Canon EOS 400D / Rebel XTi Digital Camera Logo
Heather Friedland Posted on Sep 02, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Canon Digital Rebel XTi camera - sometimes USB wire doesn't register when it's plugged into camera and computer at the same time
Willie Mondo
Level 2:
Sergeant:
  • Expert 313 Answers
  • Posted on Nov 02, 2015
Willie Mondo
Expert
Level 2:
Sergeant:
Answers
313
Questions
Helped
64961
Points
704
  1. Use the cable that was supplied with the camera or find a replacement - compatible with your camera brand.
  2. If you load too much in the card, computer memory full or slowed down by too many background application, it may take sometime for the computer to read the card.
  3. teddyboy's answer above is another probable cause.
Paul Green
Level 2:
Prodigy:
An expert who has answered 500 questions.
  • Canon Expert 527 Answers
  • Posted on Sep 02, 2015
 Paul Green
Canon Expert
Level 2:
Prodigy:
Answers
527
Questions
Helped
232937
Points
686
Probably a bit of wear & tear on the mini usb socket in the camera.. Put the card in a card reader on the computer just to check it's not the computer
1helpful
Does Canon EOS Digital Rebel XTi 400D Black 10.1MP DSLR Camera work with Vista
You should not have any problems.
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then removethe memory card from the camera and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB Mass Storage Device oran external storage device; you can then open the folder on the memory card andcopy the photos to your computer.Memory card reader is a handy device and is inexpensive. Youcan copy photos from other cameras and you can also download photos off yourmemory card to someone else's computer without the need of installing anyprograms.
Computer does not recognize my canon eos rebel xti 400D
You can download the driver aand reinstall it from this link: http://www.nodevice.com/driver/EOS_400D/get37008.html Make sure your existing Canon software, if any, is removed before installing the new driver. If this doesn't work you can always purchase a card reader and extract your photos directly from the memory card.
EOS 400D / Rebel XTi Digital Camera with 18-55mm Lens: went on a trip to europe. took lots of pics and we...
1. There are hundreds and hundreds of programs that can restore lost files from a formatted drive... just google it
2. You cannot use a usb cable to transfer files (or at least not on my computer) with this camera, you have to take the card out of the camera and directly plug it into your computer
Hope I helped
1helpful
Canon Rebel XTi not recognized when plugged into usb
Vista is your problem. Solution...buy an inexpensive card reader to download your pics to a folder you create on your desktop. From there, you can send the pics to your photo editing software.
Cannot get pictures of my Cannon Rebel XTI camera
Do you have a USB card reader? You can pick these up cheaply, and it is quicker and easier to take the memory card out of the canon and read it with the card reader.
Busy signal when trying to import images to my pc
I have had the same problem with getting a busy signal after plugging in the USB cord. Usually turning it on and off a few times, giving it a few seconds in between, works for me.
Also, have you tried just going into My Computer and clicking on the drive for the USB you've got you're camera plugged into and transferring the photos onto your pc from there? They only go onto your pc, not into a program but you can get them into one from there.
EOS Utility does not recoganize Canon Rebel Xti
I believe there are 2 modes of usb transfer that you can pick in the camera. They are set somewhere in the menu in the options. If you go through the menus thoroughly you'll find it. One option is for connecting the camera directly to a printer and the other is for computer transfer (there might also be an Auto setting but I don't remember for sure). Make sure that setting is set for computer transfer. If that doesn't fix your problem, re-install or update EOS Utility / ZoomBrowser.
1helpful
EOS Utility does not Recoganize Camera
I am not sure about this matter but it seems there is a problem with your new computer. it might not recognize the usb cable.
try to plug your camera in another USB port and try again.
CAMERA WILL NOT DOWNLOAD IMAGES
Have you tried replacing the USB cord? You also might want to try getting an inexpensive CF card reader so you can remove the memory card from the camera and then just plug the both of them into your computer's USB slot and upload from there.
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
