I have a smart tv an android tv box and att uverse for movie watching i have lousey internet its always buffering freezing up or simply says weak signal is there a way i can get stronger signal
Posted by Gloria Contreras on
Vijval Nataraja
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 12 Answers
Have you tried this
If you have try this
Top 10 Ways to Boost Your Home Wi Fi
Posted on Sep 12, 2015
5 Related Answers
Anonymous
SOURCE: Att uverse remote not working with Phillips lcd?
I just did some research on this problem and found a fix. If your tv has a powersaver feature on it turn it off i put mine on standard and my remote works fine now. weird but it works!
Posted on Jan 20, 2009
Anonymous
SOURCE: Not able to program vizio remote towork with att uverse Cisco box
Maybe too late for you but ATT just gave me a code that works with my Vizio plasma. Code is 1343. Even the mute works correctly. They gave me some others to try but I didn't need them. Other codes were 1018, 0030 and 0056.
Posted on Aug 28, 2009
Anonymous
  • 12 Answers
SOURCE: Programing Remote
1343 or 1005 are the codes - press the TV mode button and the OK button together - the release at the same time - the top row of mode buttons needs to blink twice - then enter the code - the TV button should blink 2 times - try the power and volume buttons - if it worked then be sure to press the ATT mode button again after so you can change the channels
Posted on Sep 12, 2009
Anonymous
SOURCE: need a remote code my new sanyo tv to go with
I went through all the Sanyo TV codes and then started entering in groups of 10. The U-verse offered 1103 i did 1100 to 1110 and it worked with 1107. Unfortunately at&T said you have to check the manufacturer which doesn't list universal codes. I was lucky on the Sanyo 18.5" LCD from Walmart using 1107!
Posted on Sep 13, 2009
Anonymous
  • 217 Answers
SOURCE: I have ATT Uverse. I have a white gear on my tv.
hi! just a tip hope it would help. if you have a white gear on to your tv it is either updating or probably something is wrong with the cable box. if the gear still present after a couple of mins try to do a hard reset on the cable box by pressin the power button for 10 seconds. if still doesnt work try to unplug and then replug the cable box like after 10 seconds, if still doesnt work reset the gateway but let me remind you that your internet and tv connection may be out for a couple of minutes, if still doesnt work then ill be advisin you to call ATT for further assistance, hope this would help. Goodluck!
Posted on Jun 03, 2010
Picture freezes
That is called buffering, it is caused by slow data speeds
I have a few android boxes and watch stream tv but lately they have been freezing up and buffering a lot what can I do to fix this problem? Internet speed is 50 MHZ.
If those android boxes have a slot for an SD card, put a card in and see if it helps. You say the internet speed is 50 mhz. Is that what you're paying for or actually measured with using an internet speed test software?
You may be being throttled if there are a lot of users in your neighborhood, Test your speed first before contacting your internet provider.
Why do down loaded videos from Google and Disney not play? He can stream videos from internet, but not if tablet is away from internet.
Use Disney Movies Anywhere with Google Play - the ...
support.google.com > ... > Movies & TV > Features & settings
GoogleYou can connect your Google Play account with Disney Movies Anywhere and ... If theDownloaded only switch is red, tap it again to see all of your videos.
Disney Movies Anywhere - Android Apps on Google Play
https://play.google.com/store/.../details?id...disney.disneymoviesanywher...
Rating: 4 - ‎63,729 votes - ‎Free
Or download movies to watch without an internet connection. ... Disney content with your eligible purchases, including original programming, never-before-seen videos, and much more ... Wish you could link to Vudu I have a smart TV but there is no Disneyapp. ..... But the Android app login does not work on my phone.
WATCH Disney Channel - Android Apps on Google Play
https://play.google.com/store/apps/details?id...disney...videoplatforms...
Rating: 4 - ‎17,070 votes - ‎Free
WATCH MORE & PLAY MORE with WATCH Disney Channel! ... No worries. ... Before you download this experience, please consider that this app contains advertising for ... Live video and the newest full episodes are only available with a ... 5 minutes later it logs off or something then when i go back it does the same and ...
Disney Movies Anywhere Streaming & Downloading
How do I stream movie to my lg smart TV without it pausing/buffering constantly?
go settings in the phone look for media streaming and turn it on.
mite have to go to apple apps store look for the program that fits or has the functions you are looking for.
www.ask.com
best apps for movie streaming on a phone
www.wikipedia.org
best apps for streaming movies for a phone
Loading continues through out movie
This will simply be down to your internet speed probably not the fault of the tv. if the tv connects to the internet through wifi make sure it can get a good strong signal, if posible hardwire the network connection using a lan cable. your current download speed can be determined using a pc and opening a web site like whatsmyspeed.co.uk, you need ideally at leat 4mbps download speed to be able to stream films
No sound on live U-verse TV after watching DVD on X- Box
Hi Jack,
This link I have might help you a lot. It has troubleshooting steps on how to do some stuff. Hope it helps.
verse TV Support
http://www.att.com/support_media/images/pdf/uverse/Quick_Fix_Guide.pdf
Mar 25, 2012 • AT&T UVerse
1helpful
Picture freezes or breaksup. TV problem or cable box problem? I just changed to uverse.
This is a Cable box/line problem not your TV call att and have a repair ticket made.
Samsung DLP 56' TV turns itself off when I initially turn it own. (I turn it on, then it shuts off for approximately 5-10 seconds and turns back on. Sometimes it does it a couple of times before it stays...
The problem is with the ATT UVERSE HDTV BOX and not the Samsung DLP TV. There is an inherent problem with the ATT UVERSE HDTV Box when using a HDMI cable. This was verified by the ATT UVERSE Technician.
Thanks,
Televison & Video Logo
Top Televison & Video Experts
Ekse
