SOURCE: vANITY mirror bulb replacement
there is a plastic ring on most models surroung mirror,wich should just clip off using a blunt knife,allowing you to remove mirror and replace bulbs,but some models are non replacable.hope this helps
SOURCE: how to change a headlight light bulb on toyota prius 2006?
they are usually changed from inside the engine compartment. you should be able to gain access to the bulb behind each headlight bazel. the socket often has to be turned to remove it. be careful not to touch the new bulb with your fingers as that will shorten it's lifespan. you may have to remove the battery if the burnt out bulb is on that side.
Robert
Please take a moment to rate this solution... thanks
SOURCE: 2004 Prius driver side rear taillight works intermittently
replace the bulb, you can access the bulb when you open the hatch. there is a cover at the back of the tail lights. or go to your local autozone or pepboys. they will replace it for you with no extra charge
Testimonial: "A friend showed me how easy it was to access the bulb by twisting the holder and then removing bulb. YOur response was excellent as well. Thanks! "
SOURCE: how do I replace the vanity mirror light on my buick century 2001
Usually the lense pops off and the bulb comes out.
It should be described in your owners manual.
