Question about Teac AG-V8060 Receiver
Why does my Teac receiver only light up the volume, then shut back off?
I turn the power on and the volume light lights up, then the power goes back off.
Posted by Mcdirty42069... on
richie46
    Top Expert:
  • Teac Master
  • 12,962 Answers
Your receiver has developed an internal short circuit and the unit is shutting down to prevent further damage. You might want to check the power supply for problems since it is a hard working area and prone to failure.
Posted on Sep 02, 2015
Why does my Teac receiver only light up the volume knob, then shut right back off?
hi sounds like a fault in youre power supply circuit or there is a fault elsewhere causing the power supply to shut down .....u might need expert help .....good luck
Teac AG-V8060 Receiver No sound. If I turn up the volume all the way I get a whisper of sound from the speakers.
NEVER USE MAXIMUM VOLUME FOR TROUBLESHOOTING.
Turn the volume control to something medium.
The errant switch, control or condition may change and you will suddenly release the amp's full power and possibly destroying your speakers. If a signal isn't audible at 1/2 volume it's probably not there.
Carefully examine the front panel for clues like a misplaced Mute or Tape Monitor control or Multichannel Analog Input selected.
There is a good chance that a common control may have developed a high-resistance or 'dead' spot through defect or idleness and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
Turn the volume to something reasonable and see if that helped.
2answers
Teac ag-d9100 center and surround speakers are not working , very very low volume.. the others all work fine. Anybody know where to start troubleshooting. Its not a fuse that I can see , at least that i...
You have to enable them and turn the volume on them up separately with the speaker config, level trim, and up/down select buttons on the remote. You can also adjust the rear speaker delay time or just hit the test tone button and adjust the volume on each speaker separately as it goes through them one at a time...
Receiver will click off
check your power supply to make sure the correct amps and volts are there. check your speakers to verify the correct ohms for the receiver. if the ohms are to big you will shut down because it overdraws on the receiver.
My 605 turns off and red light blinks when volume goes past 58
Shorted speakers can cause the unit going on protection mode (the red light blinking) when a certain volume is reached.
Test with a set of replacement speakers.
If it is not the speakers, it is probably transistors in the amp final or something nearby. Test also input output board.
Teac AG V7700 Receiver problem powering up
I have a Teac ag-7700 and when I would try to power it on it would shut off. I did get it to turn on for about 10 minutes and then it shut off. Now when I try to power it on the light on volume dial stays lit but the LED does not light up and no sound through speakers.
3answers
Onkyo HT-R501 7.1 reciever issues
i have the same problem with a onkyo tx ds494
Kenwood KDC-MP228
Your ground is weak or your running your radio at low voltage. Good Luck
1helpful
Protect
You may have shorted the speaker wires. Remove all wires from the output connections and make doubly sure no strands are left there. Turn volume to zero and turn the receiver on. If the problem persists, you probably fried the output stage. Have it repaired.
Teac AG-V8060 Receiver Logo
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
 Francisco Mauricio...
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
