Question about Canon Office Equipment & Supplies
HOW TO FIX ERROR - E5 ON CANON PIXMA MP258
HOW can I fix ERROR 05 - E5 ON CANON PIXMA MP258
pi-inthesky
    Sergeant:
  • 318 Answers
Google canon web page for full list of error codes and fixes
Posted on Sep 02, 2015
5 Related Answers
Anonymous
SOURCE: Canon PIXMA MP140 error code E 2
error E 2 => The machine is out of paper. / Paper does not feed.
Reload paper in the Auto Sheet Feeder and press the Black or Color button.
Posted on Mar 02, 2008
Anonymous
  • 377 Answers
SOURCE: canon mp150 pixma printer error e5
dear warenout
try this methode
Methode 1
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting formenu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
that's all
maybe it can fix your problem
thanks
cropp
Posted on Mar 15, 2008
ginko
Ginko
  • 19396 Answers
SOURCE: Canon PIXMA MP160 E5 error.
The unplugging procedure is called hard reset, and is useful only when there is no real problem on the printer.
Error E5 means a problem with cartridge chipset, here follows reset procedure, it does not always work:
Error E5 is a problem with cartridge ink counter. This happens when you use refilled or not original crtridges.
Try removing cartridges and putting them back in place.
Here is the whole service procedure for Pixma, you must use this to reset the ink counter:
service mode. (Waiting for menu selection)
button pressing
procedures below.
procedures below.
If it does not work you will need to buy a new set of cartridges, possibly original ones. If you just bought cartridges tell the seller they are faulty and ask an original set of cartridges as replacement.
Posted on Aug 15, 2008
Anonymous
SOURCE: e5 erron on canon pixma mp160
E5 is your problem,i also encountered that problem w/ my pixma mp 160,all you have to do change your cartridge w/ a new one,thats all...in case E5 does'nt resolve contact this no. 374-7103 to 04,coz they were the one who fix my pixma...thanx -----pilippines,antipolo city--------
Posted on Oct 11, 2008
pineworks
Clive
  • 4345 Answers
SOURCE: My Canon PIXMA mp240 is displaying E5 error. I
Hi there
Yes all inks must be in or you will get a error.
A) E5, E6 or E4 - it is cartridges error - to fix press the "stop\reset" button for 5-7 sec. and then release
it.
B) E27 - it is code for reset absorber (EEPROM reset or Waste
ink counter reset) and follow the described below
procedure:
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
button pressing
5) Turn off the printer.( it must be turn off)
then turn it on again.
Only in B) case you can enter into "service mode", in A) case or if have e.g. paper jam, or another error you CAN'T enter
the "service mode"
Try it
Anonymous see A) case: E5, E6 or E4 - it is cartridges error - to fix press the "stop\reset" button for 5-7 sec. and then release
it.
All the bst Pineworks
Posted on Apr 28, 2010
E5 error
The error code E5 shows that your colour cartridge is finished and the printer is telling
Read more: How to clear error code e5 - What does it mean when my mp210 canon printer has the alarm on :: Extreme Cow Answers at http://www.extremecow.com/How_to_clear_error_code_e5-qna9448.html
Hope it helps
--N
Apr 02, 2014 | Canon PIXMA MP210 Photo All-In-One Printer
What is error e5 in mp 198 printer
E5 - The ink cartridges are not installed or a non-supported ink cartridge is installed , or the ink cartridges are not installed properly..
  • In certain models of Canon Pixma printers such as the Canon MP160 and Canon MP150, you may receive an E5 error when trying to print. In this state, you will not be able to use any of the functions of your printer. The error itself is an ink cartridge error. It may be that you are using generic or off-brand ink cartridges in your Canon Pixma printer. Canon Pixma printers do not work with other brands of print cartridges; invest in Canon brand ink cartridges and this should take care of your problem.
  • Nov 18, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
    HOW TO REMOVE E5 EARROR
    make sure you removed the orange tape from the cartridge.
    usualy E5 is when the color cartridge is faulty but if the orange tape is on the cartridge it will show E5.
    if you removed the orange tape an it still shows E5 go with the cartridge to the store where you purcess it for excange.
    Nov 18, 2010 | Canon PIXMA MP150 All-In-One InkJet...
    E5 flashing - do not want to use colour ink
    use any color cartridge that is no sort & see canon error e5 solution
    Jul 21, 2010 | Canon MP140 PHOTO AIO All-In-One InkJet...
    What is e5 error
    E5 error code occurs in certain models of Canon Pixma printers such as the Canon MP160 and Canon MP150, you may receive an E5 error when trying to print. In this state, you will not be able to use any of the functions of your printer. The error itself is an ink cartridge error. It may be that you are using generic or off-brand ink cartridges in your Canon Pixma printer. Canon Pixma printers do not work with other brands of print cartridges; invest in Canon brand ink cartridges and this should take care of your problem.
    Feb 25, 2010 | Canon PIXMA MP160 All-In-One InkJet...
    Canon pixma error code
    TOLONG DONG CARA RESET CANON mp145 ERROR CODE E5
    Aug 25, 2008 | Canon PIXMA MP160 All-In-One InkJet...
    Ink Cartridge Refill Error E5
    First take a smooth cloth or cotton
    take a cleaning liquid like spirit, thinner etc., (note - not cleaners)
    clean the golden chip with out giving much presser
    in the same way clean the other side of the printer also
    now test it
    90% Problem will solve
    Thanku
    Take care
    Bye
    Apr 04, 2008 | Canon PIXMA MP150 All-In-One InkJet...
    old marine
    old marine
    efs_perpends
    efs_perpends
