Question about Conair Lands Phones
Where can I find manual for conair sound therapy machine SU5
Where can I get manual for Conair sound therapy machine SU5?
Posted by Carole Waddell on
5 Related Answers
Anonymous
SOURCE: Conair Call Keeper TAD920
How do you work the remote answering from a different location...
Posted on Jan 27, 2008
Anonymous
SOURCE: conair digital answering system
TAD2012 Quick Reference Guide
To Install
1. Open the battery door with a ballpoint pen. Install one 9-volt alkaline battery (not included)
and replace cover.
2. Plug the telephone line cord (connected to the back of the TAD2012) into the modular wall
jack.
3. Plug AC adapter into standard 120-volt outlet. Plug your phone directly into an outlet, not into
an extension cord.
Answering System Operation
Recording Your Personal Greeting
1. Press and hold down the GREETING control.
2. After the beep, speak towards the front of the base; you have 30 seconds.
3. When finished, release button. Your unit will play back your greeting and
reset to answer incoming calls.
4. Adjust volume control on the side of the unit to set the speaker to the desired level.
Select the Number of Rings
Choose 2,4 or TS (Toll Saver), which programs the number of rings that you want before your unit answers.
To Play Back Your Messages
1. When the message indicator flashes, you have received messages.
2. To hear your messages, press and release the PLAY control. Your unit will automatically
reset after messages are played.
To Save Your Messages
After the last message and 2 beep tones, press the STOP/SAVE control.
IN CASE OF POWER FAILURE OR IF ANSWERING SYSTEM IS NOT OPERATING PROPERLY
If a power failure occurs or the plug comes out of the wall, your unit will shut down until the power is restored. One 9-volt battery must be installed to retain your personal greeting message and incoming messages during the power failure. Occasionally outside factors, such as power surges, may adversely affect the unit. If the unit is not operating properly or if the light continues to flash once power is restored, try these steps:
1. Unplug the AC adapter from the power outlet.
2. Remove the 9-volt battery. Replace with a fresh 9-volt battery.
3. Plug AC adapter back into power outlet.
4. When your unit is initially plugged in, it will check its memory for approximately 3 seconds.
Three deep tones will be heard if you attempt to record a greeting message before this
period.
5. Record a new greeting message.
Indicator Status: Message indicator is consistently flashing slowly.
Reason: No greeting message has been recorded.
Action: Record your greeting.
Indicator Status: Message indicator flashes rapidly.
Reason: A 9-volt alkaline battery (not included) has not been installed or needs to be replaced.
Action: Install a fresh 9-volt alkaline battery. (Battery provides power failure backup. Unit is functional without it).
Indicator Status: Message indicator flashes to indicate number of messages received,
and then repeats.
Reason: Messages have been received.
Action: Press PLAY control to hear your messages.
Indicator Status: Message indicator is lit solid.
Reason: System is in Answer Mode.
Action: No action required. Unit is ready to receive calls.
Conairphone™ Consumer Hotline
Questions? Call the Conairphone™ Consumer Hotline, toll-free, 1-800-366-0937.
Hotline Hours: Monday-Friday 8:30 a.m. - 9:00 p.m. (EST)
Saturday 8:30 a.m. - 12:30 p.m. (EST)
7475 North Glen Harbor Blvd.
Glendale, AZ 85307
Posted on Jan 29, 2008
Anonymous
SOURCE: conair scale ww36gd err reading
I have a WW36DG digital scale and most of the instructions are the same, so far as I can see. When you tap on the scale, 888.888 appears. It is just seting itself. If you step on the scale before it reads 00.0 it wil give you a Err signal. If you stepped on the scale after it read 00.0, and an Err signal appears, either your battery is very low or it is malfunctioning. it does have a 10 year warranty on it. For the person wanting to set the scale, here are the directions. Good luck.
Customizing Your
Weight Watchers® Body Fat Monitor
1. Tap center of scale platform with foot to activate digital display (display will
flash).
2. Wait for "0.0" to appear in display window.
3. You are now ready to input your personal data. Firmly press the SET button
located below the display.
