Question about Dishwashers
While running a cleaning program it turned off and won't power up
Posted by Michael Siebert on
Parts AL
    Problem Solver:
  • 11 Answers
You may have a loose power wire down in the electrical box on the dishwasher. Sometimes the wire nuts come loose if they are not securely fully. A loose wire may give it enough power to light the control panel and when the water valve turns ON the amperage increases, then the wires will push apart. This is because the two loose wires become magnetically similar poles and push apart. I have fixed many dishwashers by turning OFF the power to the dishwasher. Removing the lower kick panel opening up the electrical box, then removing the wire nuts, then reattach the wires together with the wire nuts again. Turn ON the power and see if the washer now works. If it does, then reassemble the dishwasher.
If this does not work, then you may have a loose wire connection in the control panel.
Posted on Sep 13, 2015
Dryer says clean filter
Elizabeth, I can't answer your question until you provide more detail about the equipment and control thermostat. Brands, type, etc. If the "static" is too great, you should install a NEW filter. Turn the power switch off, then back on to reset the control and the thermostat.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dan_77d17b8918f54455
Sep 18, 2017 | Filter Heating & Cooling
Error code e01
do the following steps: God bless you
To start test program, press and hold both POWER SCRUB PLUS and RINSE & HOLD program buttons, then turn unit on by pressing ON/OFF button. When program buttons are released, lights above them will flash. To end test program, press ON/OFF button.To check program indicator lights (POWER SCRUB PLUS, REGULAR WASH and RINSE & HOLD), press and hold each program button. When REGULAR WASH program button is pressed, CLEAN light also comes on.
To start testing, press both POWER SCRUB PLUS and RINSE & HOLD buttons a second time. When testing has ended and a fault was detected, the following indicator lights will be lit:
POWER SCRUB PLUS = Heater fault
REGULAR WASH = Water filling fault (over or under filling)
RINSE & HOLD = NTC (temperature sensor) fault ? note circulation motor stops shortly after it started during an NTC fault
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
If water level switch (f1) has failed (opened), REGULAR WASH light will come on and unit will continually fill and drain where testing won't be completed. If flow switch (e5) has failed (opened), water won't heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), RINSE & HOLD light will come on immediately and testing will end shortly after water has started circulating.
If more than one fault occurs, more than one light will be lit.
Jul 21, 2012 | Dishwashers
DEHUMIDIFER WONT START
empty the tank, and clean the dust off of the condenser in the front or clean the filter. if it still won't turn on, may have a bad sensor or a siezed compressor.
May 09, 2012 | Midea Dehumidifiers
My laptop is running slow
Simply put, if you want to fix the problems more efficiently, try the Lenovo speed up program, available here: http://www.speeduplenovo.com/
If that still won't help, upgrade hardware!
That's it!
Apr 21, 2012 | Lenovo Computers & Internet
Kenmore 70 Series Dryer won't turn on. I don't think it is a door switch problem because when I hold down the door switch to make the dryer light turn off, the dryer still won't start. I...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 19, 2011 | Kenmore Dryers
After a power outage, the lid is locked and won't open. I tried running a new cycle but won't run either. Any suggestions. Thanks, Jan
This is a common problem, often associated with a momentary power failure when the controller doesn't get time to reset and return to an idle state before the machine gets power back and it gets "confused". Regardless of the cause, you will almost certainly find that unplugging from the mains (Not just powering off on the button, as some door locks have a sneak circuit, even when the power is turned off at the button) and leaving the machine undisturbed for a full 20 minutes will allow a reset, the door lock will disengage and all will be well when you power back up.
Additionally, on older machines with analog program selectors, turn the selector to an end of program setting before you power it off.
Jul 11, 2011 | Washing Machines
Water not draining
Set the controls to off then power off at the mains for 30 mins and then power mains back on and run a drain program or a full wash program. If the water won’t drain away then the most likely problems are the door interlock switch is faulty, the drain water motor is faulty, there is a blockage in the drain outlet pipe or filter – this will need unblocking, there is a blockage in the water pump – this will need to be unblocked, the controller board is faulty – but this generally shows an error code. First turn off the mains power to the dishwasher then check the internal filter and screen and clean it thoroughly. Then check the waste water hose and any outlet valve and make sure that it is unblocked and free of any obstruction or waste material. If you have access to the water pump you can check that it is free of obstruction and is able to turn and that none of the impeller vanes have been damaged. Then if all this is OK then try turning on the mains power and running a hot wash cleaning cycle to flush out any remaining sludge / debris.
Oct 01, 2009 | Frigidaire Dishwashers
The machine struggles to move grounds through after brewing. The tray seems to be locked in.
Your brew unit is probably dirty and needs cleaning. However, it won`t always help just running the cleaning program. Try to clean out all the used ground that is stuck inside the brew unit; use your fingers or a toothbrush maybe. Then run the cleaning program. It may be smart to run the program once or twice after this too, but you don`t have to use the tablet everytime.
It is the grounds blade that holds the used ground container so you can`t get it out. This means that the brew unit stops in a wrong position, and don`t get back to grinding position before timeout. If you shut down the machine for a few hours, it usually moves back during startup. But of course; this indicates that you need to clean up inside...
Jul 16, 2009 | Jura Capresso Impressa S8 Coffee Maker,...
Dishwashers Logo
50 people viewed this question
Top Dishwashers Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
