SOURCE: Unlock LG home theatre model LH-SW5100
at "no disc", press "pause" and enter "314159". when it shows CODE__, enter "0" for all code, press "pause" and the power button.
SOURCE: Protect error
This is a failure of the power supply or the amp. In either case, this unit is one that the boards are available and should be replaced. The first thing you must determain is which board is bad.
I have been repairing these since they started making them, and can tell you that it is not an easy task to figure out which board is bad. You will need a multimeter, and then know how to use it very well.
Sometimes you can get pointed in the right direction just by knowing what was happening when it went bad.
If the unit was working and you turned it off, then the next time you went to turn it on you started getting the "protect" message in the display, you most likely have a bad power supply board.
If you were listening to the system and it just shut off on you and then when you turned it back on you got the "protect" message, then it is most likely the amplifier board.
There is one more thing to check before you ever buy a board for this unit. If the fan in the back is not turning when you turn the unit on, it may only need a new fan. Lets hope that this is your problem, it is cheap and easy to fix. The other options may be better for you to take it to a service center to properly troubleshoot The boards are a little expensive, but that is what Samsung does with these units, they replace the boards. Most all other audio equipment from all other brands do not even make the boards available.
Check the fan first, if you need the part number let me know, I think I may have a manual to look it up for you. If you want to try and check the boards, I may be able to help a little more, but this is a very difficult thing to do over the internet.
I would appreciate it if you would wait until we are finsihed communicating on this problem before you rate it.
Thanks,
Dave
SOURCE: rear check message on HT-TXQ120 samsung home theatre
Looks like it is to do with the rear wireless speaker. Now, my problem is over. Its gone. I first turned the reciever on and then turned on the rear speaker wirel less on. No rear chk in problem now. Hope this helps. R.
SOURCE: Hello I have a Samsung HT-HTX22 home cinema.
ik heb een vestel tv ,en krijg geen geluid via mn 5.1 ht-thx22 speakers omdat hy niet voorkomt op de lijst van het manual dus mijn vraag is ondersteunt hij ook vestel tv ,s of moet ik een samsung tv kopen m.v.g. D.Suverein
SOURCE: RCA RTD206 HOME THEATRE
I have the RCA RTD206 Home System. As of 12 hours ago, teh system was working perfectly, at this time the system's disk tray is stuck on tray 3 even though it is changing all 5 disk trays. When it gets tray 5, it stops there and says on the system's screen, "No Disk". Is there anything that I can do to resolve this problem?
