Question about Quickutz rev 0313-d Revolution Die "bird Cages"
Why does handle turn and nothing happens? - Quickutz rev 0313-d Revolution Die "bird Cages"
Posted by Diane Whitacre on
  • DaveMc3
    DaveMc3 Dec 05, 2017
    Hi Diane Whitacre, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
Hope scooter will start but when I give it gas nothing happens
Trace the throttle cable from the handle to the(carb or throttle body).Either the cable is broken,it has come off at one end,or the throttle handle or a piece of linkage is broken or loose.(this is a pretty basic problem-you can do it!)
Oct 26, 2012 | Office Equipment & Supplies
I plug my vacuum in and turn it on and nothing happens. checked different outlets and still the same problem.
Check the following:
- The handle may not be installed properly, causing a loss in the power connection. Remove the handle completely. Slide the handle back into place on the lower section of handle and tighten the screw.
Jun 15, 2010 | Bissell Healthy Home HEPA Bagless Upright...
I just bought a bissell power roller prodry cleaner and turned it on and nothing happens. Is there another button I am not turning on to get it to work?
The power switch is on the back of the handle. If that dosen't turn the unit on take the handle off and put it back on make sure its tight. If still nothing then its defective. Bissell says not to return it to the store contact a service center. If you have never used it return it.
Dec 16, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Engine Scooter, throttle does not work
trace the cable to the connection on the motor.check that throttle lever is connected to cable,and lever moves when throttle is turned.cable may have broken.
Oct 06, 2009 | 2008 Yamaha Yamaha G5
90 525i bmw key will n ot lock/unlock door and door will not clos
I would check the door lock actuator and the actual linkage. you need to remove the outside handle assembly for full inspection. on your model year car the linkages sometime wear out at a camon the handle that rotates the linkage. sounds really like you have worn linkage/handle.
Apr 06, 2009 | 1990 BMW 5 Series
Mtdb 115 lawn tractor will not start
Make sure the handle that lowers the blades is pulled right up into the last slot,and it is in neutral.
Trev.
Apr 01, 2009 | Garden
Quickutz rev 0313-d Revolution Die "bird Cages" Logo
1,044 people viewed this question
Top Quickutz Birds Experts
Kardoc
Tom Chichester
NOEL
NOEL
Are you a Quickutz Bird Expert? Answer questions, earn points and help others
