LG 5350 37V 1550mAh Extended Life Liion Battery Logo
J
Joan Engelhaupt Posted on Sep 06, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I get a ringtone instead of vibration on my LG530G cellphone?
I used to have a ringtone, and I don't know what I did to make it only vibrate now, but I want my ringtone back, please.
Bill Boyd
Level 3:
Top Expert:
  • LG Master 53,816 Answers
  • Posted on Sep 06, 2015
Bill Boyd
LG Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11949454
Points
172802
Try going into settings and change the method from vibration back to ring tone
Testimonial: "Thanks, Bill. I have tried that, but it didn't work."
  • Bill Boyd Sep 06, 2015
    next step is to find a phone shop/ repair shop and ask how it is done
How do I turn the ringtone volume up? i set the ring setting to "vibrate and ring" and when I get a call from someone I sometimes feel the vibration but I don't usually hear my ringtone...how...
Hello patty,
Depending on the brand and model of your phone, there usually is a volume control on the side of your cellphone. If it doesn't have one, please reply here and indicate the brand and model of your phone.
Oct 16, 2011 • Cell Phones
tip
How to Fix iPhone Not Vibrating?
If you are in a meeting or attending a special event, you probably set your smartphone to silent mode to avoid any distractions from your phone. But what if there is an emergency? You will miss the calls and texts from your phone and then regret it later after realizing that it is a very important matter that needs to be discussed with you.
If you don't want to disturb your meeting or the people around you when your phone receives calls or texts, then choose to vibrate mode instead of silent mode - at least you will be notified if your phone receives any notifications. But what if you are using an iPhone and you learned that the vibrate mode is not working. What would be the reason behind it?
/uploads/images/fix-iphone-not-vibrating-undefined-undefined-0.jpg
Fix iPhone not vibrating
Now, if your iPhone is not vibrating when it receives calls, texts, notifications, or when you switch on the ring or silent mode, then you need to learn some of the solutions to fix this issue. Here are the 3 effective solutions that you need to know.
Solution 1: Check the iPhone Vibration on Sound and Haptics Settings
One of the basic things that you should learn about your iPhone is how to set the phone settings, especially the vibration mode. If your phone is not vibrating, go to your iPhone settings then navigate to the sounds & haptics option and check the vibration mode from ringtone to text tone - if off, turn it on. Then disable the focus mode that restricts the vibration of the app's notification.
Solution 2: Check the iPhone Vibration on Accessibility Settings
After enabling the vibration in the sound and haptic settings but still your iPhone is not vibrating, then go to the accessibility settings and check the vibration mode is turned on.
Solution 3: Fix iPhone not vibrating via iOS System Recovery
If the first two solutions didn't work on fixing the vibration issue of your iPhone, don't worry. With the iOS System Recovery, all iOS errors will be fixed including the vibration issue of your iPhone. This reliable tool can quickly solve any type of iOS error.
on Jul 14, 2022 • Miscellaneous
Hello boss 3110c vibrate is not working plz help me
every nokia cellphones vibrating functions are usually place in the profile features, when you are on the PROFILE functions scroll it down until you see the vibrating functions. and vibrating functions are now usually use in the silent mode. if you don't find it in your profile functions try scrolling down it in the SETTINGS functions. if all doesn't work it means you will have to be ready with your warranty because some cellphones comes out from the factory with defects.
1helpful
How to change from ringtone to vibrate and back
Press and hold the * key to switch to turn "Vibrating mode on." Press and hold * again to turn "Vibrating mode off."
5helpful
3answers
LG env3 alarm clock vibrate
Yeah, I had that problem too. I thought my phone was broken. -_- My old phone from Verizon is like 4 years old and I JUST got my enV3. On my old phone, I'd have to set the alarm's ringtone to "no ring." But, on my enV3, "no ring" literally means NO ring, no vibration, no notification, no nothing. On the enV3, in order to set your alarm clock to vibration mode, all you have to do is make sure you "master volume" is in vibration mode, but you have to set your alarm's ringtone to something other than "no ring."
My Slice phone no longer rings out loud or vibrates when a call comes in. How do I restore those settings?
Check out this link for a PDF manual for your phone. Just copy and paste into your browser.
http://safemanuals.com/user-guide-instructions-owner-manual/UTSTARCOM/PCS1400-_E
I got this info off of page 60 from your manual.
CUSTOMIZING YOUR PHONE VOLUME
Control the volume for Ringtone, Speakerphone, Headset, and Advanced settings.
Ringtone
Set ringtone volume and incoming call alert options:
1. Press [Menu], then press "Settings".
Press "Sounds", then press "Volume".
2. Press "Ringtone".
3. Press / to adjust the volume level. Press to select Vibrate when High is the volume level.
The volume settings available are:
• Silence all: All sounds are off.
• Vibrate : Phone will vibrate to alert you of incoming call or message.
• Off: Only the ringtone is muted.
• Ringtone mode: Low, Medium, High.
Tip • You can adjust the ringtone volume with the side keys.
Hope this helps. Let me know if I can help you with anything else.
JimmyC
1helpful
Ring tone vs vibrate
There is no option to turn off the ringtone. You're not doing anything wrong. The only way to turn off the ringtone is to use the volume button to turn the sound off or to vibrate, or using the hot key (#) to go to "Vibrate Only Activated". I hope this explains what you wanted to know.
1helpful
Ring vs vibrate
This phone allows you to independently set ring and vibrate modes. When you access "Call Vibrate" to set the mode, also visit the "Call Ringtone" menu to turn off the ringer.
You may want to leave the vibrate mode OFF and your ring tone ON and use the quick keys to switch between ring and vibrate. Two ways to do this, push and hold the # key to switch between normal mode (the settings you chose in "Call Ringtone" and "Call Vibrate") or use the side volume button to access the "Master Volume" and select "All Off", "Vibrate" or a ring tone volume.
If this helps you, please leave me a good rating.
2answers
No ring, only vibrate
if the ringtones ring from settings or the songs play then it will be surely the settings problem please select ring and vibrate instead of vibrate only and if it doesn't works then go to a near by repair shop and ask them to check and change the buzzer
Top LG Cell Phones Experts
vince
Steve Sweetleaf
Steve Sweetleaf
nexrad_chris
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
