Question about Generac Generator 15000 Watt 15kw
Why is there no output?
Has less than 150 hours although 11 years old. Motor runs great propane but shuts off every 15-18 seconds. Checked murphy switches oil & temp and they are fine. Notice generator is not putting out any current during run times. Unit is on my shop bench with outer case removed but still functional. Starts right up every time. We live rural on a ranch
Posted by Craig Hayes on
  • Pontio Pilato
    Pontio Pilato Sep 13, 2015
    Hi Craig Hayes, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
  • Craig Hayes
    Craig Hayes Sep 13, 2015
    Thank's Pontio. When engine runs and I run a 12 volt power lead to the generator it produces about 30 volts AC. Unit sits unused for extended periods of time. It may only get used once to a dozen times a year depending on weather. If there are any specific questions you might have I will do my best to answer them. We are expecting a severe winter and I am trying to get this online before that.
Generator Guru
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 49 Answers
You need to determine if it is a Brushed or Brushless generator and follow the tests on the link below. (You will locate the brushes on the end of the alternator in a 12o'clock position if they are fitted).
http://www.generatorguru.com/help-me-fix-my-generator-repair-advice/
Then contact Generator Guru with the results and they will let you know what needs replacing. This is a free service.
Posted on Sep 25, 2015
5 Related Answers
protek480
Craig Butler
  • 1730 Answers
SOURCE: unit shuts down from overspeed fault
The engine throttle control is out of adjustment. It needs to be set based on the generator frequency
(60 Hz).
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jun 27, 2009
RSG000
  • 26 Answers
SOURCE: Generac 4456 does not start on power loss
I install and work on these everyday. If you hooked up the transfer switch you probable have a control wire wrong. check the utility power sense wire. That lets it no when to start in auto. it could be a relay or fuses. or a control board.
Posted on Jul 09, 2009
protek480
Craig Butler
  • 1730 Answers
SOURCE: The generator starts up runs for about 15 seconds and shuts down.
Check the oil pressure switch
Posted on Aug 21, 2009
Anonymous
  • 27 Answers
SOURCE: Suddenly in power outage and engine starts auto., NO inside power
DO U HAV POWER FROM GEN ?
Posted on Sep 04, 2009
Testimonial: "Thank you for taking the time to respond. Much appreciated."
Anonymous
  • 142 Answers
SOURCE: I have an older model Niagara 4kw by generac with
I have not seen yor generator in practice, but saw some pictures of it.
As it is an older model, but it is not rare for modern generators too, when they stay a lot of time (3 years is a good lot of time), they lose thier magnetism.
In order to build the magnetic field up again you can connect for a short time (1 - 3 seconds) by a working motor, a 12 V battery to the field terminals, + and - respected. A series diode 10 - 25A to battery can stop the built up field voltage to overcharge the battery.
Posted on Aug 01, 2010
Testimonial: "Thank you for the prompt reply - it seems to make sense and I'll try it."
Atwood g6a-be lights but goes out in 3-4 min.
mine is pretty new about a 1year in halve to two years old. i light with lighter it lights burns great then acts like propane cutts out then burns low then cuts out kinda acts like propane pressure cuts out in the valve but i can relight 30seconds later same thing. i have checked stove it burns great. is it in the waterheater propane valve. need help pease i need a cheap fix layed off right now. thank you dave
Sep 20, 2012 | RTO Atwood Water Heater - 6 Gal LP
Tip
Make your Lithium Laptop Battery last longer.
Hello folks,
Although I usually offer advice on backing up files or recovering them, I have been asked a lot lately how my 3 year old laptop still runs 1:45mins on a standard battery when many peoples 1-2 year old laptops can barely last an hour.
Simply put, most people do one of two things wrong. Both are common misconceptions and easy to remedy. First I've heard countless people tell me they pop the battery out of their laptop and toss it in the desk drawer until needed, often months. Second I have been told by more people than I can count that they leave their laptop plugged in 24/7 for most of the year.
Bottom line, although popping it out and leaving it in the drawer is less harmful to it's lifespan, both ideas are wrong.
The shelf life of most unused lithium batteries is shorter when unused than ones being used properly. The lifespan of a battery that is constantly being trickle charged is even shorter.
Most batteries in modern laptops are 4-6 cells, designed to give about 2 hours of charge and should last 3-5 years with charge life starting to degrade in the third year.
