Question about Lexmark X Office Equipment & Supplies
How do I clean print head on Lexmark x7170? - X Lexmark Office Equipment & Supplies
Posted by Kelly farris on
Rusum Gupta
  • 102 Answers
Here is a manual for the same. In case you are unable to do it, please call on 1-877-805-1027 for further assistance.
http://www.lexmark.com/publications/pdfs/lexmarkj110/eng/clean.pdf
Posted on Jan 12, 2016
5 Related Answers
Beni S-P
arben pllana
  • 1006 Answers
SOURCE: Installing printing applications on Lexmark x7170
Here u go:
http://www.downloaddelivery.com/en/cpddrivers/133.html
or:
http://www.opendrivers.com/company/2287/lexmark-free-driver-download.html
and please if u got help rate this solution as SOLVED
Posted on Nov 05, 2007
ohms
monk3ybidzness
  • 1879 Answers
SOURCE: Black lines on the back of the printer page
the rollers / guides the the underside of the paper touches
Posted on Sep 11, 2008
mrgreenz
Daniel Arellano
  • 962 Answers
SOURCE: Lexmark X7170 - Landscape orientation doc prints on bottom of a portrait page, not landscape
Go to print setup and go to properties then adjust the settings to the full page . right click on the default printer icon to go to properties.
Posted on Nov 06, 2008
Anonymous
SOURCE: How do I clean my Lexmark X8350 printer heads?
Was able to download the manual at no charge and found solutions on pages 96-98.
Posted on Jan 21, 2009
Teet Bergmann
  • 565 Answers
SOURCE: Problem with Lexmark X7170 and UBUNTU OS . Please help.
http://www.downloaddelivery.com/downloads/cpd/X7170SampleSANE-1.0-1.tar.gz
Posted on Feb 01, 2009
Lexmark x7170 changed ink cartridge. test sheet comes up great, print something and it says ink low. i tried to shut off 5x's to maybe reset/ reinstalled ink cartridges same message. cleaned heads
The Lexmark x7170 should let you continue printing with the ink cartridge regardless of the estimated ink with most cartridges. The only exception to this is if the cartridges are part of Lexmark's returns programme. I would advise removing the cartridge and checking for small text stating "Return Programme Cartridge" on the label. If this is present sadly there is no way of continuing, apart from buying a new cartridge.
With regards to the low ink estimate, am I right in assuming you are using a refilled or remanufactured ink cartridge? If so this is unavoidable but should not prevent you from printing until the ink physically runs out.
Nov 29, 2012 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
My lexmark X7170 Printer Skip line when printing how do fix it
Try to re-seat the cartridges in the printer. Open the printer cover > remove the cartridges > close the printer cover > re-brick you printer by pulling out the power supply - black box behind the printer where the power cord is plugged in, and re-plug after 10 seconds. When the printer turns on, reinsert the cartridges and close the cover. Try to print a document again to verify that the problem is fixed.
If that doesn't help, the problem could be due to a clogged print cartridge nozzle. Please follow the steps below to fix print quality issues with your model:
  1. On your computer, go to Start menu.
  2. Go to Programs.
  3. Go to Lexmark 2600 Series folder.
  4. Select Lexmark Solution Center.
From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through to clean the print cartridge nozzles.
Jan 03, 2012 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
  2. Go to Programs.
Is lexmark x7170 fax machine wireless compatible
The Lexmark X7170 printer does not support wireless printing. It doesn't have a wireless network adapter to connect to your wireless network.
If you want, you may contact Lexmark Technical Support Center for other printer options. You might find one that will suit your printing needs.
Nov 26, 2011 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
I have an x7170 and the color printing is streaked. I just put in a new cartridge and it is doing the same thing...
Try this approach instead:
  1. From the printer operator panel, press Setup button > and then press Ok.
  2. Press the up or down arrow button until Clean Cartridges is highlighted, and then press OK.
  3. Press OK again. A page prints, forcing ink through the print cartridge nozzles to clean them.
  4. Print the document again to verify that the print quality has improved.
If that doesn't help, please contact Lexmark Technical Support Center for additional assistance.
Aug 23, 2011 | Lexmark X7170 All-In-One InkJet Printer
I have the X7170 printer. I keep getting several blank horizontal lines through my text making those particular lines unreadable. It's been doing this for quite some time now. Hopefully...
Most obvious problem is that the ink heads are clogged, you need to run the nozzle clean utility.
If this fails to work (and may not given the time you say it has been doing this), try again. If after this, it shows no improvement, remove the cartridges, and clean the print heads carefully with a proprietary solution of cleaner. I'd moreover discard the old cartridges and replace them
Jun 16, 2011 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
I'm trying to download the software to my computer so that I can print
You can download and install the Lexmark X7170 driver from the Lexmark website. Just click on this link: Lexmark X7170 Drivers
Apr 19, 2011 | Lexmark X7170 All-In-One InkJet Printer
Error:2200
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
May 13, 2009 | Lexmark X7170 All-In-One InkJet Printer
I can receive faxes but when I send them they are illegible.
make sure glass is totally clean and pad is clean, also could be an issue with your scanner bulb
Feb 04, 2009 | Lexmark X7170 All-In-One InkJet Printer
INSTALLATION
Heres the link so you can download the installation program , its free ,click or copy paste:
http://downloads.lexmark.com/cgi-perl/downloads.cgi?lxkprod=Lexmark+X7170 , and click your OPERATING SYSTEM and your good to go , pl rate solution and thanks AJ
May 19, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Open Questions:
124 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
CheckitRight
CheckitRight
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
