SOURCE: Electrical problem
Without a battery,None of the electrics will work unless the bike is running.Start the bike to test.
Please rate this fixya
SOURCE: No Horn
sounds like you have a dirty or missing ground connection or a fuse that's bad. the ground problem is usually best left to a technician (it can get pretty involved, but the fuse is a quick check and fix you can look at it and see if it is blown and get a new one at any auto parts store.
SOURCE: yamaha mto3 sitting for 3 monts outside, battery
try cleaning the carb completely off the bike, make sure you take the jets out and clean them well.
They are probably gummed up....gas does not last long after 30 days anymore before it begins to varnish and clog parts.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
SOURCE: 02 YMF660 Yamaha Raptor won't rev
dude i have a 02 rapter 660 the reverse light was on and it wasent reving i took the battery out and took the ecu out and i found some disconnected wires fixed them and every thing was fine. if you still have a probley with it check the ecu...
