SOURCE: Filter location? Rheem Classic Super Quiet 80, RCBA 2457GG14XI
Open the two side panels. The filter is at the bottom held down with a wire spring. Release the spring and the filter can be removed.
SOURCE: Rheem classic super quiet 80.
YOUR TEMPERATURE SENSOR NEEDED .
CLEANING, LIGHT SANDPAPER WILL DO THE TRICK.
IT LOOKS LIKE AN UP RIGHT NEEDLE ATTACHED TO A SMALL WHITE DISK.
http://alltemp.com/FreeInHomeEstimate.html
SOURCE: my rheem quiet 80
I have a Rheem Classic 80 furnace that would ignite but not stay lit. Cleaned the ignition sensor which was easy to get to and the flame sensor which was under the burner plate and it fired up and stayed lit. The flame sensor was about 6" under the burner plate. Easy to get out, but tough to get back in. Used the old piece of paper shim trick to get the screw to "stick" in the socket and it was much easier to position the screw and get it back where it belonged.
