Changed out coil, getting 120V across coil and 11ohms but still wont heat up. Dryer coil looks like steel spring, old coil was broken but was much thinner. Could I have the wrong coil? No error code except a clicking sound. Fuses are continuous and so are thermostats.. Should dryer be electrically hot ?
BOTH LEGS OF AC MUST WORK TO GET HEAT FOR DRYER Maybe the receptacle has no power on one of the 110 volt legs. Both legs of the 220 volt AC have to work go get heat. Only one leg is used to run the motor etc.. Your motor runs so this can fool you into believing that the electrical connection is ok when it really is not. Your dryer is on a double circuit with two breakers. If one fails you lose one 110 volt leg which can be the one giving the full 220 Volt needed for the heater. This happens quite frequently and people mistakenly replace heating coils. You could have a bad breaker, one of the two. You must check this first before assuming anything else. Get help if you are uncomfortable with potentially deadly voltages
There are several things that can cause this issue but you can check the most common problems by following the instructions here:
Electric Dryer Runs But Dont Heat
Most dryers are 220. its possible your breaker is half tripped. try cycling the breaker.. you should get 220 across it while its running. (Be careful).
