Question about Sony KP-46WT500 46" Rear Projection HDTV-Ready Television
Trouble Turning On
When power button (or remote power on) is pressed the TV does not come on. The red "Standby" light flashes in cycles of 9 repeatedly. Up until today if we continued to press the "on" button eventually the TV would come on and the picture was normal. Today I have yet to get the TV turned on.
Posted by ffdlk on
  • 6 more comments
  • ffdlk Nov 15, 2007
    Believe it to be a "tube" projection as it has three large what look like tubes projecting against the mirror inside.
  • Anonymous Nov 24, 2007
    exact same let me know what the fix is
  • vasilios Nov 24, 2007
    made a crackle and turned off for good
  • Anonymous Dec 10, 2007
    Blinking red light ... nio picture
  • Anonymous Dec 18, 2007
    I have the same problem it blinks 9 times repeatedly and only way to stop the blinking is to remove power cord.I have no clue what could be the problem.
  • Fiona Doyle Jun 23, 2008
    I have the same problem with mine. Only difference is I believe my TV is a 52 inch not a 46. Its a rear projection not LCD projection. LED standby light blinks 9 times. No sound no picture. No clicks of any type.
    Same problem with mine. Will not turn on. Standby light blinks 9 times. No picture, no sound, no clicks of any type.
  • mmdlchld Aug 10, 2008
    I have had the same problem with my SOny HDTV KDP51WS550. Can anyone please provide me any suggestions for repair?
    Thanks, Marcos.
Vista Electronics
    Genius:
  • 1,694 Answers
Repeat LED blink = bad HV block....Part # 8-598-955-32.....
..........................Let me know ASAP...................T.
Posted on Dec 06, 2007
Anonymous
    Sergeant:
    Champion:
  • 375 Answers
Is this a lcd projection or just tube projection
Posted on Nov 15, 2007
The sky remote will not operate the volume on my grundig gu22dvd have tried all the usual things codes etc but still doesnt work
Try an auto search with the remote, you might have already tried it :
1. press tv
2. press select and the red button simultaneously untill the LED light flashes twice
3. Then keep pressing the TV and Standby buttons one after the other (not at same time) until the tv swithches off, then press select to store the code, the LED should flash twice to confirm this.
Once you have the remote working the TV, you can get the remote blink back the TV code so you can write it down for future reference.
  • Press the TV button on the Sky remote
  • Hold down Select and the Red buttons together for approximately two seconds until the LED blinks twice
  • Key in 9, 9, 0
  • Key in 1 on the numeric keypad and count the number of times the Red LED blinks. This is the 1st digit.
  • Repeat for 2 and 3
  • Note: no Blink = 0 (zero)
Sep 09, 2014 | Grundig GU22DVDPX 22 in. LCD TV
Have grundig gu22dvd tv and can not get volume on the sky remote have tried the normal things and have code but still doesn't work
1. press tv
  • Key in 9, 9, 0
KDL-40W2000 Startup Problem
Replace the card reader board and the problem is solved.
Jan 25, 2014 | Televison & Video
When turning on tv. screen will display Bravia image & then go blank. red light flashes SIX times
Power off the television. Wait a few minutes, then power it back on. If this does not correct the issue leave the power on, point your remote control towards the Sony television and hold the down arrow button. While holding the down arrow button press the "Power" button. Release the down arrow button and the Sony TVicon1.png will reset itself to factory settings. Once the television performs a scan on itself your problem should be gone.
Good Luck Ed Pinero
Read more: How to Troubleshoot the Standby Indicator Flashing on a Sony TV ' eHow.com http://www.ehow.com/how_5925008_troubleshoot-indicator-flashing-sony-tv.html#ixzz2KBk1cWbu
Feb 02, 2013 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
TV doesn't turn on
I have a Mintek DTV265 which is almost the same TV the red light don't blink it stays on as long as the Power button is on. Try turning on the TV by pressing any of the buttons on the side of the TV Channel up or down, Volume up or down , or source. If it comes on then your TV is alright. I had one of them jumbo universal remote controls and it actually had a code that worked on my TV.
Mar 02, 2010 | Initial DTV372 37 in. HD-Ready LCD TV/DVD...
Press the on/off button on remote or on the tv itself, the standby light flashes 9 times , goe out and cycles again for 9 times . TV will not turn on .
Power board or power supply is bad. Call sony @ 1-877-619-7669 They can help with parts or find you a local service shop. Hope this helps
Nov 10, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
STANDBY LIGH BLINKING 9 times...
I have a Sony SRS BBE Trinitron (WEGA). The last few days when I tried to turn it on using the remote the Red Light would go on but the TV did not turn on. I would have to press the power button again to turn it on.. I tought the remote battery was just low.
Today when I tried to turn it on nothing is happening and the Red Light is blinking 9 times ??? I tried to unplug it and try it again, still does the same thing ???
We need help...
Lori Nall
Jun 19, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I want to find the Sky remote code for this Tv.
Just got an LG 42LH2000 and code 0206 works
May 16, 2009 | LG Televison & Video
How do i key in code for digibox
TO PROGRAM THE remote USING THE 3 DIGIT CODE:
1. Turn on the TV receiver
2. Press TV on the Sky Remote Control
3. Hold down SELECT and the RED buttons together for approximately two seconds, until the RED LED on the Sky remote blinks twice.
4. Enter three digit code from list for the receiver (early versions now flash twice).
5. Press select to enter code structure (the LED will flash twice if a valid code has been entered).
6. Now press the STDBY button and test other functions.
Repeat if necessary until a code is found that works most common functions.
TO PROGRAM THE remote USING THE 4 DIGIT CODE:
1. Turn your TV on.
2. Press tv on your Sky remote control.
3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
4. Press tv on your Sky remote control again.
5. Key in the four digit code for your brand of TV. The light on the Sky remote control blinks twice. If the light blinks once only, recheck the code for your brand of TV and start again at Step 1.
6. Press the standby button on your Sky remote control. If your TV switches off, press select. The light on the Sky remote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code).
If at this point the LED on the Sky remote control blinks three times then all possible codes for that make of receiver have been checked. Repeat from step one, ensuring that you enter the correct manufacturer code.
At the end of the sequence, if you see the TV Guide screen, the remote control setup process is complete. If you did not see the TV Guide screen, you must now complete the following steps.
8. Press tv on your Sky remote control.
9. Hold down select and the green button together for about two seconds, until the red light on the Sky remote control blinks twice.
10. Key in the number of the channel on your TV that you use for watching satellite TV.
11. Press select on your Sky remote control. The red light blinks twice. The remote control setup process is complete.
If after trying this, you still have problems, call your broadcaster's help desk. For your broadcaster's help desk number, select the Telephone Numbers option from the Services screen.
Dec 19, 2008 | Computers & Internet
TV not turning on.
Mine was doing that and I ordered a replacement power supply board for it and now it work. It's fairly easy to replace.
http://www.partstore.com/GetModel.aspx?MfgName=Royal+Philips+Electronics&BrandName=Philips&ModelNumber=37PF7320A37&page=16
Mar 14, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Sony KP-46WT500 46" Rear Projection HDTV-Ready Television Logo
125 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
