SOURCE: Renault Megane
this might sound silly but check you do not have the child lock on.
please leave feedback
SOURCE: renault megane key fob wont work
I had the same problem with mine
your key fob is now out of sync with the ECU to sync them just follow this link (renault will charge up to £180 for new key and to sync it)
http://renaulthelp.110mb.com/ImmBypass.html
SOURCE: My Renault Megane Scenic S reg heater is not working
Most likely to be a faulty resistor block, which has 3 resistors and a thermal fuse controlling fan speeds 1,2 and 3, maximum speed 4 by-passes the resister block. It may also be poor electrical connections to the resistor block caused by overheating. Renault ask for approximately £350 to carry out repairs, a replacement resistor block will cost £50. If you decide to carry out the repairs yourself, be advised that if you are not competent to carry out such work you, could cause electrical damage or worse an electrical fire.
SOURCE: my renault laguna 1999 rt remote key fob wont work?
IF YOU TYPE 1999 RENAULT LAGUNA REPROGRAMME KEY INTO A GOOGLE SEARCH, YOU WILL BE ABLE TO PRINTOFF INSTRUCTIONS TO REPROGRAMME THE KEY TO THE KEY READER.THE IGNITION NEEDS TO BE OFF TO DO THIS
