Question about LG Microwave Ovens
Cost of control circuit board LG microWave oven error code E-10
Posted by Pavithran on
5 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: My LG Combi Microwave oven
This is usually caused by either a bad door switch (usually the top one), a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
Posted on Apr 20, 2008
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: Whirlpool microwave/oven combo- model #RM288PXS
That would be a problem with your control board. It probably needs a few capacitors and a relay replaced and minor circuit board repair.
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
William E. Miller
[email protected]
P.S. (to Guest: Please make a new post with your model number. I think your problem is different.)
Posted on Nov 08, 2008
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: Microwave turns on & control panel is frozen. F2&PAN error codes
You have a shorting membrane keypad. If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and please do not leave it running unattended.
On this model, the membrane keypad is not available as a separate part, so you would have to order the control panel frame which comes with a new keypad.
In this case, you simply move your circuit board into the new frame.
That is a simple do-it-yourself job.
You can find helpful exploded view diagrams and order parts by entering your full model number (KHMS155LWH1 without dashes) from the tag on the oven here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Posted on Jun 11, 2009
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: LG lmvm2075st microwave control panel problems.
"On each panel the board surrounding the same diode is burned"?
Maybe that's a three-tap power relay, not a diode?
I'd be very interested in this and I have the service manual here which you can download.
Feel free to contact me directly (and please include your full model number from the tag in or on the unit) for a free estimate and free tips & do-it-yourself advice.
Also, if you can send me a photo of the burned area, that would be helpful.
William E. Miller
[email protected]
Posted on Jan 31, 2010
Kolawole Ayede
  • 327 Answers
SOURCE: 66993 pizza oven microwave oven combo
Hello, please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
Posted on Jul 13, 2010
What is error code E-10 on a LG microwave oven, model MC- 7646UQ
This usually means a defective control circuit board.
Contact manufacturer for help.
Jun 27, 2017 | LG Microwave Ovens
What does E 13 mean on a Kenmore microwave oven?
Kenmore microwaves are made by several manufacturers. The E-13 error may indicate a humidity sensor issue or a problem with the control board. It could also be an issue with the wiring between the sensor and the control board. Try unplugging (or turning off the circuit breaker to) the microwave for at least 30 seconds. This may reset the error. If the problem recurs, the sensor or the control board may need to be replaced. Microwaves can store an enormous amount of power in the capacitor and may be dangerous. Repairs are best done by a professional.
I hope this helps.
(The E-13 code diagnostics above apply to Samsung-made microwaves.)
Mar 12, 2016 | Kenmore Microwave Ovens
What is SMH18165 -Error code: E-13?
It is a T1 maximum time error (oven did not preheat properly). usually caused by a failing thermistor/sensor, a bad seal, bad control circuit board or connector. Unless you are a really good electronics expert and have the test equipment for after-repairs microwave emission measurement, it has to be dealt by the service people.
Read more http://www.kgbanswers.com/on-a-samsung-over-the-range-microwave-what-does-the-code-e-13-mean/11020759#ixzz37XLvUOq8
Jul 09, 2014 | Samsung SMH9187ST Microwave Oven
My microwave is showing EE on the control panel and then stopping what could cause this
Hi.
If the microwave was built by LG, then error EE means "EEprom Failure".
The eeprom is a memory chip built into the oven electronic control board. The error usually means that the electronic board must be replaced. In some case the alluminium insulation foil that protects the board must also be replaced. A radiation leakage test must be done after carrying the repair. The repair must be performed by a technician.
Regards.
Ginko
Dec 15, 2011 | Sharp Microwave Ovens
F3 Message on microwave
Hello
GE microwaves with a digital display will show an error code when there is a problem or malfunction with the unit. One type of error code that will be displayed on a GE oven and require troubleshooting is a code F3. An F3 error code indicates that the keypad for the control panel is bad or has a short. This will cause the microwave to beep continuously after the set clock message appears.
