Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
Have a spinscrub and water is spitting out the back as soon as it is turned on, and keeps slowly leaking as water is being cleaned up? F59414900
Posted by Veronica Althouse on
My SteamVac SpinScrub works fine then all of a sudden, the noise level of the vac seems higher and does not **** up water. I turn off vac then turn it back on, works good for awhile, then noisy, higher...
It sounds as if the ball in the tank in shutting down the suction prematurely. Be sure there is a gap of about 3/4 inch between the top of the filter inside the tank, and the lid of the dirty water tank. Without this gap, suction will pull the ball up too soon.
Apr 04, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Severe water leak at the bottom when turned on.
It sounds like the tubing that is suppose to be hooked to two spray nozzles has come loose. You will have to take that dirt tank off, then turn the machine upside down and take the two screws out that hold the hood on from the bottom by the brushes, and then turn the machine back upright and take the screw from the top out. You should be able now to take the hood off and see all the tubing exposed. There is only one tube that goes to the spaying part in the front and see if it needs to be pushed back onto its' barbed fitting. Put that back on and put the hood back together. That should get you going.
Dec 02, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Clean water tank leaks
Your going to have to replace it again, good thing is they completely remodeled the new one.
Aug 26, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover steam vac clean water reservoir leaking.
take the clean water tank out and look on the bottom for a fitting that screws on make sure its tight.also inside of that fitting trhere should be a washer or an oring to keep it from leaking.if thats not the problem then your pump mightbe leaking.for that i would take it to a vacuum repairman.i hope i have been of some help.please leave feedback
Apr 07, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover SpinScrub
I would almost guarantee the recovery tank is not seated properly. Trust me, I reseated the tank 5-10 times before giving up. I finally decided to give it one more try before forking out the money for another cleaner. I removed the clean water tank, turned the machine on (you could feel the air blowing out the sides on the bottom). With the machine still running, I unclipped the recovery tank and lifted it up (yes, you can do this, and it creates a very loud air thrust, but don't be scared), then I SLAMMED it back down into the seat and immediately I could tell the difference. The air stopped blowing from underneath and I could tell I had suction once again. I turned it off, put the clean water tank back on, and it worked like a charm. Trust me, you may be convinced that the recovery tank is seated properly.....LOL.....it ain't! Hope this helps!
Mar 24, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Steam Vac Deluxe Wont **** up water?
we can not as that type fix needs to be hands on not wireless
Dec 15, 2017 | Hoover SteamVac F5914-900 SpinScrub...
Leaking from bottom
It is the steamvac pump that is bad. When you fill up the tank with solutions, even though it is not running the solution leaks out, and when you turn it on it sprays up and out the sides etc. Also the attachment doen't work either, no solutions comes out. Apparently the float sticks in this. My husband fixed it once, and now he can't, need a new part. Options are take it to a hoover service dealer, or I found 2 place online that sell the part. One is http://buyitnow64.stores.yahoo.net/hostrepufor5.html and the other is http://www.sweeper-city.com/ho5brstpu.html, this site if you look at different size pumps have a description of the problem: "If your Hoover Steam Vac is leaking or water will not come out of the attachment hose, then this is the part that you probably need !!!
This part is for F5914-900 model. Hope this helps
Aug 29, 2008 | Hoover SteamVac F5914-900 SpinScrub...
HOOVER STEAM VAC
Check the seal where the tank sits on, also is the rod inside the handle moving up and down, or is it suck down pushing the reservior asm and allowing water to keep flowing. Another is there a hose off just under where the tank sits.
Feb 10, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Leaking
My machine leaked badly BUT it was my own fault. There is a one-time only setup procedure where you squeeze the trigger and push the Clean-Surge button to lock a rod into place. Push the Clean-Surge button VERY HARD. There will be a loud SNAP which sounds like you broke something, but you didn't. I didn't push hard enough initially, all I got was a click which I thought was enough. My machine leaked so I called the help line. They told me to push the button harder, and sure enough, they were right. Until you get that snap, the Clean-Surge (which releases a little extra water-cleaner solution) is on all the time, hence the leaking
Sep 22, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
502 people viewed this question
Top Hoover Vacuums Experts
Marvin
Marvin
Mike
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
