Hi, the basic elec. Design. Of auto lighting circuits is based on this concept. Dash lights and tail lights use the same feed, For example, if a dash light. Was shorted, you will lose dash and tail lights, Assuming. your stereo has the factory system, this is where. I would start. First chk your fuses, if they are ok, your. issue. may be your dash dimmer,, or worse cas, your muttifunction switch may be def.
SOURCE: 1999 Jetta Headlights not working at all
try replaceing bulbs if thats not it it could be a fuse or a wiring problem
SOURCE: brake and dash lights no working
Had a similar problem and fixed it by installing a new headlight switch / turn signal lever. Hope this helps.
SOURCE: Need to know which fuse controls park lights/dash
buy a chiltons manual from autozone or oreillys has the diagram for all fuses
SOURCE: 1991 Toyota Camry, tail lights and dash lights don't work
Have you looked under the hood? There are more fuses under the hood. Is your dimmer turned down on your dash lights?
I have a Nissan Altima 2002, engine 2.5. The problem is that the cars dashboard lights are not working, also the altenator is not working?
