Question about ULINE U Line 3000 Series 3018CLRS41 20" Built-in Undercounter Ice Maker with 30 lbs. Ice Storage, 60 lbs. Daily Ice Production, Frost Free, Clean Indicator Alert and Drain Required: Stainless Steel, Left Hinge with Pump
Why does freezer get condensation on bottom that drips onto bottom of refrigerator?
Posted by Brian Bauknecht on
  • Brian Bauknecht
    Brian Bauknecht Sep 01, 2015
    not a ice maker, it is a compact refrigerator with small freezer
Tom Chichester
    Top Expert:
  • ULINE Master
  • 57,296 Answers
The condensate drain tube may be clogged.
Posted on Sep 01, 2015
Why is condensation in fridge?
Good afternoon friend, thank you for your post!
I understand that your Frigidaire refrigerator has moisture forming underneath the bottom panel of your freezer and that is causing water to drip onto your shelves. Would you be able to provide me with your model number that way I could research additional information for you please? You can locate your serial tag (which lists your model number) on the inside cabinet of the fresh food compartment normally on the left side of a top mount. On a side by side it can be found on the right hand side. I look forward to your response. -Matt
Jul 16, 2014 | Frigidaire Refrigerators
I have a Gibson mode lRM18F6DMGA bottom mini freezer refrigerator that leaks water under the crisper drawers and eventually through the seal onto the floor. There is a ice maker in the freezer but I turned...
Sounds like a clogged drain line. Find the drain and blow or clean out the clog. Drain usually travels from the freezer coil area down to the drip pan, which is usually back bottom.
Apr 15, 2008 | Refrigerators
Water condenses on outside bottom of freezer and drips on floor
I would not remove the bottom and replace the insulation. Where is the unit located in your home?
Nov 02, 2012 | Refrigerators
Excessive "fog" in freezer causing
Check your door gasket. Cleaning the gasket should help it seal again
Nov 27, 2017 | Maytag Refrigerators
My Hotpoint refrigerator drips water some times alittle and some times a lot I'm not sure where it comes from I have cleaned the rubber seal and made sure there is nothing keeping the freezer side from...
In most refrigerators there is a drip pan underneath that captures condensation and allows it to evaporate. Possibly your drip pan is missing or improperly installed so that the condensation is dripping onto the floor. Check your manual, or find one online. Usually you just have to remove the grill from the bottom of the fridge to get access to the drip pan.
Nov 19, 2017 | Hotpoint HSH22IFT Side by Side...
Whirlpool ultraease refrigerator (ED7FHG) making water sounds, and drips water onto steel pan in bottom rear of freezer side. Purchased new. This is an obvious change. Problem?
You have a water leak somewhere (I'm assuming this water sound is constant). If not write me back for other possible solutions.
The only place water comes into the freezer is for an ice maker or a door water dispenser. Check around the ice maker for a leak. If there is a water dispenser in the door then check the piping to it also.
There is a drain in the bottom of the freezer compartment which is there so when the frost is melted by the defrost heaters, it has somewhere to go. This drain drains into the "drip pan" (or condensate pan) in the bottom of the unit. Here the water will sit until it is evaporated into the air.
If this helps you, please select YES to the first two ratings questions. Thank you, and Good Luck.
Oct 13, 2009 | Whirlpool 21.7 cu. ft. Top Freezer...
Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://servicepartstec.blogspot.com/
Jul 01, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water on btm of glass shelves and water in bottom of frig
sounds like you have a gap in the door seal, which results in condensation forming inside unit. Use a blow dryer to heat the seal around the door and ensure that the fit is tight.
Jan 07, 2009 | Kenmore 72073 Top Freezer Refrigerator
Kssp42qhwoo(7 yrs old)
Check and make sure you defrost drain in the freezer isn't frozen. The water may be coming from the bottom of the freezer inside. When the heater comes on to defrost the evaporator, the water drips in to a small hole in the back bottom of the freezer inside. If the drain freezes, the water runs out into the freezer on the bottom and eventually onto the floor in front of the freezer door. It will eventually create a gap and let moisture into the freezer and may show up in the refrigerator section as condensation. Remove the ice build up including the alluminum drain pan area where the drain is located. Pour hot water into the drain to defrost it. You may have to remove the back of the freezer wall on the bottom to get better access. If the water goes down the drain, its clear. If you need a part for your refrigerator, please email me on ebay under user name themackshack. Good luck! , Mack
Jan 06, 2008 | KitchenAid KSSP42QKS Side by Side...
ULINE U Line 3000 Series 3018CLRS41 20" Built-in Undercounter Ice Maker with 30 lbs. Ice Storage, 60 lbs. Daily Ice Production, Frost Free, Clean Indicator Alert and Drain Required: Stainless Steel, Left Hinge with Pump Logo
314 people viewed this question
Top ULINE Kitchen Appliances - Others Experts
Lawrence Oravetz
ray gallant
Tom Chichester
Are you an ULINE Kitchen Appliances - Other Expert? Answer questions, earn points and help others