A "stored battery" has only 3 years of shelf life due to extended times sitting discharged and one that is trickle charged 24/7 may burn out in as little as a year.
Many laptop manufacturers have taken measures to improve this but ultimately the best thing for your battery is to use it. If you currently run you laptop plugged in 24/7, unplug it every night after you shut it off, then when you start it in the morning, let it run an hour before plugging it back in. This will give the battery both down time and exercise.
If your battery is in a drawer somewhere for safe keeping, put it back in the laptop, run it down then charge it over night and run it down then recharge it one more time. Store it back in the drawer charged and repeat the cycle at least once a month.
These tips will help drastically improve you batteries performance over time. My 3 year old laptop only ever got 2 hours of battery life and still gets 1:45 with no power saving measures, give it a try.
Crankstart
on Mar 20, 2010 | Computers & Internet
Dell inspiron said battery low plug into charger, when plugged in charger light goes out and laptop will not power on, why?
Remove the main battery from the laptop and try power, if it works the battery is bad, if no change the charger needs to be checked for proper voltage. Since your laptop is less than a year old you should have warranty for up to the year, check this asp and find your paperwork should verify.
Mar 24, 2012 | Dell Inspiron N5030 Notebook PC
It starts and heats up after 20 minutes cuts off and makes sound like it wants to start. then shuts off completely and starts back in about an hour for 20 minutes and cuts off.
You have a bad motor there is a safety feature built into the motor to where when it gets hot it will shut off so it wont start a fire. After the motor cools off in the time frame you listed it will come back on but repeat the same thing all you can do is have the motor replaced by a qualified service technician or buy a quality used machine or a new one if the dryer is 10 to 15 years old not worth putting a motor in it will run $125 to $150 for just a new motor but sorry for the troubles.
Jan 05, 2011 | Dryers
Grill is 6 years old, was running great, put new gas tank on line and ran it for an hour only to get to 130 degrees
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
You problem could be or probably is with the regulator...not enough gas pressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Aug 30, 2010 | Weber Genesis Silver C Grill
I have a Fujitsu 42'' PDS4221 - 10 years old - shuts itself off
See Fixya tips and tricks:-
'Fujitsu Plasma 42" random shutdown - continuous flashing red'
While the model of your set is slightly different, the checks described generally still apply, as it is very similar.
Nov 18, 2009 | Cars & Trucks
Starter/solenoid prob?
Replace the MAF sensor. The starter is overheating due to cranking excessively. It has noyhing to do with the engine staying running. The MAF sensor is located as the first sensor out of air cleaner. It controls the fuel. Good luck and have a safe trip.
Jun 18, 2009 | 1993 Ford Explorer Limited
Kenmore Dryer Model 66801692
at leas 15 yrs old??? think it's done its time, its a great machine andwould reccomend replacing with a whirlpool/kenmore unit again.no tworth servicing in my opinion, average call here in new york 150-225, anbd those are for simple issues. id rather put money into new unit! bit be sure to check your venting id say 85% of dryers taking too long to dry are vent related issues
Nov 13, 2008 | Kenmore 62872 Electric Dryer
Inefficient (big, yellow flame) on wall propane heater, using up propane too fast
A clue to what could be wrong is that you mentioned it took 10 minutes for the pilot to go out. It could be your gas valve. Get a technician in to check your gas pressure both before the gas valve and after. Have them check it as the water heater is running.
May 15, 2008 | Dayton Heating & Cooling
Frequent interruptions of washer
This is most likely the brushes on the motor. Intermittently failing due to wear and tear. I *could* be the motor but the brushes are very cheap in comparison.
On most washers the brushes are < £20. Time to fit is less than 0.5 hours.
You have three options
1/ If you are or know someone who is very technical and confident - once you have the right parts should be able to install them. (Unlplug the unit before touching!!!)
2/ If you have a service contract use it, they should provide parts and fix.
3/ A service engineer is your last option - say £90 callout + parts. (On certain washer units parts are free up to five years old - but you have to pay the call out fee)
Please dont forget to rate me, thanks!!
Mar 17, 2008 | Washing Machines
Generac Generator 15000 Watt 15kw Logo
91 people viewed this question
Top Generac Electrical Supplies Experts
Bill Johnson
Fahr Quad
JOHN LAPIER
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
