Car Audio & Video Logo
Question about Jensen Car Audio & Video
I have a Jensen RV AM/FMCD,DVD Stereo and my granddaughter stuck two disk in and I can't get either to eject. Any ideas?
richie46
    Top Expert:
  • Jensen Master
  • 12,962 Answers
Yup - they are stuck in there good. You need to remove the cover and get inside to remove the disk(s).
Posted on Sep 02, 2015
1helpful
I have the Jensen 5000 media pro / 5000 installed in our RV. It has the stereo and plays DVD's . Well I ordered a replacement universal remote. Shortly after orthotic the remote control to use, our DV
That was an EXCELLENT video with clear speech and a lovely voice. I would be happy to help as much as I can....First of all, the remote control has nothing to do with the sound pulsating in the DVD. May I suggest that either or one of these is the problem: the disks or the internal pickup of the machine need to be cleaned. Please get a cleaning kit from your favorite electronics store. Keep fingers off the playing surfaces of the disks and protect them rom scratches.
Jan 14, 2013 • Cameras
Have a Jensen UV8 That will not eject the disk any ideas?
Yes, I have a Jenson UV8 that not eject the disk any ideas?<!-- from fixya rte -->
My clarion CD player in my Nissan Primera P12 2004 will not eject the discs can this be rectified and would it be expensive.
Hi.
Check first that it is not a single disk stuck inside.
Try pressing repeatedly the eject button on the on dash player while at the same time you start the stereo.
If that does not work you can try disconnecting the car battery to reset the unit, and then attempt again the procedure above.
Remember that you may be asked stereo code after disconnecting battery, have it ready.
If still no luck, then the unit must be removed from the dash to be taken apart, so to remove the stuck disk.
In that case the repair may require replacement of CD drive unit or front panel. When disk does not exject repair done from a local technician may be expensive. Usually better replacing the whole stereo unit.
Regards.
PS: Here the procedure above illustrated in detail. The procedure is described for home DVD players, but it is the same on any optical unit, including in-dash stereo. Naturally , since the unit is an in-car system, you do not have power cord, but you will need to disconnect battery to reset the system: player system won't eject disk.
2helpful
CD does not eject from my VM 9410 Car DVD Player
it probably got jammed in there what you can do is unplug the power source and replug it back in a brief power push should eject the disk. make sure you have your unlock codes as the unit may think it got stolen if you undo the power. if that does not work to get it fixed around $89 bucks Thanks and please rate
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
1helpful
DVD will not Eject
answer - had the same issue turned out to be 3 dvds in it, Remove the 4 screws holding the dvd player to the roof. wire harness will hold it up. There is an fm transmitter on top held on by three screws. remove the little screws and push the transmitter to the side. you winn now see the stuck dvds. push the extras out with a small screw driver. once they are out the eject button will eject the last dvd.
just worked for me hope this helps.
1helpful
My uv8 wont eject my disk
I suggest you disassemble the radio and take it out that way. While your in you can check on the blockage. Shouldn' t be hard. Good luck.
1helpful
2answers
Stuck DVD
im not resposible for anything here but try this. stick another disc in only about half way or as far as it will go up to that point. when the loading mechanism in the player sees another disc trying to come in, it pops up to accept the disc. it should spit your stuck disc back at you while holding the new disc in your hand.
Can you help? Stereo does not take in any discs
I think you have a mechanical problem with the load and eject mechanism. Either a spring or a gear has popped out of place or may be a switch got stuck and malfunction. If you are mechanical incline just open the unit up and look for anything that look out of place, becareful and remember what goes where so you can put it back in order. That is how I fix mechanical problem. Good luck.
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
