Question about Apple iPhone 4S
Error 3194 when i try to restore or update my iphone 4s ios 7.1
I tried everything, i edited the host file in the windows folder, i disabled the firewall, i uninstalled my anti-virus, & i also used the wired connection Internet instead of wifi router, none of this worked for me, every time Error 3194, i even tried to restore from another PC, & i also got the same error, this is frustrating, any ideas about how to fix this?
Posted by Black Light on
Eller
    Novelist:
  • Apple Expert
  • 78 Answers
Hi, This is probably too late but I really hope this can help you or others.
FoneDog - iOS System Recovery
software is the easiest solution so far that we put it on top to let you know that FoneDog - iOS system recovery fixes error 3194 without any data losses and compatible with all iPhone models, iPads and iPod Touch. Here are the steps on how to use FoneDog Toolkit:
Step 1: You need to Download, Install and then Launch FoneDog -iOS System Recovery software
Step 2: Make sure that FoneDog - iOS system recovery detected your iPhone
Step 3: Proceed to "System Recovery"
Step 4: Confirm device in System Recovery module
Step 5: When the download is complete, the repair process starts
Step 6: You are good to go
More information you can see: How to Fix iTunes Error 3194 or iPhone Error 3194
Hope it can help you! How to Fix iTunes Error 3194 or iPhone Error 3194
Posted on Apr 26, 2017
Jesse Allen
    Master:
  • Apple Master
  • 307 Answers
This tutorial should be able to help: How to Fix iTunes Error 3194
Posted on Mar 19, 2018
Apple Technical Support Number 1-833-493-0111
    Habit-Forming:
    Scholar:
  • Apple Expert
  • 36 Answers
ITunes Error 3194 occurs when your system is not able to connect with Apple,s firmware signature verification server. To Fix iTunes Error 3194, read the easy steps are given below:
Steps to Fix iTunes Error 3194:
Step 1: Close iTunes and open the open the hosts file on your computer and go to terminal from the utilities folder, then type sudo/nano/etc/hosts, and press ? Return. This will open the hosts file in a text editor.
Step 2: Now find the bottom of the hosts file to look at the Apple address at the bottom. Here a standard hosts file would not have any lines without a # at the front.
Step 3: Now look for a .74.208.105.171 gs.apple.com entry that will redirect the signature verification process to the Cydia servers. Owing to existence or nonexistence or that is producing the error.
Step 4: Now save the changes you made and your iPhone should now connect properly. To save successfully on Mac Press Ctrl+O to save and Ctrl+X to quit.
Step 5:Here you need to restore your iTunes and attempt your restore or update again. Because in few cases changes you did to your hosts file should allow you to proceed.
Step 6: Now keep your iOS device on Firmware update mode, especially when your iPhone is still not able to establish connection. However, make sure you have keep backup of your iPhone because iPhone will erase all of your device data.
Step 7: To restore your device connect the iOS device to your computer and switch it off. Then press and hold the power button and home button simultaneously for 10 seconds. After 10 seconds now release the power button but keep pressing the home button and you can see the message saying in iTunes prompting you to restore the iPhone.
After following these steps if you are still unable to Fix iTunes Error 3194, just call us 1-833-493-0111 for instant solution.
1 833 493 0111 How to Fix iTunes Error 3194
Posted on Nov 27, 2017
Stephen Riw
    Habit-Forming:
    Scholar:
  • 47 Answers
Generally, host file editing is useful to fix iTunes error 3194, you need make sure you did it right:
Step 1. For Windows, navigate to C:/Windows/System32/drivers/etc/ and find the file that's named "hosts". For Mac, the file is in /etc/
Step 2. Open the file in Notepad (or any other text editing software) (for Windows users, open this with Administrator Privileges). You'll mostly have this line at the bottom of the file: 74.208.105.171 gs.apple.com
Step 3. Either comment this line out by typing a single '#' (without the quotes) in front of the line (before 74) or remove the line entirely.
Step 4. Now, save the hosts file and then try updating your iPhone through iTunes. In most cases, the error shouldn't pop up now.
IF doing as above, still not working, you can change another iTunes backup recovery tool as an alternative. Personally, I recommend PhoneRescue to help you restore iPhone from iTunes backup.
Posted on Apr 21, 2017
Erik Walters
    Scholar:
  • 155 Answers
Whenever there is an ios update offered, Apple will give enough time to the public to install the update. When they decide that there has been ample time to do so, they stop writing the certificates that allow access to the older updates for security reasons along with others. It's still possible to do it with an iphone 4 though because it's a hardware thing that apple can[t fix with a software update.
