the exact location. If you can find the 30A power c.b. you may be able to reset it by pulling it out and pushing a paper clip wire through the reset hole. Reinstall and see if you get power.
Jan 13, 2011 | 1985 Toyota Celica Supra
My 98 Regal keep blowing the ignition fuse
Is it the 30A MaxiFuse marked IGN 1 or the 60A MaxiFuse marked IGN 2 from the underhood fuse block that blows, or a different fuse? Maybe the 10A IGN 0 fuse in the fuse block?
Nov 05, 2017 | Buick Regal Cars & Trucks
Mercedes C-Class Exterior Pillar Posts Trim Set Logo
111 people viewed this question
Top Mercedes-Benz Vehicle Parts & Accessories Experts
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Bill Boyd
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