Unplug the power cord for the microwave from the electrical outlet. Pull the microwave out from the wall and set it on a table or the counter.
Find and remove the two screws from the top of the grille, on the font of the unit, with the Phillips-head screwdriver. Pull the grille off of the microwave.
Find and remove the screws that are used to secure the control panel to the microwave frame. Lift the control panel unit up and away from the microwave.
Find and remove the screw that is used to secure the green ground wire. Pull out all of the connectors and ribbon cables from the control board.
Apply heat from a hair dryer to the front of the control board for at least 30 seconds. Make sure the hair dryer is at the low setting. Pull up on one corner of the top membrane, then peel it off of the control board.
Repeat Step 5 for the other membrane that is on the control board.
Insert the pliable circuit of the new membrane through the opening in the control board. Remove the wax backing to expose the adhesive for the membrane. Place the membrane onto the control board.
Peel the wax backing off of the top membrane, then place it on the control board.
Place the control board back on the microwave and secure it with the screwdriver. Reattach the grille, and set the microwave back in place.
Plug the microwave back into the power outlet and reset the clock.
Oct 04, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Cannot turn on the microwave oven. Getting E-10
E-10 = Control Board fault
This is usually associated to the main control circuit board. When this develops a fault it will quite simply disable the microwave. It can however be triggered by other less serious faults, for example the door switch can produce an E-10 error although this is rare. If it simply is not powering up then it is more than likely the main control board and needs to go to an LG repair centre to be properly repaired.
Hope this helps
Jul 15, 2011 | LG 1.2 Cu. Ft. Mid-Size Microwave -...
I have a sharp microwave sometimes it works for 10 or 20 seconds and then stops with error ee2, other times it works fine. Today it did the same but stopped with error ee1!
This sounds like a keypad problem, sometimes a short developes in the keypad controller causing all kinds of intermittent problems, on the back is the microprocessor circuit board which controls vital areas of the microwave oven. The cost to repair will be high and consideration should given to looking at a replacement.
Feb 17, 2011 | Microwave Ovens
Error message
The F6 error code on your microwave oven is a relay failure.
Check wiring to relay 4903 for short circuits. If wiring is OK - replace the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 14, 2009 | Kenmore 61701 Microwave Oven
Works for approx 30 secs then it cuts off with a error Code F7 message.
Assuming yours is a model KHMS2050SSS0, here is what the technical sheet says about the F7 error code:
1. Unplug microwave oven or disconnect power.
2. After 40 seconds, check to see whether this solves the problem.
3. Unplug microwave oven or disconnect power.
4. Check cooling fan operation
5. Check the magnetron.
6. Check P65 connection on the relay control board.
7. Check the P56/P66 connection between relay board and relay control board.
8. Check wiring to the 1200W inverter and control system. See “Checking Inverters.”
9. Check operation of all interlock switches.
10. Replace all parts and panels before operating.
11. Plug in microwave oven or reconnect power.
12. Check voltage at 4903-1 on relay board. If it is 120, unplug microwave oven or disconnect power.
13. Replace inverter.
14. Replace all parts and panels before operating.
15. Plug in microwave oven or reconnect power.
16. If problem persists, unplug microwave oven or disconnect power.
17. Replace relay control board.
18. Replace all parts and panels before operating.
19. Plug in microwave oven or reconnect power.
20. If problem persists, unplug microwave oven or disconnect power.
21. Check for reversed plug connection on controls or loose wiring.
22. Replace all parts and panels before operating.
23. Plug in microwave oven or reconnect power.
(This troubleshooting guide presumes one does not know how to test electronic components. That's why they say to replace and part and check it again.)
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
If yours is a different model number, please reply back.
May 26, 2009 | KitchenAid KHMS2050SSS Microwave Oven
Microwave Ovens Logo
286 people viewed this question
Top LG Microwave Ovens Experts
Sheldon Dedek
Randy Schumann
Randy Schumann
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