Posted on May 05, 2016
5 Related Answers
Geekman
Chris Hingee
  • 32281 Answers
SOURCE: My wifi doesn't connect to
Ad-hoc is a computer to computer connection.
You need to change the wireless configuration to Access Point (Infrastructure) mode with encryption.
Your wireless card in your computer or laptop needs to be configured with the router's wireless settings eg. the SSID and encryption key
The encryption key (network key) is in your wireless router, without this key the wireless router won't allow the computer or laptop to connect to this wireless router.
The WEP, WPA, WPA2 encryption key is in your router's wireless settings. Log into your router and got to the wireless settings, you will need to get the SSID and the encryption key. Then go to your computer or laptop's wireless card and configure it with the router's SSID and encryption key, so it will then connect to the wireless router and the Internet.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Posted on Dec 30, 2010
celltech_adv
Michael J.
  • 443 Answers
SOURCE: my iphone does not turn
If the ios 5 is in beta. That means that it's in Test mode. If it keeps messing up and dying. It's not ready yet.
Beta = Test
So the best you can do is offer feedback to Apple over it, then restore your phone back the the latest ios 4 for the time being, and wait for ios 5 to get out of Beta mode
Posted on Sep 21, 2011
usmc4peace
usmc4peace
SOURCE: update ios 5.1 with jailbroken iphone 4s
Not possible on 5.1 for 4s apple stopped writing the code for 5.0.1 already so a downgrade ain't happening bright side though any day now according to Twitter
Posted on Apr 14, 2012
marco
  • 35 Answers
SOURCE: After downloading ios 6 on my Iphone 4s, I tried connecting to itunes and it gave me an error message saying it can not connect, need to download the latest itunes version, whichI tried to do, but did
first try to unplug your iphone and update your itunes first. then get back on me and let me know what happen. post it here.
Posted on Oct 15, 2012
ipodslinger
Steve Brown
  • 688 Answers
SOURCE: ever since i have ios 7 on my iphone 4s, i'm not
It sounds like the app may need to be updated for iOS 7,
The Lockbox website says it's compatible on iOS 5.1 and above. but i cant confirm if its updated for the new iOS yet.
it shows a new version 1.3
check your updates and see if it updates today.
Posted on Oct 18, 2013
I wrote a text message to someone today and at the bottom of the message in a gray box popped the word Velkomin
Hi, you can try FoneDog iOS System recovery.
  • Fix with various iOS system issues like recovery mode, DFU mode, white screen looping on start, etc.
  • Fix your iOS device to normal from white Apple logo, black screen, blue screen, red screen.
  • Only fix your iOS to normal, no data loss at all.
  • Unfrozen your iPhone, iPad and iPod touch
Here are some articles for FoneDog:
Tips & Trick to Fix Your iOS System
iOS System Recovery Guide How to Fix with Various iOS System Issues
May 16, 2017 | Cell Phones
I want to take my pictures out of iCloud so I can make copies
It's in your best interest to transfer the photos to a local storage solution, perhaps an external hard drive, or another cloud based drive. Once you cancel the service, no guarantee that your data will still be there, so take care of your data and those precious photos.
Dec 24, 2016 | Cell Phones
Error 4103
Here is an Apple forum about this issue.
Iphone 4s not working after ios 7 upgrade
Jul 31, 2014 | Apple iPhone 4S
How do I prevent Tenorshare iphone data recovery from crashing every time I try to connect my iPhone?
Hello, firend. iPhone Data Recovery for iPhone 4S is leww likely to crash and DFU mode is not needed. And the bug-fixed version is better than the previous. If it crashes really badly, you can apply for an exchange from Tenorshare.
Contacts Tenorshare on: http://www.tenorshare.com
Mar 07, 2013 | Cell Phones
Iphone 4 error 3194
  • Quit iTunes
  • Locate your hosts file, in Mac OS X this is /etc/hosts and in Windows this is c:\windows\system32\drivers\etc\hosts
  • Open the hosts file with Administrator privileges
  • Add the following lines to the very bottom of the hosts file:
  • 74.208.105.171 gs.apple.com
  • Connect your iPhone to the computer
  • Launch iTunes
  • Put the iPhone/iPad/iPod into DFU mode by turning the phone off and then holding down the sleep and power button for 10 seconds, then release the power button but hold onto the home button until iTunes tells you that the device is now in recover mode
  • Use the iTunes Restore feature as usual with the iOS device
  • After the process, remove the line you added to the hosts file.
Jun 24, 2011 | Eforcity for IPHONE 4 OS4 4G 16/32 GB...
My iphone is unable to update and restore and I got error code 1015.
This usually happens when you hve problems downgrading firmware or jailbreaking.
