Question about Kohler Electrical Supplies
I have a kohler generator model 8.5 RMY need to know the middle wire number on the run/auto off reset switch.
Posted by Frank Berkhouse on
5 Related Answers
CarlGehrke
Carl Gehrke
  • 169 Answers
SOURCE: kohler 12kw generator starts but shuts down after 3sec
Your gas pressure is too low and you may not have a large enough supply pipe. You need at least 10 inches of water column with the engine running to operate an LP vapor fueled engine. Because the engine is starving for fuel, its governor opens the throttle to WOT (so it goes to high revs) but there isn't any fuel to make horsepower with so the output voltage falls and the undervoltage alarm trips.
Carl
Posted on Dec 03, 2008
Joe Hogan
  • 10865 Answers
SOURCE: wiring schematics
Kohler has an entire technical library on their website. Go to Kohler.com and you will find it. good luck
Posted on Jan 21, 2009
rjivaro
  • 158 Answers
SOURCE: electrical wiring for kohler engine
Perhaps you would enjoy the entire service manual. Here it is: http://www.asberry.net/files/TP-2379.pdf
Posted on Apr 29, 2009
Anonymous
I have a Ford LGT with a 14 hp Kohler K321AS engine. Go to Kohler.com and download the service manual for the K321 engine. The manual covers all of the K type engines and gives diagrams and details of all the different types of ignition and electrical systems. It is free. JS
Posted on Jun 07, 2009
protek480
Craig Butler
  • 1730 Answers
SOURCE: I have a Honda generator model EM3500X with auto
The control board that senses load (current) is not working.It should drop to low with no output current. (nothing running)
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jul 07, 2009
Gen runs when switch in auto even though power avail. Tried resetting ATS - waited 30 min. No luck. Only way to turn off is to move switch to stop/reset. Any ideas on what is broken?
have an electrician check the relay that is activated when the utility power fails
that is what starts the genset when it is in auto
it should also stop the get set when utility power comes back on
Nov 03, 2015 | Kohler 17RES 17 kW Generator
Trying to find what oil filter can be used in 14KW Kohler
what is the filter part number on the Generator now? Give that to an Auto parts place and they will cross it to what they sell
May 05, 2015 | Kohler Electrical Supplies
Generator code 0094 01
Can you be more specific? what model Kohler is it, Model number KW etc.
Sep 15, 2013 | Kohler Electrical Supplies
Kohler 12.5 res gen. Battery is good. Get OC code. If I reset auto switch by clicking off, then clicking run, then clicking auto it will start. Any thoughts on this issue?
OC is Over Crank which generally means it cranked and cranked and failed to start. Turning the switch off and on again is the way to clear the fault. How long is it taking to start whilst cranking? It should start within 8 seconds
Sep 11, 2013 | Kohler Electrical Supplies
No 110 ac power out of gem
Check the rotor slip rings for tarnish as it has sat.
If they are clean, the rotor may have lost it's magnetism and may need flashing (putting DC power directly on it for approx 3 seconds) with brush wires disconencted POLARITY IS CRITICAL
Feb 12, 2013 | Kohler 12 kW Emergency Power System -...
Generator starts then shuts off in 8 to 10 seconds it shuts down
Check oil, and sensor, rotor rings, and brushes, then stator rotor for shorts
Aug 18, 2012 | Kohler Electrical Supplies
My gen starts and runs for 1 min or so then dies restarts then dies again and again. if i start it under load ( turn on air con) it will run for 10 min then die allen
Is there a fault?? All UL listed generators including Kohler are required to lockout on a fault on shut down. This really sounds like a problem with your 2-wire auto start connection between your automatic transfer switch and genset. RDT model automatic transfer switch it is the 2 middle wires on the green connector and terminals 3&4 in the generator. close to run and open to shut down. Any open at any time will cause the unit to shut down. The 12 will shut down instantly upon an open because your 5 minute cool down is built into the transfer switch.
Jun 27, 2011 | Kohler 12 kW Emergency Power System -...
Models: KCT, KCP Power Switching device: Standard Open- Transition 30 to 4000 Amps Programmed- Transition 150 to 4000 Amps Electrical Controls: MPAC 1000 Problem: Power went off, generator Started,...
try to find the manual , these units have a pre program set from the factory, dissconect the unit at the generator 1)battery terminal 2)main switch on generator 3) reconnect battery and turn on the switch,press auto,should reset
Jun 09, 2011 | Kohler Electrical Supplies
1975, 7.5 Kohler marine genset, runs only with the reset depresed
Can't search for a manual without model, type, serial, etc numbers...
A few things to take a look at:
1) Oil level / pressure sending unit. This is normally bypassed as long as the start switch is pressed. When engine starts, and switch is released, engine will die if sending unit is defective, or you are low on oil.
2) Exhaust temperature sensors. Older units were notorious for burning these up.
3) Cooling Water Temperature sensor. These cause trouble often, but mostly due to water pump impeller being eaten away by galvanic action and not able to pump water as effecively. End result is water temp higher than normal, which trips the switch, which kills the engine.
4) Alternator (generator) output not as it should. If output doesn't rise to proper level within a few seconds of engine start, the engine will be shut down.
5) Choke not working as it should
6) Bad fuel, bad fuel pump, clogged fuel filter.
May 26, 2010 | Kohler Electrical Supplies
I have a Kohler 12RESM1 propane generator with oc/uu code
U need to make sure that the relay driving ur auto start stay closed all thru the crank cycle.
Feb 04, 2010 | Kohler 12 kW Emergency Power System -...
Electrical Supplies Logo
194 people viewed this question
Top Kohler Electrical Supplies Experts
John Trevino
Tim Venetis
jdthefixer
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
