Question about Kenmore Side by Side Refrigerator
My Kenmore refrigerator side by side, the ice maker works but the water coming from the ice dispenser is warm. I tried putting in a new filter. Why is the water warm?
Posted by leonid gitlin on
5 Related Answers
fridgetech
Craig Shelton
  • 473 Answers
SOURCE: Kenmore Side by Side Refrigerator Ice Maker Not Working
A couple things to check here. First see if there is ice in the tray. If so chances are the ice maker will need to be replaced however these are very reliable ice makers. If no ice in the tray pull up on the ejector blade (don't worry you won't break it) turn clockwise to start the ice maker thru a cycle. The ejector blade is the long white bar with fingers on it that run the length of the tray. Once it completes a cycle it should fill with water. If no water then either the fill tube is frozen over and will need to be defrosted or the water valve is bad.
Posted on Oct 05, 2007
Anonymous
  • 100 Answers
SOURCE: Kenmore Refrigerator stopped dispensing water
Either your water tank in the fridge froze up, the waterline that goes up the freezer door from the bottom hinge froze, or the switch that your glass hits is damaged. Do you hear any humming or noises when you put your glass up to get water?
Posted on Oct 30, 2007
duby1990
Justin Duby
  • 370 Answers
SOURCE: ICE MAKER NOT WORKING
Check to make sure you freezer is at 0 to 5 degrees. If it is not the water valve to the ice maker will not even open.
Posted on Nov 20, 2008
Anonymous
SOURCE: Kenmore Coldspot Ice maker is not working on our side by side refrigerator
I have Kenmore Coldspot top freezer that is not making ice. I herad a clicking sound.
Posted on May 08, 2009
Anonymous
  • 6 Answers
SOURCE: kenmore coldspot 106.556325 not making ice
could be your ice maker or your water valve
Posted on Aug 30, 2009
My kenmore side by side is not making ice
when was the last time u change your water filter, if water is coming into the ice maker and it don,t make ice that means u have a defective ice maker, if no water comes into the ice maker check the water valve at the back of the refrigerator with an ohm meter for resistance if no resistance is present replace water valve,u should unplug water valve when checking
Jan 16, 2013 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I have a Kenmore side x side. I have changed the water filter and now water is coming from the water spout when water is needed to make ice. Just prior to changing the filter I noticed water coming from...
Sounds like the dual water inlet valve on the back where the water supply is connected, has gone bad and is leaking across to the other side. It may also put water into the ice maker when you use your dispenser.
Jan 13, 2011 | Kenmore 44103 Side by Side Refrigerator
Kenmore side by side: ice maker works...ice
Probably a broken plastic tube from the solenoid valve to the water outlet tube. It will stay dry until you try to get water then it may take a few days to dry out.
Good Luck,
Gilsh
Nov 27, 2009 | Kenmore 57029 Side by Side Refrigerator
Water will not dispense to ice maker
The water dispenser in the door of my Kenmore side by side will not work. The ice dispenser does work. What do I need to do to fix it?
Thanks Kel
Sep 06, 2009 | KitchenAid KSCS25FKSS Side by Side...
Icemaker not making ice
If water is also not com out of dispenser then filter should be changed. If water dispenses but ice ice is not being made, the sensor arm or infrared sensor may be stuck or blocked. If sensor is OK then ice maker needs service.
Aug 25, 2009 | Kenmore 57029 Side by Side Refrigerator
I can get water to the water dispenser in my side by side. but it will not make water. It's a Kenmore 22 side by side. I believe the model number is 9522611. We switched the wires on the solenoid and it...
the inlet water valve has a screen on the inlet in the valve which is probably clogged - replace the inlet water valve with a new one, install a ice maker water filter in the water line feeding the ice maker!
Jan 15, 2018 | Kenmore 56562 / 56564 / 565 / 6656569 Side...
Kenmore side by side makes no ice
the water line coming into the freezer may be iced up. or the motor that spins the ice "ejector" arm may be stuck. try spinning it manually (just dont force it).
May 29, 2009 | Kenmore 44103 Side by Side Refrigerator
Kenmore side by side refrigerator Ice maker not working
Found out we still had a warranty/service contract on it. Contacted SEARs and I explained problem to technician. Scheduled house call is Friday.
Apr 14, 2009 | Kenmore Refrigerators
Water won't dispense from side by side fridge
check for water at bottom of door going in, if there water line in door or tank in door freezing. only fix to replace door. ck with dealer to get fixed under warranty
Jun 11, 2008 | Refrigerators
there is valve for each right at the water inlet, your valve is stuck or your coil is bad......get a new valve.
Nov 03, 2007 | Refrigerators
Kenmore Side by Side Refrigerator Logo
120 people viewed this question
Top Kenmore Refrigerators Experts
gbob59
Dale Copeland
Dale Copeland
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
