It finished the cycle and beep it was done .went to turn it off what is when I got the red light and message 1
SOURCE: Display Lights Flashing
try to unplug the power cord for more than a minute to see if the control panel reset itself first
SOURCE: fisher paykal top load washing machine
I had the same problem. I unplugged the machine for a while (overnight) and it then worked properly when I plugged it back in. Probably just a circuit board issue that was cleared with the power removed.
SOURCE: fisher paykel washer
Sounds like you could need a new out of balance switch or bracket, also try to make the clothes evenly spread in washing machine on rinse if they clump up on one side of the bowl they will cause out of balance :)
SOURCE: beeping and red light stating U3
Hi and welcome.
You posted your question in the DD/DS603 series section, but code U3 is usually seen on a DD/DS601 or DD602 series. When this code appears, most comon cause is that the machine is set in LP or LOW PRESSURE mode and needs to be set to HP or HIGH PRESSURE.
The fault is sensing water level too high in the drawer, which can also be caused by a blocked drain or inoperative pump. I can tell you exactly how to tell if the machine in in the wrong mode if you can tell us the correct model number. The machine's pump/drain system can easily be checked by putting the machine in diagnostic mode and running the drain pump.
SOURCE: F&P washer lights on and beeps
Clogged pump stopped up drain. If the washer does not think all water was pumped out in 8 minutes then it shuts down. Slow drain is my first inclination.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
If you get the Xbox 360 1 red light message, it means that the problem is either with the DVD drive, or with the hard drive.
Fortunately, the Xbox 360 1 red light message is not something that you should worry about. In order to identify which of the two drives the Xbox 360 1 red light messages is referring to, just look the code number that the screen displays. DVD drive errors are identified with the codes E64, E65 and E66, whereas hard drive errors are identified with codes E67, E69 and E79.
Once you identify which error the Xbox 360 1 red light message is pointing to, fixing it is really easy. The guide available at Fix-xbox360.info will tell you what to do in each case, as well as what to do in case you get any of the other Xbox 360 lights messages. Check it out.
