Dear Helen,
Which filter? You have the air filter, the oil filter, and the cabin filter.
If it is coming out near the air filter or the oil filter, I should suspect a leaking heater or radiator hose.
A pressure tester for the radiator will help you find those leaks.
If it is near the cabin filter, it should be the drain tube for the air conditioner condenser, which is normal to leak when the air conditioning is running.
Try to catch some of the water that is leaking and see which fluid it is.
Air conditioner condensation water is clear, it even looks drinkable.
Anti-freeze/coolant liquid is colored blue, green, red, or yellow, (it depends on the brand) and has a distinct sweet smell and taste. No, I am not recommending you should taste it.
God bless your efforts.
SOURCE: 1995 nissan quest
Have your engine mounts checked. I was experiencing the same type if things, and it turned out all 5 were cracked! (I also have the 1995).
SOURCE: changing water pump on 1994 nissan quest
There is no easy way, water pumps are hard to change on this vehicle. Before starting the job I would buy a repair manual with step by step instructions. To give you some idea on how long it may take, the labor time is 4.5 hours for an experienced tech.
SOURCE: water leak inside the car
Whats causing this is that the drain hose for the evaporator is clogged and overflowing into the car. what has to be done is get under the car and find the drain hose, which is going to be on the passengers side of the car by the firewall, and get either compressed air and blow into the hose to try to free the blockage
SOURCE: I need to replace my Nissan Quest 2007 in cabin micro filter
I'm going to send you exploded view of the glove box and the in cabin micro filter cover illustration. Remove the two upper screws on the glove box and carefully pry metal clips loose.
Disconnect glove box lamp electrical connector. Do not let glove box assembly hang from glove box lamp harness.
Remove three lower screws and remove damper clip from glove box door. Separate glove box housing and passenger instrument lower panel.
Remove three screws and remove in cabin micro filter cover.
Remove in cabin micro filters from front heater and cooling unit assembly.
Note When installing two new in cabin micro filters ensure that the filters are facing in the direction indicated by the direction arrow for the airflow. Direction arrow is printed on side of in cabin micro filters.
Install in cabin micro filter cover. Reinstall glove box.
Testimonial: "Finaly I found the air flow door with three screws and removed it. The filter will need replacement soon. It is been replaced one time at the dealer."
SOURCE: firing order diagram neededbfor 95 nissan quest
For the 1995 Nissan Quest 3.0L SOHC V6:
Firing Order:
1-2-3-4-5-6
Cylinders:
.......(back)......
1........3........5
2........4........6
.......(front)
Distributor:
....(back)
.......2
3............1
4............6
.......5
...(front)
Let me now if this helped, or if you have additional information or questions. Feel Free to contact me at FixYa.com!
Hi Helen Navas, what kind of water, and which filter are you talking about ?
