Question about Sharp EL-1197PIII Calculator
Why does E appears on display?
When try to use the print option. My "feed" button is not working also. It seems to work on and off but more off though.
Posted by S Tisell on
1 Related Answer
Anonymous
  • 32 Answers
SOURCE: how do you fix -E appears when printing option is used?
You may have a defective printer. It has be overhauled, clean and re-timing on the gears
Posted on Sep 17, 2009
Printer will not advance to tear after print
I can't give the exact solution for this printer, however, I use the Epson POS thermal printer and here was our solution. In Windows 7 go to Devices and Printers. Click on Printer Properties. Then see if you see a tab that says Document Settings. Under that setting click on Paper Source. You should now see several options; I have mine set on Document(Feed, No Cut). There are other options but we prefer to tear ours off. You can chose Document(Feed, Cut) and it should advance then cut the paper for you.
Jul 10, 2014 | Datamax E-Class E-4205A Direct Thermal...
Zebra LP 2844 doesn't feed label all the way out for tearing off. When I print a label everything prints fine, however the last 1/4" or so is still left in the printer. Technically, it's like the printer...
Hi Brian,
When the last label printed is still under the printhead, that means the printer is in "rewind mode". There should be an option for "tear off" mode in the printer driver. This is the mode that pushes the last label printed out to the tear bar. The printer will then "backfeed" when printing the next label. Peel off mode is used if you want to print a label and have it "peeled" off the liner so that you can just pick up the label off the liner and apply it. That takes the rewind option to be installed.
Watch out though, if you are using a label software package, there might be a setting in the label format setup for "tear off" which usually overrides the settings in the printer.
Hope that helps !
May 06, 2010 | Zebra LP 2844 Thermal Printer
Deskjet 932C. Won't feed paper.
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
Sep 24, 2009 | HP DeskJet 932c InkJet Printer
Zebra Printer LP 2844 not feeding
Thanks for the response. It turned out to be a faulty power supply which did not send enough power to turn the printer. now it works like a champ
Apr 06, 2009 | Zebra LP 2844 Thermal Printer
I just installed a Lexmark 2500. It came with an ink cartridge (color) I purchased a black cartridge and installed it but it does not seem to be working. How do you darken the ink on this printer. It seems...
start
control panel
printer and fax
right click your printer, choose properties
go tab by tab and look for print quality and then try
something like this
choose econo mode, or ink saving mode to start.
try to print in grayscale mode and use only the black ink cartridge.
that should be your new default, and you don~t have to change it from winthin other programs
Mar 30, 2009 | Lexmark X2580 Wireless All-in-One InkJet...
5300 won't load 8 1/2x 11 photo-weight paper.
''grabber'' roller out of work sometimes, you may try
1) there is a input paper sensor around roller, the roller out of runing if the sensor is not senitive enough or sensor switch dirty,
clean the sensor as you can find it,
2) Lighter-weight paper feeds and prints fine, which means this paper input sensor works ok, but you need to make sure they are same paper input sensor,.
3) the paper surface bright and the roller worn could be cause paper feed fail, you need clean the roller anyway. still not fixed, you need to adjust the roller pressure by increase the spring force.`
Feb 07, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Firmware corrupted? Only prints some random computer text
The printer is in line mode. Do the following to take it out of line mode:
Turn printer power off.
Hold the feed button while turning printer power on.
When the light starts flashing, release the feed button.
When the light starts flashing again, press and hold the feed button.
When the light turns steady amber, release the feed button.
When the light turns steady green, the mode is changed.
Verify the mode by printing and inspecting a status report.
This requires good timing and may take several tries. You'll know it worked if no labels are reeled out after you're done.
Apr 17, 2008 | Zebra LP 2844 Thermal Printer
Brother 2820 paper feeding problem
An easy fix would be to try to clean the paper feed rollers in the paper pick up area with a gentle cleaner like soap and water or simple green. Do not use alcohol as this will break down the rubber over time. If this doesn't work, you may have drive problem and will need to refer to a professional to resolve.
Mar 06, 2008 | Brother IntelliFax-2820 Laser Fax
Sharp EL-1197PIII Calculator Logo
501 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
