Hi Bo,
You need to rebuild the carburetor. Here is a 2 part video on how to do this:
https://www.youtube.com/watch?v=HAPFZ5US9uM
Good Luck!
Jim
SOURCE: weedeater featherlite 25cc. runs fine for 10 mins,
I just fixed one of these. Starts, but won't throttle up, sounds labored.
I checked compression, exhaust for carbon build up, spark, and even the carburator for bad gummed up gas. All were fine.
What I did to fix it was...
You need to remove the high and low speed adjustment screws on the Zama carb. They are blanks, and have no slot for a screw driver. I used a roll pin that the inside diameter fit snug on the outer diameter of the ajustment screw head, and turned it with a pair of needle nose pliers. I remove them (One at a time) and cut a slot in the head with a hacksaw, to allow for future adjustment. Back them both out one full turn from seated, and then tweek to get it to run. The low speed is for idle (Out to richen), and the high speed is for wide open throttle. It's closest to the air filter.
SOURCE: I changed primer bulb on weedeater and now it bogs
The trimmer needs a carb adjustment, but the adjustment screws take a special tool only available to dealers. Go to poulan's website to find a service dealer near you.
Testimonial: "you are correct sir, already had it fixed and that was the problem. "
SOURCE: poulan pro weedeater 330 runs but no power. boggs downs when full trigger pull
remove the muffler and try it if ok open the muffler and clean out the carbon from the screen
Testimonial: "yes that worked, but i did not have to remove the muffler.. i just had to take take a small screw driver and and slide the the screen out and clean it and slide it back in. my weed eater is running like new again.. thanks"
SOURCE: echo 225 wont reach full power
have you check to make sure your air cleaner is not due for a clen or rereplacement.
