Question about Maytag Refrigerators
How do I change the freezer lite bulb?
My Manual doesn't tell me how only for the refrig bulb
Posted by Mary on
richie46
    Top Expert:
  • Maytag Master
  • 12,962 Answers
A bulb is a bulb is a bulb. Unscrew and replace.
It might be behind some cover - if so remove the cover and unscrew and replace and put the cover back on..
Posted on Sep 04, 2015
Reverse Light doesn't work, fuse good and bulb to.
I haven't worked on an escape, but i can tell you that switch is on the transmission.
Jun 02, 2013 | 2010 Ford Escape XLT
My dashboard main light went out. I don
check the fuses if not the fuse its the bulb
May 17, 2010 | 2006 Jeep Liberty
I have a GSS25KGMD fridge. I opened the Fridge compartment top part was very warm and the bottom was cooler. Upon investigating more I noticed that the fridge bulb was very hot. So I pushed the fridge...
Your refrig light switch does control the freezer fan and the refrig light bulb . Replace the refrig light switch .
Open the refrig door , freezer fan goes off and the refrig light comes on .
Nov 03, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Replacing Light bulb in a Frige
Open refrig door, look at control panel, on each end of control panel there should be philip screws holding panel, remove screws, drop panel down slowly, replace light. Install in reverse order.
Oct 16, 2009 | GE PTC22MFM Top Freezer Refrigerator
Bulb went uot new bulb not working
...will need to check power at socket. using a multimeter.
Jun 17, 2009 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Bulb does not light on refrig side. When it happened it popped out the two control knobs. Reset control knobs and replaced bulb but the bulb will not light. After resetting the knobs the refrigerator...
i would alssume(knowing about this refrig) that the leectronic control board hasgone bad. the board is located behind the unit next to the compressor, inside a white housing, if you rmeove this board yull probably see a "burn" on one or more ofthe resistors, this is what controls the lighting in refrig sect, not affecting the cooling but only lights
Mar 04, 2009 | Refrigerators
Whirlpool refrig side by side
flickering noises??? are they working at all. or are tehy flickering on/off along with the noiise. id be willling to bet that if you removed the back panel from behind the refrig, youll find a control board mounted on the left side(when lookin at from behind) alongside the compresssor assy in a white box. if thats the case that, that there is a board there and your lights are not functioning and you hear "chattering" when the doors open you have a faulty board, look up via model number and replace it
Oct 31, 2008 | Whirlpool Refrigerators
Refrigerator
possible that the bulb recepticle is losing contact with bulb, real common among refrigs that have 2 bulbs back 2 back in one socket.UNPPLUG refrig and try prying up the brass contact arm on bottom of socket assy.UNPLUG first, that contact is live!!!!!!!!
Feb 18, 2008 | Refrigerators
Refrigerators Logo
71 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
