Epson Stylus Pro 4000-PS InkJet Printer Logo
Kevin Miller Posted on Sep 08, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where is the printer ip address? - Epson Stylus Pro 4000-PS InkJet Printer
Ron
Level 2:
Scholar:
  • Expert 67 Answers
  • Posted on Sep 08, 2015
 Ron
Expert
Level 2:
Scholar:
Answers
67
Questions
0
Helped
18697
Points
224
You should be able to print the settings from the printer. Press the menu button and go to the reports and print the settings. You can also load the drivers and they will search your network for any available epson printers. I have included a link to the downloads page for documentation and drivers.
Epson Stylus Pro 4000 Print Engine
tip
Printer IP Address Lookup
<span></span><b>Need assistance in looking up for your printer's IP Address?</b><br /><br /> Often times we see a networked printer suddenly stop working and you need to find a static (private) ip address of the printer to diagnose further. How do we find IP address of a networked printer? There are a few different ways to go about finding it. <br /> <br /> 1. A network printer with built-in ethernet port usually provides a menu button that will allow you to display IP address assigned to it. You may also try printing self test or configuration page from your printer. <br /> <br />2. If you can't find an IP address of a network printer from the menu display or your printer is connected to a printer server with no display, you may find its address from any networked computer configured to use the printer. To find the printer IP address from a Windows machine, perform the following. <br /> <ul> <li>Start -&gt; Printers and Faxes, or Start -&gt; Control Panel -&gt; Printers and Faxes <li>Right-click the printer name, and left-click Properties <li>Click the Ports tab, and widen the first column which displays IP address of the printers </li></ul> 3. If your networked printer uses DHCP, you may connect to your router and find the IP address of the printer from DHCP status page. The router displays all host machines that are assigned dynamic IP addresses. <br /> <br /> 4. You may also try pinging your network from a computer connected to the network, and lookup an arp table. On your computer, click [Start] -&gt; [Run...] and type "cmd" and [Enter]. Type "ipconfig" to find your network address. The network address is found by performing a logical AND operation on your IP address and the subnet mask. For example, if you IP is 192.168.1.101 and subnet mask is 255.255.255.0, then the network address is 192.168.1.0. Ping your network using a broadcast address, i.e. "ping 192.168.1.255". After that, perform "arp -a" to determine all the computing devices connected to the network. One of the IP found is your networked printer. <br /> <br /> 5. You may also use "netstat -r" command to find an IP address of all network routes. However, if your printer has problem communicating with other network devices, you may not be able to find IP address of the printer using "netstat" command.
Set up epson workforce 600 printer wifi via dlink dir615
Configure the IP address range your wireless printer, (this is done through the printer's menu settings) make sure it matches the IP address range on your wireless network, it maybe 192.168.1.*** then configure the wireless printer with a fixed IP address with the same IP address range but higher address eg. 192.168.1.10 so it does not clash with any other IP addresses.
Next install the printer driver normally.
Then configure the printer Properties.
Click Start - Printers and faxes - right click on the Brother printer - click Properties - Port tab - click Add Port - Standard TCP/IP port -
Port Name eg. 192.168.1.10
Printer name eg Network printer
Click OK
Then do a TEST print if it does not work then the IP address is probably incorrect.
Where is IP address for the MFC-7220 printer
Network printers do not have a set IP address, you need to configure the printer with an IP address that uses the same range of IP addresses as your network.
The IP configuration is normally done through the printer's Menu on the printer's buttons.
If your are using a network IP range 192.168.0.*** that your wireless router issues automatically then select a fixed IP address on your printer above the number of computers that is installed on your network. (ie if you have 10 computers the make the printer's fixed IP address say 192.168.0.30) so the wireless router cannot issue a conflicting IP address.
When you install the printer driver on each computer then go to the Printer Properties - Port tab - click Add Port - IP port and enter the printer's fixed IP address and printer name.
Do a test print to check if your computer connects to the network printer.
2answers
Where do i find the ip address for my lexmark z705 printer
This may help.
How do I find IP address of a network printer?
  • Start -> Printers and Faxes, or Start -> Control Panel -> Printers and Faxes
  • Right-click the printer name, and left-click Properties
  • Click the Ports tab, and widen the first column which displays IP address of the printers
4. You may also try pinging your network from a computer connected to the network, and lookup an arp table. On your computer, click [Start] -> [Run...] and type "cmd" and [Enter]. Type "ipconfig" to find your network address. The network address is found by performing a logical AND operation on your IP address and the subnet mask. For example, if you IP is 192.168.1.101 and subnet mask is 255.255.255.0, then the network address is 192.168.1.0. Ping your network using a broadcast address, i.e. "ping 192.168.1.255". After that, perform "arp -a" to determine all the computing devices connected to the network. One of the IP found is your networked printer.
Thank you for choosing FixYa! have a good one!
2answers
We are trying to download the drivers for a network but it is asking for the IP address IPv4 and we don't have it. Could you provide it.
well check your printer machine IP address...just like a computer printer machine have their own IP.then use the IP of you printer...
2helpful
I have one Epson TMU220PD printer. I have to set its IP address. how can I do it. Also, i want to know its default IP. Thanks, Saket
switch on your printer while pressing feed button.printer will print some pages and u can read ip address of printer in printed page.Then add same ip range in ur computer.connect printer to pc by network cable.test ping command to printer ip address.if ping succes then open internet explorer, type printer ip address in address bar, press enter key..there u can set ip adress from tcp ip options.
Brother MFC 8860 has ip conflict. How do I resolve this? The issue is that the IP address is different on my computer versus the printer and thus doesn't allow them to connect. Greg
Each IP-address on a network (private in your home, or public on the Internet) must be unique; hence "IP conflict" when two devices (computers or printers or iPod Touch) try to "claim" the same IP-address.
If you have configured a "static" IP-address into the printer, change it to an IP-address that is *NOT* used on your network.
Or, find the computer on your network that is using the same IP-address as your printer, and change its IP-address and reboot it.
In order to connect, your computer and your computer *MUST* have *DIFFERENT* IP-addresses.
2helpful
Dell 5100cn change ip address
Changing Printer's IP Address isn't that complicated. There are two ways on how to change the printer's IP Address.
If you know the old printer's IP address, you can simply type that old IP address on the Address Bar of your Internet Explorer or any other browser (ex: http://192.168.1.101). It should redirect you to the printer's User Interface. From there you can go to Network then TCP/IP settings. You can change the IP address of the printer. Make sure to use an IP address within the same range of your network.
The other way to change the printer's IP address is by its own Menu/Settings on the printer's LCD panel.
On your printer, press Menu then got Settings. Look for Network or LAN settings and click on Advance. Select TCP/IP and click on Edit. You can now change the IP address of the printer from there. Click on Done or Save after that.
Note: Make sure the use the correct IP address within the network's range.
4helpful
About n/w printer
If you have the network enabled 1022 you need to find out it's current IP address. To do this press & hold the Go button on the top of the printer (the large button) for 5 - 10 seconds or until the printer starts to print. This prints out the configuration page.
The printer is set to get an IP address via DHCP from the factory, but once you have it's IP address you need to give it a static IP address. You can do this by typing the IP address into a web browser & go to the network tab. choose an IP address that has not been allocated already & apply the changes.
You will need to type the new IP address into the browser if you want access to change further settings.
You can then add the printer using the new static IP address.
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
