Question about HP LaserJet 1020 Printer
Alignment of solonoid pickup of hp 1020 - HP LaserJet 1020 Printer
Posted by ramasoami on
How do I align the HP Laserjet 1020 to print straight? Its printing crooked every time. No two sheets are in the same position
Most likely to be a page feed problem, look online to clean page feeder rubber rollers.
Try here for the pdf manual which covers problem with jams and skewing
http://www.hp.com/ctg/Manual/c00264334.pdf
Mar 05, 2015 | HP LaserJet 1020 Printer
Hp 1020 out put jam problem
CHECK & CLEAN THE PAPER PATH .
PICKUP ROLLER MAY FAULTY
Jan 06, 2015 | HP Office Equipment & Supplies
No paper pickup problem in system printer (HPLaserjet 3050 models)
open back & side covers.. start diagnosys..
chech paper pickup unit trying to picking up the paper?..if yes.. clean/replace pickup roller..
No. check solonoid acting proprly,,
Paper passing little bit?..if yes..check paper sensor flag strucked?
check transfer roller gear properly engaging with the catride? 1.Replace catridge..2. Transfer roller check..
Good luck..
Sep 05, 2011 | HP LaserJet 3055 All-In-One Printer
My 1991 nissan pickup want crank
few things, battery flat, battery termanl corroded, ignition fault, Solonoid on starter stuck, ignition wire on solonoid has come off or corroded connection. trying to help without seeing, hope these get you started, good luck
Jun 01, 2010 | 1991 Nissan Pickup
Paper won't feed
More than likely you pickup roller is dirty.
You can try to clean to see if that helps.
If that fails, then replace the pickup roller.
Below is a service manual that will show you how to remove and clean the pickup roller and how to replace it if necessary.
LJ1020 Service Manual
  • Pickup roller RL1-0266-000CN 50,000 pages Affects paper pickup
Sep 04, 2009 | HP LaserJet 1020 Printer
1 inch ink smudge down right side of paper
try going on ur computer that the printer is contected to and have the printer align itself
Mar 17, 2009 | HP LaserJet 1020 Printer
Drivers
I loss the drivers of HP LaserJet 1020 printer. I need now. Please help me.
Jul 16, 2008 | HP LaserJet 1020 Printer
HP LaserJet 1020 Printer Logo
135 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
