Canon PowerShot A95 Digital Camera Logo
A
Anonymous Posted on Sep 10, 2015
We just got A495 Canon PowerShot Camera. Any special batteries or cards to use in it?
5 Related Answers
Anonymous
  • 3 Answers
  • Posted on Oct 30, 2007
SOURCE: Canon powershot G2
I just repaired my Canon G2 with the same symptom.  The internal PCB that you plug the external AC adapter is defective.  The numbers on the board are:
GCMK-M1X
QTipsX800Pro
Gregorio M
  • 48 Answers
  • Posted on Feb 08, 2010
SOURCE: Canon PowerShot S3 IS Digital Camera turn on
Get your camera serviced imediatly..
Anonymous
  • 1177 Answers
  • Posted on Nov 05, 2010
SOURCE: camera says card is locked canon powershot sx100
"Card is locked" usually means that the little write protect switch on an SD card has been set to stop the card being written to. Seems unlikely that it would happen to two cards in a row, but it is worth checking this.
Anonymous
  • 441 Answers
  • Posted on Feb 10, 2011
SOURCE: Canon PowerShot A495 the memory
Good day,
This tip will explain how to remove the write protect from your SD Card.
This is a easy fix and won't take a minute.
First remove your SD Card from your device. You will see on the side of the SD Card that there is a small switch. If your SD Card complains about being write protected simply put the switch in the opposite position. Some of the SD Cards even have the word LOCK on near the switch indicating the direction the switch must be to LOCK the card.
Once the switch is changed you can put the SD Card back into your device and the problem of write protection would be solved.
Please feel free to let me know if this tip was able to help you!
You can also visit http://www.fixya.com/support/r7042428-sd_card_write_protect for more info!
Regards
Anonymous
  • 567 Answers
  • Posted on Feb 22, 2011
SOURCE: how to restart canon powershot A495 camera
In order to restart the camera, please press the power button and it should restart.
In case you have already tried that, please remove the battery from the camera, wait for 5 seonds and insert them back.
This will cause the camera to restart.
If you require any further assistance, please comment and let me know, and I will be happy to assist you to further resolve your issue.
I will appreciate your feedback and positive rating for this solution.
Thank you.
How can I connect my camera to my tv to view images?
This link will show the procedure out of the users manual.
http://www.manualslib.com/manual/24743/Canon-Powershot-A495.html?page=89
Why won't my Powershot A495 take a photo?
iIt seems that the battery is low or not powerful enough to run the camera properly. when the camera notices there is not enough power it will automatically shut down. ensure the battery is fully charged up on the charger and then try it. the battery type is
Canon NB-3L and if the camera is a few years old or has been stored for a long time the battery may need to be replaced.
if all these have been done and still the problem persists i would recommend a dealer have a look at the camera.
to replace battery open slider plate on bottom of camera and flip tab to release the battery pack.
I hope this was useful.
1helpful
Whereismemorycard
If you are looking for the memory card in the camera, just open the battery door. There between the battery and the back side of the camera you find the memory card.
How to unlock my memory card of Canon PowerShot A495 Digital Camera
Take your memory card out of the camera and switch the position of the "lock" tab. One position is for "locked" (i.e., "Write Protected") and the other position will allow the card to be written to (unlocked). Some cameras have image protection built into the on-camera software and you may need to configure this there.
Canon Powershot A495 Wont power on using the ON/OFF button
Try this: remove the batteries and memory card....press every button...leave it alone for 20 minutes...insert the battery and then the card....turn it on.
My canon powershot a495 has a problem. it always
Alkaline batteries just don't have the power for more than a few pictures in today's power hungry digital cameras. Some batteries may also have reached their shelf life at the store, and though brand-new right out of the package may even have problems just powering startup of the camera. The one's that came with your camera are just to show you that the camera works, but as you've discovered, they'll only last for a few pictures. Digital cameras that use AA's for the most part should only be used with modern rechargeable batteries. If you read the camera's instruction manual concerning batteries, you should see the same recommendation.
Modern rechargeable batteries have over 5 times the power density of alkaline batteries (that's right, they last up to 5 times longer than an alkaline battery. And you can recharge them over and over!). Keep in mind rechargeable batteries will save you much money in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may be angry with yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
I have a canon powershort A495 camera now it shows "memory card is locked" let me know how it can be cure?
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
My canon powershot a495 has a problem. it always shows low battery and turns off. i have changed to new batteries three times but the same problem. i bought 3 months ago. help please thanks
my canon powershot a495 has a problem.
My Canon Powershot A495 is not getting detected by PC, I have to download photos.. Also I wont have External Card reader... Please guide.... TIA.. Amol Mane
Having gone over a month without a response to my query, I assume my suggestion to get and use a card reader solved the problem.
I have a canon power shot A495 digital camera. problem with camera is new or fully charged batteries discharges after taking 4 to 5 photos when taken with flash
all the canon cameras batteries do not last more than 2 years.
the best would be to purchase a new battery which you can find at any Target, OfficeMax of a sort department stores.
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