Here is a guide to fix it.
To fix this error, you will have to make a couple of changes in your system's "host" file, by pointing it towards Cydia server instead of Apple's. Also this is not it, you may also receive another error during restore: 1004, or 1015 from iTunes saying: "The iPhone [you name] iPhone could not be restored. An unknown error occurred (1004)". The following step by step instructions will guide you on how to fix these errors so that you can restore any of your new iOS devices like iPhone 4 or 3GS to iOS 4.0.1 successfully.
Step 1: Download the required iOS 4.0.1 ipsw firmware files from here.
Step 2: Put your device into DFU mode (not recovery mode).
  • Connect your iPhone to your computer.
  • Turn iPhone off.
  • Start iTunes.
  • Hold Power and Home buttons together for 10 seconds or so.
  • Release Power button but keep holding the Home button until your computer recognizes a new USB device.
  • iTunes will now recognize your iPhone.
Note: Your iPhone screen at this time should be blank (black in color), if not, then you are most likely in Recovery Mode, not DFU mode.
Step 3: Before you proceed, you must make sure that you have your SHSH blobs saved on Cydia for the firmware version you restoring or downgrading to. If you don't have your SHSH files saved, you cannot downgrade or restore to iOS 4.0.1.
So now, what we will do is to trick iTunes into thinking that it is watching Apple servers, while in real, we are going to change the address to Saurik's server.
  • Navigate to C:\Windows\System32\drivers\etc\ and locate "hosts" file.
hostsfileinwindows.png Mac OS X users can get to "/etc/" directory by going through "Go -> Go to Folder" from Finder.
  • Open this "hosts" file in Notepad (for Windows) or TextEdit (for Mac OS X) and add this
74.208.105.171 gs.apple.com line as shown in the screenshot below:
21.png Now simply save this file and you are good to go!
NOTE for Windows 7 and Vista: Start "Notepad" with Administrator privileges by right clicking on "Notepad" app, and click on "Run as Administrator" option.
NOTE for Mac OS X: Make sure you have full read and write access on your account when you are saving the host file. If it still throws permission error, simply copy the host file to desktop, make the required changes, and then replace it with the original file in "/etc/" directory.
Step 4: You will now have to restore your iPhone to the firmware you downloaded in Step 1. Click on your phone icon from the sidebar in iTunes. Now press and hold left "alt" (option) button on Mac (Left "Shift" button on Windows) on the keyboard and then click on "Restore" (Not "Update" or "Check for Update") button in the iTunes and then release this button.
itunes.png This will make iTunes prompt you to select the location for your downloaded firmware file. Select that ipsw file and click on "Open".
Step 5: Now sit back and enjoy as iTunes does the rest for you. This will involve a series of automated steps. Be patient at this stage and don't do anything silly. Just wait while iTunes installs firmware on your iPhone. Your iPhone screen at this point will be showing a progress bar indicating installation progress. Now at some point, iTunes will probably throw 1004 or 1015 error at you. This is normal, just ignore this error as the firmware has already been successfully installed on the device.
iphone42.png Step 6: Your iPhone at this point will be stuck in Recovery Mode, showing that "Connect to iTunes" screen. To exit your device from Recovery Mode, download this program called TinyUmbrella (Windows / Mac). Run it and the click on "Kick Device Out of Recovery" button. Your device will now restart normally.
iphone43.png This is it, you should now be able to jailbreak and unlock your device.
Feb 23, 2011 | Apple iPhone 3G
How to restore iphone to factory settings?? I lost the password.
To restore iPhone and reset the phone to default factory settings, follow these steps:
  1. Turn off iPhone – Hold down the Sleep/Wake button for a few seconds until the red slider appears, then slide the red slider. Ignore this step if your iPhone is already off.
  2. Press and hold down the Home button for about 10 seconds until a yellow triangle with a text which says Please Connect to iTunes appears. iphone-recovery-mode.jpg
  3. Plug the iPhone into Mac or Windows PC. Release the button if you haven’t.
  4. Run and open iTunes if it’s not already opened yet.
  5. iTunes will prompt a message that says iTunes has detected an iPhone in recovery mode. Click OK.
  6. You will be taken to the iPhone pane. Then, click on Restore.
  7. Wait for the full restoration process to complete, and the iPhone will be back to the original settings state as when it left the manufacturing factory, typically a working phone again if you face any problem, unless it’s hardware related.
Jul 03, 2010 | Apple iPhone 3G
Apple iPhone 4S Logo
150 people viewed this question
Top Apple Cell Phones Experts
Ekse
Marvin
Marvin
sandyp4ever
sandyp4ever
Level 1 Expert
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
