Question about Sony Cybershot DSC-P200
Wheel to adjust settings works when first turn on camera & then quits. WHen I set to playback, it automatically goes to some other setting.
When I take a picture & turn wheel to see photos, it doesn't change. It goes crazy & whatever I set the wheel too, it changes itself to another setting.
Posted by Dorie Riddle on
5 Related Answers
Anonymous
  • 113 Answers
SOURCE: Date doesn`t appear on the photo in computer
Download the userguide from the following link and please refer page 74 & 75 http://esupport.sony.com/perl/model-documents.pl?mdl=DSCW50 Good Luck
Posted on Mar 30, 2007
Anonymous
  • 4 Answers
SOURCE: cannot change flash setting
Hello, i just fixed that problem yesterday.
You just have to enable Burst mode.
You click on Menu, then you go down once, to the REC Mode, and you take the first choice (normal).
Posted on Dec 31, 2007
Anonymous
SOURCE: Flash options for sony camera
I recently had the same frustrating problem. The top of the camera has a little black button that can change from continuous mode or single picture mode. It has to be on single picture mode to change the flash setting. After this is changed you can press the flash setting onthe dial and change the setting. I hope it works for you.
Posted on Dec 30, 2008
zohail
Shoaib Rais
  • 1223 Answers
SOURCE: Can't change flash settings to Sony Cybershot DSC-H10 camera
Glad ur problem solved !
kindly rate my response WELL in system
Regards
Zohail
Posted on May 29, 2009
Anonymous
  • 10865 Answers
SOURCE: trying to change flash settings but says 'flash
Hello. I have a solution for you. You have your camera set to "burst" mode, which does not use flash. Reset it to "single" mode and you will be able to change the flash settings. Regards, Joe. PS Please rate my answer. Thanks.
Posted on Dec 09, 2009
1helpful
I cannot reset time and date on my samsung z2
Want to set the date and time for your mobile phone? Follow these easy instructions.
From a Home screen, tap the Arrow icon to display all apps.
  1. Navigate: Settings > Date & time.
  2. To use network-provided values, turn on the following:
    • Automatic date & time
    • Automatic time zone
  3. When manually setting data & time, perform the following:
    Automatic date & time and Automatic time zone settings must be turned off to manually adjust date and time.
    1. Tap Set date.
    2. Adjust the date then tap OK.
    3. Tap Set time.
    4. Adjust the time then tap OK.
    5. Tap Select time zone then select a time zone.
  4. If desired, tap Use 24-hour format to turn on or off .
2answers
Camera does not work
Sorry, but in a finepix camera, no image normally relates to when you are viewing the pictures you have taken and not in the shoot mode, applogies if i'm wrong, but theres seems no others are posting a solution.
What would be the easiest setting to use for a beginner
The easiest setting would be the AUTO mode. In this mode the camera does everything except decide where and when to take the picture. You can also use the various scene modes depending on what you're taking a picture of.
As you gain experience you'll want to use some of the other settings in order to take more control over your photography. I suggest you visit your local library. They should have some introductory photography books which will tell you when to use what setting.
How to import picture from Samsung camera PL120?
Transferring files by connecting the camera
as a removable disk
Connect the camera to your computer as a removable disk.
1 In Shooting or Playback mode, press [m].
2 Select Settings - PC Software - Off.
3 Turn off the camera.
4 Connect the camera to your computer with the USB
cable.
Transferring files with Intelli-studio
Intelli-studio will start automatically when you connect the camera
to your computer with the USB cable.
The battery will charge while the camera is connected to a computer with the
USB cable.
2 Select Settings - PC Software - On.
cable.
5 Turn on the camera.
• The computer recognizes the camera automatically and
Intelli-studio launches automatically.
6 Select a destination folder on your computer, and then
select Yes.
• New files stored on the camera will automatically transfer to
the selected folder.
• If your camera has no new files, the pop-up window for saving
new files will not appear.
Rate my answer if this helped you.
Sep 13, 2011 • Cameras
4helpful
Playback for movies on digital camera plats way too fast
I had the same problem. You have the recording setting on time lapse and there is no sound.
Set the recording on to standard by turning the round wheel at the back of your camera. I did not read the manual until I had this problem and I ended up making useless fast videos with no sound. Hope I am right?
1helpful
Kodak M1033 does not recognize memory card
  1. Turn camera on
  2. Push the options/settings button (the button next to the view/playback button)
  3. On the Capture Screen move over to "Setup"
  4. Move down to "Image Storage" and make sure its set to "Auto" {if not select it and set it to Auto}
  5. If already set to Auto, change to Internal Memory.
  6. Power off and power back on then follow steps 1-4 to set back to Auto.
If this still doesn't work, backup pictures from internal memory to computer then delete all pictures on internal memery. Camera should automatically prompt you to change to memory card.
2answers
Camera automatically resets some settings.
Sure sounds like it could be a firmware bug - I suggest you upgrade to firmware version v 2.0.0 (it looks complex but is really quite simple - just need to do upgrade twice - once for A and once for B.
If this does not fix it I would suggest repair - the CMOS (which stores the values when the camera is shut off) may be defective - it must be fixed by Nikon Service.
Problem with menu system maintaining display
I would highly suggest upgrading the firmware. Best thing to do first when having odd glitches like that.
1helpful
2answers
Aperture priority only in manual mode?
Yes. You pick the apature (the 3000 keeps it aorund the setting you pick) and then it automaticly adjusts the speed for you.
Sony Cybershot DSC-P200 Logo
Top Sony Photography Experts
Tony Parsons
Tony Parsons
Tom Chichester
Are you a Sony Photography Expert? Answer questions, earn points and help others
