Question about Dishwashers
Hi, my dishwasher is stuck draining and issuing the three beeps 'anti-flood' error with no sign of a leak? Is it possible to re set this?
Electrolux realife XXL Model ESL 7220RO
Posted by Pete Harman on
rostit
  • 746 Answers
You need to remove the bottom plate and clean up any water. it most likely means there is a leak in the gasket around the door and it tripped the flood sensor. the only way to reset it, is to deal with any water and dry it up and then power down and power up the washer.
More importantly I would look for leaks. Bad hoses or possible rubber that dried out and cracked. Maybe someone spilled water and it got on the sensor too. Either way , water is what causes that sensor to activate.
Posted on Sep 02, 2015
Testimonial: "Removed plinth from under the units, removed bottom plate and found some water. Cleaned it up, cleaned out filters, ran and checked for leaks and now all seems fine :)"
  • rostit Sep 02, 2015
    Fantastic! Im glad to hear it. Thanks for the helpful vote!
Hi wont start. just making a loud whiring noise.
According to your description of the fault, something was blocking drain turbine of main motor. Dishwashers always first start drain water because calibration of water level inside dishwasher (empty). In your case, the main motor is same motor for washing and draining. Runing in one direction means washing, runing to oposite side means draining.
The solution is to open a turbine pump and remove all obstacles and visual check turbine impeller,ceramic seal and plastic sleeve on the motor shaft.
Dado
Mar 26, 2015 | Electrolux Dishwashers
Electrolux dishwasher esl 6114 door does not lock
Hi Peter Gumbrell - Often when the dishwasher door does not lock, it is because the of door lock assembly. The door lock or latch may either be faulty or damaged. If I was in your position, I would personally recommend consulting a professional to accurately diagnose the dishwasher to determine the root cause to reduce the risk of unnecessary parts.
Mar 20, 2013 | Electrolux Dishwashers
What does the shower and bar smybol mean on my ESL 63010 Dishwasher please?
I've been dealing w/electrolux for over 2 years on a dishwasher problem. Technician have tried all that they know & the dishes still come out dirtier than when they go in. I've been using it as a drying rack. Kinda exspesive drying rack. Electrolux won't stand behind their product either.They are offering me a 60% discount on a new Elextrolux dishwasher! Are they kidding?
Apr 01, 2011 | Electrolux Dishwashers
Hi, I have an Electrolux ESL 4115. It seems to be stuck on 50 degrees but wont start as usual when I close the door, the on/off button works and lights functioning as normal but that's all. Thanks
I had a similar problem - seemingly stuck or locked with a solid light showing (in my case on the 65 degree wash). Nothing seemed to unlock it. But when I closed it and went away to think about what to do next - some 5 minutes later - it made its end-of-cycle peeps. It now works fine. All I can think of is that I must have interrupted the previous wash cycle l was using before it had ended, and had left the door ajar. all it needed was the door closing for the cycle to finish. Does that help?
Sep 22, 2010 | Electrolux 24 in. ESI6220X Free-standing...
It fills with water and then continues to wash but the water does not heat up.the program does not progress.electrolux esl 6114.
Problem is either a bad controller board or bad heating element.
You will need to know how to diagnostic service work using a volt-ohm meter, and be mechanically handy if you want to diagnose and repair.
Dec 11, 2009 | Electrolux Dishwashers
Electrolux ESL 6225
before you operate the dishwasher get your water as hot at the sink as you can this will prevent filling the dish washer with cold water and i would use powder or liquid now if you not sure of your heating element turn your washer to dry close the door for about 2-3 minutes get a glass of cold water open the door and pour water on the element if it sizzles its working
Feb 12, 2008 | Electrolux 23 in. ESL624 Built-in...
Dishwashers Logo
Top Dishwashers Experts
Michael Thomas
Michael Thomas
