Question about Manitowoc Kitchen Appliances - Others
Check compressor, is it running?
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jerry_8a145f1328fa119f
Posted on Sep 08, 2016
SOURCE: i have a model qd0452a manitowoc and it will not
Very unusual for one of these to not stop. There is a magnetic proximity switch located on the bottom right side of the water curtain that serves to both cancel a harvest/drop and to shut the unit down on a full bin. When a drop occurs the control board sees a open and then close of the switch and restarts a freeze mode. If the ice drops and the bin is full the curtain is blocked by the ice behind it from closing again and the unit shuts down on a full bin indication. If the curtain does not open and close after 3 hours it would lock the unit out. Therefore I assume that the switch and the board are working. Most likely you either have the unit on a non-Manitowoc bin or are missing a deflector plate in the Manitowoc bin and the ice is falling out of a service door.
Posted on Dec 11, 2010
SOURCE: My Manitowoc Ice machine is making ice slowly and
You're bridge thickness is set to high, lower the bridge on the sensor located when you open the front door behind the water curtain on the top. If the sensor is scaled badly replace it.
Posted on Feb 14, 2011
SOURCE: I have a Manitowoc QD0212A
Try cleaning the radiator for the ice box compressor it could be tripping it's thermal overload switch, if that doesn't work check to see if the termostat setting is in the range for the compressor to turn on when the ice starts melting.
Posted on Jun 29, 2011
compressor or condenser fan motor bad, very rear problem, or check wires on physical damage.
Posted on Aug 23, 2015
Apr 19, 2015 | Manitowoc SM50 Series Ice Maker
Aug 31, 2014 | Manitowoc SY0324A S Series Ice Maker...
Aug 05, 2014 | Manitowoc Compact Undercounter Ice Machine...
Oct 31, 2013 | Manitowoc SM50 Series Ice Maker
Feb 12, 2013 | Manitowoc SY0454A S Series Ice Maker...
Sep 18, 2011 | Manitowoc Heating & Cooling
Nov 11, 2010 | Manitowoc SY0454A S Series Ice Maker...
Apr 23, 2009 | Manitowoc MAN-KF6E Koolaire Undercounter...
509 people viewed this question
