Cameras Logo
A
Anonymous Posted on Aug 31, 2015
The camera has a message that the Media Dial is in the wrong position and it will not do anything.
richie46
Level 3:
Top Expert:
  • Cameras Master 12,962 Answers
  • Posted on Aug 31, 2015
richie46
Cameras Master
Level 3:
Top Expert:
Answers
12962
Questions
Helped
2945973
Points
58151
Read the manual, locate the media dial and set it to the correct default position.
If camera refuses to operate, then there is something wrong with unit.
Message d erreur sur ma lumix gh4 mode dial is not in the proper position
I would reset the mode dial to the correct position.
Camera is mn35z. the message states mode dial indefinite and then shuts off.
It sounds like your camera, the Nikon Coolpix MN35Z, is experiencing an error with the mode dial. The "mode dial indefinite" error message indicates that the camera is unable to recognize the position of the mode dial. This can be caused by a variety of issues, such as a malfunctioning mode dial, a damaged mode dial, or a problem with the camera's internal components.
To troubleshoot this issue, you can try the following steps:
  1. Make sure the mode dial is not damaged or stuck. If the mode dial is stuck or damaged, it may not be able to move freely, causing the error message to appear.
  2. Check the camera's battery and memory card. If the battery is low or the memory card is full or damaged, the camera may not be able to operate properly.
  3. Try resetting the camera. To do this, remove the battery and memory card, wait a few minutes, and then reinsert the battery and memory card.
  4. If the problem persists, the camera may need to be repaired by a professional. It is recommended to contact the manufacturer or an authorized service center for further assistance.
Jan 06, 2023 • Cameras
My camera when it turns on says ' Mode Dial Is not in the proper posistion ' I haven't dropped or anything! Will my warrinty cover it!?
Hi jayderehbein,
Make sure that the dial for selecting either video capture or image capture is not stuck somewhere in the middle , therefore a good idea would be try moving it to different positions and then back to the usual image mode and this message would go away ...
Hope this helps ..:) Your feed back would be appreciated.
2helpful
I have a Lumix DMC-LC50 When I turn it on it says: Mode dial is not in the proper position I tried everything
The mode dial is the knurled knob on the top of the camera - if you didn't already know. This same error message displayed when the knob is between selection. If you have moved the know to a valid position - where it stops in a detent, the message should clear from the display and be able to take pictures.
If moving the mode dial so that it rests in a detent and the message is still displayed, it indicates a problem with the switch inside the camera (that is operated when the mode dial is rotated). This is not a user serviceable part, and should be professionally repaired. I found United Camera to list a Mode Dial repair to be $42. there are plenty of others that can make this repair for you, too - this was simply the first I saw that had a price (I have never done business with nor am I affiliated with United Camera in any way).
I hope this is a good starting point for you & good luck. Please rate my reply - thanks.
1helpful
4answers
Lumix camera says mode dial is not in proper position
Hi and welcome to FixYa!
Please try to remove the battery and let it sit for atleast 5mins. then reconnect it again. This should reset the system and can resolve the problem.
Hope this helps and thank you for using FixYa! Have a good one!
1helpful
Warnin! Mode dial is not in the proper position
I used to have the same problem. Make sure the picture of the setting you are using on the turn dial is lined up with the beige pointer on the top of the camera. When you turn the dial, you can feel it lock into position. It could be that the dial hasn't quite clicked into the right position and just needs adjusting.
Problem with my camera
Sounds as though the mode dial is "freewheeling", i.e. it is turning...but is not revolving the wiper/selector below. Workshop job.
Top Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Camera Expert? Answer questions, earn points and help others
