Question about LG WM-2277HW Front Load Washer
How do i unclog the drain filter? - LG WM-2277HW Front Load Washer
Posted by sandi welch on
My vax rapid carpet cleaner no suction filter is fine
If the vacuum is still functioning, the hose is most likely clogged. Disassemble the vax and unclog. Make sure you drain before disassembling. If possible do this outside.
May 16, 2016 | Filter Vacuums
I have wm1814cw lg front loader washing machine with oe light on and not draining we have clean filter unclogged drain hose and reset by unplugging and holding down power putton and start button als
The OE error or fault code indicates that the washing machine is not draining properly. Check to be sure the drain hose isn't clogged or kinked. If that checks out, check to see if the drain pump or drain pump filter are clogged. Sometimes objects that are put into the washing machine, for example combs, money, hair pins, etc. end up in the filter. Finally, if the drain line is clear and the pump seems to be clear and functioning properly, you may need to replace the drain pump assembly.
Sep 16, 2014 | LG Washing Machines
How do you unclog washer drain
Hey friend, thanks for your inquiry!
I understand that you would to unclog your drain on your Frigidaire washer. I would recommend having a professional come out to unclog your drain because this would acquire some disassembly of your washer. These intricate parts do require precision and patience and I would suggest having a technician come out to avoid any potential harm. -Matt
Aug 22, 2014 | Frigidaire Washing Machines
Unclog a/c drain on mitsubishi ductless mr. slim
you should have a drain on the outside of the house take a shop vac and suck this drain line out, Make sure your filter is clean.
Jul 15, 2014 | Mitsubishi MS-A12WA & MU-A12WA Mr. Slim...
Washing machine won't drain, filled with water
You need to remove the hose prior to filter. Make sure machine is turned off & unplugged, be careful not to splash washer on any electrical components.
Dec 18, 2013 | Kenmore HE2 Plus Front Load Washer
Washer doesn't spin drain
remove the drain hose at the back of the washer and check that the filter is not blocked.
Feb 24, 2012 | GE Washing Machines
Our dishwasher isn't draining
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 04, 2011 | Kenmore Dishwashers
My washer will not drain the water and the spin-Model ATF6000FS1
I had the same problem but bought a new washer. As we were parting this washer out we found that there is a black rubber boot the attaches to the water pump. There is a filter inside of this boot and it was clogged with hair, string, and almost 2 bucks in change. No wonder it wouldnt drain. Check yours and see if thats your problem too!
Oct 05, 2009 | Frigidaire ATF6000ES Front Load Washer
The spin cycle will not work. I think the drain is clogged and would like to figure out how to unclog the drain
If you unscrew the bottom front kick plate there is a black rubber piece to the right in front. In order to get to the filter make sure the washer has no water in it or it will spill all over the floor. The black rubber piece houses the filter. You need a phillips screwdriver to unscrew the clamp at the top of the black rubber piece. Once that is unscrewed you can pull it down and you'll see a white plastic filter inside. It is most likely clogged so it won't drain. When it is cleared it will work again. It is pretty easy but can be messy if there is water still in the drum. Just make sure that you put the rubber gasket back on with the clamp tightened.
May 02, 2009 | General Electric WSSH300G Front Load...
Samsung fridge filter leaking
HI,
your drain is clogged.you may have a catch for your drain where you see leak coming from.that may pull off and you can see if their is trash build up in it.you are going to need to take the panel off the back of freezer.inside back of freezer you will see screws.they will need to come out,if you have ice maker that will need to be removed also.once back panel is off you will see your coils,beneath the coils it will most likely have a sheet of ice.tturn machine off and take a hair dryer and defrost the ice.once ice is gone take a cup of hot water and run thru drain to see if unclogged.repeat if drain is not clear.the ice in drain tube will eventually unclog.I use a steamer.much quicker.
thanks,
Mar 22, 2009 | Samsung Refrigerators
LG WM-2277HW Front Load Washer Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Michael Thomas
Michael Thomas
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