Enter User Number
• P-01 will flash in display window
• Press UP or DOWN arrows to select your individual user
number (Ten user numbers available: P-01 through P-10)
• When selected user number appears in display, press SET
button to save user number
• The scale is now ready for you to enter your height
Set Height
• "Ht" (height) will flash in display window
• Press UP or DOWN arrows to scroll to your height measurement
• Press SET button to save height
• The scale is now ready for you to enter your age
Set Age
• "Age" will flash in display window
• Press UP or DOWN arrows to scroll to your age
• Press SET button to save age
• The scale is now ready for you to enter your gender
Set Gender
• The gender icons will flash in display window
• Press UP or DOWN arrows to select male or female icon
• Press SET button to save gender
• The scale is now ready for you to weigh yourself and to
determine percentage of body fat
Posted on Jun 26, 2008
Anonymous
  • 16 Answers
SOURCE: Conair TAD-1220 Digital answering machine
Background: The TAD1220 does not have a way to manually delete messages. It more or less has a FIFO(FIRST IN-FIRST OUT) method of retaining messages. It will save up to 14 minutes of messages and then they are deleted automatically after you play them back and receive another incoming call.
This is important:
It will only erase the messages AFTER you have listened to them *AND* received another message.
Exception: If you happen to press the STOP/SAVE button, then all of the messages will be RE-SAVED until the memory limit has been reached.
Extreme Solution:
The only manual way is to remove the battery, disconnect the power cord and erase everything. You will then need to reprogram your greeting.
Posted on May 21, 2009
k24674
  • 8092 Answers
SOURCE: Remote Access Is Not Working.
Read the following
To erase messages
Posted on Sep 16, 2009
I can't find how to change the time for the alarm system for a Alphaline 150i digital radio alarm clock
PDF]Instruction Booklet - Sound Therapy and Relaxation Clock ...
www.conair.com/instruction.../07ps111_su7_ib.pdf
Conair CorporationThe LCD display will show the current time of ALARM 1, reset time. ... The Conair Sound Therapy & Relaxation Clock Radio System can be used with a cord ... 1) 10 high quality digital recordings .... 150 Milford Road, East Windsor, NJ 08520.
Muse - Alarm clock radio
www.muse-europe.com/en/products/alarm-clock-radio
Catalogue Products, Cat?gorie Alarm clock radio. ... M-125 CRB. Clock radio CD player with MP3 ... M-150 CR. Clock radio ... Automatic time-set clock radio PLL ...
[PDF]FM/AM Clock Radio - Sony
Jan 10, 2016 • Watches
I was given a CONAIR model SU5T SOUND THERAPY TRAVEL SYSTEM, but without an operating manual. I am hearing impaired & can not find a travel alarm clock loud enough to wake me up. I wish to try this...
There are at least three different Sound Therapy systems and two of them have manuals available on-line:
SU1W:
http://www.conair.com/instruction_booklets/07PS078_su1w_IB.mech.pdf
SU7:
http://www.conair.com/instruction_booklets/07ps111_su7_ib.pdf
Aug 03, 2011 • Cameras
HOW TO SET THE CORRECT TIME OF DAY
Did you ever figure this out? I had one of these given to me, and it's driving me mad!
Flashing L on display conair TAD 1216PWT answering machine
i was wondering the same thing. i contacted conair, and although they no longer make these things, a very nice lady named maria was able to find an owners manual which she promptly sent me via email. the L means the 4 triple A batteries need to be replaced. hope this helps.
How do you turn the alarms off and on for the Conair model SU7?
Link to set up for SU7 alarm sound therapy clock: http://www.conair.com/instruction_booklets/07ps111_su7_ib.pdf
2helpful
I can't find my manual
After having looked around the conair website for a downloadable manuable i was unable to find one, however, i did find this, quote... "# Please email customer service dept for insturction manuals." So, please follow the link below then scroll down the page and click "Contact us by Email". Im quite sure the email is free but it might take a while for them to get back to you. good luck http://www.conair.com/customer-service-cn-18.html
Lands Phones Logo
Top Conair Lands Phones Experts
k24674
Oloyede Monsuru
Tom Chichester
Are you a Conair Lands Phone Expert? Answer questions, earn points and help others
