Question about Target Portable Masonry Saw PS1455 Horsepower: 5 1/2. Blade Guard Capacity: 14
Schematic diagram of motor dual voltage connections
Electrical schematic diagram of dual voltage for used with target power pack masonry saw
Posted by RICHARD LEONARD on
1 Related Answer
Anonymous
  • 33 Answers
SOURCE: need a wiring schematic for a dual voltage masonry
http://us.husqvarnacp.com/
drop down menu "service"
click "service literature"
click "old target, dimas, partner literature"
enter model number
pdf has basic wiring diagram page 4 or so
Posted on Dec 14, 2009
Testimonial: "ty this should help"
This is not a question about a dryer! I have a Sears 10 inch Radial Arm Saw. How do I switch the motor from 220 volts to 110??
If the motor is a dual voltage type the instructions might be printed inside the motor cover or alternatively in the saw handbook.
It is important to find the correct instructions and to follow them exactly.
Dec 23, 2016 | Dryers
How do i fix a 5" grinder?
The motor brushes could be bound up in their holders or worn out. Another possibility is the power switch is worn out or packed with dust not letting the contacts in the switch come together.
Sep 06, 2014 | Makita Angle Grinder 4.5" 9524NBX
Need wiring diagram for 230 v for delta table saw cat. #36-451
Is the motor designed for dual voltages? The manual does not have a wiring diagram. I assume the motor lable diagram is faded or missing.
Dual voltage motors contain two sets of winding. Each set is rated for the lower voltage. To operate the motor on the higher voltage the windings must be connected in series. AND, they must be connected in the same direction. I use a variac to apply 30-40 VAC to the coils in various combinations, then measure the open lead voltage to determine the proper connections. This test should be performed by a licensed electrician.
Dec 05, 2013 | Delta Saws
14 in. saw with leeson motor
To start with what size circut are you trying to run the saw on? What ever the amperage is on the saw will draw almost 3 Xs the amperage rating of the saw on start up. If the circut is a 20 amp the breaker should hold long enough to start the saw. Also the saw should be the only thing running on the circut at the time. A 1-1/2 hp motor is a good size one aproximately 15.2 amps If you circut breaker is twenty amps and you still pop the breaker you may want to convert the motor to run on 220 volts as that will drop the load to approx. 7.6 amps Youcan run the saw on a 20 amp. 220 volt circut with no problem unless there is a problem with the motor. If the outlet is the only outlet on the circut it is an easy change to convert the circut.
Mar 02, 2013 | Target Portable Masonry Saw PS1411S...
Ryobi 10 in Mitre saw with laser, switch / motor wiring diagram?
capacitors are known as capacitors or condensers. Both do the same job of storing electrical energy and then releasing it when the current flows back . They are used to either start an electric motor or stop arcing on the brushes by absorbing the current flow as it stops over each commuter bar of the armature
Dec 02, 2012 | Ryobi 10 In Miter Saw With Laser
Need wiring diagram for a marathon 1/2 hp electric motor 220 to 115volt
HAVE POWER TURNED OFF AND LOCKED OUT. If the motor is a dual voltage motor it should have a wiring diagram on the motor. Check on the name plate of the motor. You should see a high and low voltage diagram. Follow the low voltage numbering. The widings need reconfigured to operate at a different voltage. Hope this helps you...Jim
Feb 12, 2011 | Craftsman Saws
I need a multi 110/230 volt wiring diagram for a baldor non reversible motor
http://www.baldor.com/support/literature_load.asp?ManNumber=MN1240
You didn't give a model,here's a manual on their motors and the wiring diagrams,they start on page 2-9.It should get you there,or you can check out their other manuals on the same page .Take care!
Jan 13, 2010 | Target Portable Masonry Saw PS1411S...
Need a wiring schematic for a dual voltage masonry saw motor. it s a baldor motor on a target saw
enter model number
Dec 12, 2009 | Target Portable Masonry Saw PS1411S...
Coleman air compressor
Should be an electrical diagram on the motor. The motor name plate should also indicate if it is a dual voltage motor. There should be a cover on the end of the motor to access the terminals.
Aug 30, 2008 | Hitachi EC12 Portable Electric 2hp Air...
Target Portable Masonry Saw PS1455 Horsepower: 5 1/2. Blade Guard Capacity: 14 Logo
168 people viewed this question
Top Target Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Target Saw Expert? Answer questions, earn points and help others
