Question about Mitsubishi WD-65734 65" HDTV
Turns on with snow and yellow light under lamp. Why does it shut down after 20 seconds?
Mitsubishi wd 65734 had a yellow light under lamp. I replaced the lamp, comes on with snow, goes off after about 20 seconds and yellow steady light. Is it the fan? I checked to make sure the lamp I bought was the correct one and it was. So now I'm back to square one, solid yellow light, no picture, set goes off.
Posted by pam Receveur on
rostit
  • Mitsubishi Master
  • 746 Answers
Yellow steady light is overheating. you have a stuck fan or its all clogged with dust. The only way to fix it is to find what is causing it to overheat or prevent the fan from spinning. It is not lamp related unless you bought a lamp that does not have an Osram bulb inside.
Posted on Sep 15, 2015
Mitsubishi wd-65734 65 in. Tv shuts off on its own and red lamp light comes on. after a few minutes i can turn it back on and works fine for a few min to an hr before doing it again. anyone no wat the...
Same thing on my tv after replacing lamp. Lamp manufacturer advised me that after changing bulb, tv must be reset or tv will go into safety mode and will not turn on. To do this on my model WD-65734 you must hold reset button in with a pen or paperclip for about 10 secs.The LED will start blinking for a few mins. When itstops you need to unplug tv set for about 1 hour. After this the tv will be reset.
Apr 22, 2012 | Mitsubishi WD-65734 65" HDTV
WD-65734 Mitsubishi TV won't turn on. System reset
Are there any lights lit on the front of the TV? Have you checked for a bad lamp? When you reset the TV the timer/power light should flash on and off rapidly for 60-70 sseconds. Does that happen?
Aug 26, 2011 | Mitsubishi WD-62526 Projection TV
I have a 65" Mistubishi WD - 65734 and have no
Yes,"LAMP" LED light indication front of tv bazel frame is on or blinking,yes mean tv projection lamp life are over.The whole tv warrenty only for a year,tv projection lamp should last at leat 1 1/2 or 2 years,by tv been on and watches used it like 4 or 5 hours daily?U never done tv replacement parts,any kinds before?Yes,hire a tv Tech. to do it.Shop around for a Tv tech.should replaced the projection lamp for u shoud be around $250 to $300 that including part the projection lamp.
Jan 03, 2011 | Mitsubishi WD-65734 65" HDTV
How to reset lamp timer on mitsubishi wd-65734
This model there is no reset for lamp timer.
Nov 14, 2009 | Mitsubishi WD-65733 65" HDTV
WD-65734 shuts down code 38
The sensor is usually right by the lamp, somewhere by the housing. There were a few bad batches of temp sensors and some others where the temp sensor connector went bad (hardwiring fixed those) . it usually has yellow wires and should be a short (0 ohms) if good, open (infinite ohms) if bad
Jan 06, 2009 | Mitsubishi WD-65733 65" HDTV
Replaced lamp and now can't get a picture
Hi Sally Jo, Unit powers on and works properly for a while then shuts off with a red lamp LED (lamp error). Suspect bad lamp part # 915P020010 2. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 3. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 4. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 5. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 934C148001. Hope this helps!
Sep 17, 2007 | Mitsubishi WD-52327 52" Rear Projection...
Mitsubishi WD-65734 65" HDTV Logo
Top Mitsubishi Televison & Video Experts
Paul Bade
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
