Question about Frigidaire Affinity ATF7000E Front Load Washer
Err err err
I can not get get my washer to start all i get no matter what i try doing is this Err
Posted by clamkiller on
prem mathew
    President:
  • 1,294 Answers
Press "stop" & "cancel" together for over 10 seconds to clear the display; and continue your..........
And rate me pl.......
Posted on Dec 03, 2007
1 Related Answer
prem mathew
  • 1294 Answers
SOURCE: Err Err err err err pau
My Electrolux time manager washing machine wont start jus flashes red with Err
Hey Beverley, thanks for your post!
I see that your Electrolux washer is displaying the error code "ERR". Typically a number follows the "ERR" but if no number followed the "ERR" error code then your washer has detected an error. I would perform a reset on your washer which can be done by unplugging the power cord or flipping the household circuit breaker for roughly ten minutes.
If that does not help correct the issue it could be a problem with your control panel or wiring harness. I would recommend seeking out assistance from a professional in order to properly diagnosis and repair your washer. I hope this is helpful to some degree. -Matt
Oct 04, 2014 | Washing Machines
Err message whatever I press!
Try unplugging the washer, wait about 10 minutes and plug it back in. Maybe this will reboot your washer. Since most new washers are digital and maybe this will help. Good luck
May 13, 2014 | Zanussi ZWD1470W Front Load Washer / Dryer
WASHER MACHINE NOISE?
What is your model number?
Oct 26, 2012 | Maytag Washing Machines
ERR LOC on display
Your door lock switch needs replacing.
Jul 07, 2010 | Frigidaire GLTF2940ES Front Load Washer
When start is pressed ERR LOC displays, door
You can try clearing the code and then running the machine. Try colding down the pause and clear button simultaneously for three second s and the faul should clear Or try turning the knob around 9 times to clear the fault.
Jan 08, 2010 | Frigidaire ATF6000ES Front Load Washer
Pau err
I have had that problem before...Try unplugging it and plugging it back in...sometimes it's almost like dealing with a computer.
Apr 22, 2009 | Frigidaire Affinity ATF7000E Front Load...
Machine stuck on pause/err
un plug the washer for 5 minutes and re try
May 28, 2008 | Frigidaire ATF6000ES Front Load Washer
Nov 15, 2007 | Frigidaire Affinity ATF7000E Front Load...
Error message wont go away
unplug machine from mains for 5 mins then try it. close IRE
Nov 13, 2007 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire Affinity ATF7000E Front Load Washer Logo
206 people viewed this question
Top Frigidaire Washing Machines Experts
Marvin
Marvin
Poppa Maddo
Poppa Maddo
Nathan Van Boven
Nathan Van Boven
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
