Question about Acer Aspire 5100 Notebook
Windows will not boot
When starting the laptop acer 5100 it tyries to start and it shows the following
Bus 06, device 02 ,function 00
error
resource conflict pci in slot 03
bus 06 device 04 function 00
error
bus 06 device 04 function 01
error
bus 06 device 04 function 02
error
bus 06 device 04 function 03
can not get it boot in any of the safe modes or boot from disk
Posted by rebels1 on
  • 20 more comments
  • rebels1 Nov 16, 2007
    it is about ,a year old , nothing prior to error
    tried that will not boot from OS disk, where can I get a MB from . And how do I check for sure that it is the mother board
  • Anonymous Nov 23, 2007
    I have an Acer Aspire 5100, and I've started seeing the same error messages. I searched on google to see if I could find any discussion regarding "Resource Conflict - PCI Network Controller in Slot 02" and Acer 5100. That search led me to this web site.
    I believe that your diagnosis is correct. I am also seeing intermittent malfunctions with my internet connection. Also sometimes the machine simply locks up and I can't move the mouse cursor or type anything.
    My machine is less than one year old. I bought it in February 2007 and
    now these problems are happening in November 2007.
    One more description of my problem: The error message occurs as the machine is booting up. First there is a beep. Then the following message is printed on the screen:
    System Bios Version V2.70
    Bus: 06, Device: 01, Function: 00
    ERROR
    Bus: 06, Device: 02, Function: 00
    ERROR
    Resource Conflict - PCI in Slot 03
    Bus: 06, Device: 04, Function: 01
    ERROR
    Bus: 06, Device: 04, Function: 02
    ERROR
    Bus: 06, Device: 04, Function: 03
    Press to resume, to setup
    Sometimes when I press I'm lucky and the machine works,
    as well as the network. But sometimes, increasingly, the machine
    boots up but the network connection doesn't work.
    I will continue to search for the most inexpensive fix.
  • amatz Dec 28, 2007
    I'm having the identical problem but with a Sony Vaio. Diagnostics are useless as system will not boot at all. IIt is out of warranty...is it repairable? If so, how do I manage this repair so I don't get taken for a ride?
    -amatz
  • Azzer Jan 01, 2008
    I have the exact same problem with my Acer Aspire 5100. Sometimes it boots but it appears to be random. Also, the wireless network card will seemingly randomly disable it's self and will require a restart to fix it, leading to this error when booting up.
    I installed a different bios version and it fixed it for a while but it went back to it's usual ways. Haven't tried reformatting yet but I will in the near future.
    *hopes it's software problems*
  • Derrick Quashie Jan 03, 2008
    when starting the laptop acer 5100 it tyries to start and it shows the following
    error
    error
    error
    error
    after it displays this message it gives the options of press F1 to boot or F2 for setup and if i press F1, then it dislays the xp logo like it want to boot and sometimes too it does not display any error message at all
  • redjeepbabe Feb 11, 2008
    I am now experiencing the exact same error message on reboot. The problem is intermittent. I have already had Acer repair this laptop twice with them replacing the MB both times.
    I lose wireless network for no apparent reason. Reboot will sometimes bring it back, but lately I am getting the same resource error. I will need to contact Acer again I suppose. I'm thinking about demanding a new laptop.
  • Anonymous Apr 01, 2008
    Same problem as above. Bought laptop in Feb 07, so it's passed warranty. Not a software problem--physically moving the laptop causes freezing or the wireless to disconnect. Resource conflict errors sometimes prevent booting a dozen times in a row.
  • anywae Apr 24, 2008
    same as everything esle here that i read it started with intermitten wireless drops when sitting 6 feet from my router now wont boot i get
    resource conflict - pci in slot 3
    bus:06, device:02,function 00
    error
    resource conflict - pci in slot 03
    bus:06, device:04, function 00
    error
    bus:06 device 04 function 01
    02
    03
  • Barikay May 19, 2008
    I have the same problem. When I start my Acer 5100 laptop it gives the message System BIOS Version V2. 70 and a whole series of ERROR Resource Conflict PCI in slot 03, Bus:06 Device: 02, Function: 00 etc right through to Function 03. Then gives me the option F1 to resume, and F2 to Setup: Neither of the F keys resolves the problem. I am now nearing frustration. Dont know what next to do.
  • shiatsubag May 27, 2008
    same problem...as everyone else...ws intermittant for the last few days, now complete failure to boot....press f1 to continue, goes to startup repair or normal startup, then freezes during the vista startup process
  • bergil210 Jun 12, 2008
    same problem but i just put pressure on it to make it boot but now nothing works whyyyyyyyyyyyyyyyyyyyyyyyyyyyyyy!! sniff sniff sob sob.
    ive even went into the tool mode and none of them work its hopeless
  • aloktrpth Jun 21, 2008
    Exactly same problem
  • Anonymous Jun 23, 2008
  • Anonymous Dec 02, 2008
    same issue
    have
  • Anonymous Jan 01, 2009
    yes
  • youngmary50 Jan 09, 2009
    I have the same problem on my Acer Aspire: same error, same message, cannot get to Windows at all. The laptop is a little over a year old.
  • mareka704 Feb 11, 2009
    please send me any solutions
    [email protected]
    thanks
  • Anonymous Mar 12, 2009
    when starting the laptop acer 5100 it tyries to start and it shows the following Bus 06, device 02 ,function 00error resource conflict pci in slot 03bus 06 device 04 function 00errorresource conflict pci in slot 03 bus 06 device 04 function 01errorresource conflict pci in slot...
  • bebeto_70 Apr 24, 2009
  • rodney_brewe May 04, 2009
    i have exactly the same problem and i mean EXACT!!!!!!!!!
Anonymous
Just turn-off network boot in your bios
Posted on Oct 13, 2008
Anonymous
    New Friend:
Device 02 and 04 errors refer to the memory. Had the same problem with the 5100 series. I had a gig in both "A: and "B" modules (5300 DDR2 667). I removed the memory from slot "A" keeping slot "B" in and it rebooted after the first reboot. It boots up with no problems. The errors 02 and 04 are memory slot problems. Give it a try and see if it helps you.
Posted on Dec 16, 2009
Anonymous
    New Friend:
Try taking the battery out and turn it on with just the charger...
Posted on Dec 13, 2010
Anonymous
    Problem Solver:
  • 26 Answers
Hi Friends,
Acer Aspire 5100 PC Notebook main problem is Connection Problem, Software Problem etc.
For these problem you can visit a link by just Click Here .
For any other problem with this Notebook you can Click Here
s4de
Posted on Jul 20, 2010
Anonymous
Device manager - update the driver if your using ati radeon graphics
Posted on Sep 24, 2008
Anonymous
Have a sony vaio desktop with windows xp .problem it wont boot,it takes me to the boot screen press f2 to resume and when i do that it goes to main,bios exit menu and i try to save and exit.to restart it would go back to the same menu.it keeps asking for a insert boot media. i even tried putting my windows xp orginal disk and tried to repair the problem. but no help from that either.please help me
Posted on Oct 12, 2008
Anonymous
    New Friend:
This ia a overheating problrm. A chip in up- left side overheats and cause this problem. if you disasemble you laptop and blows that chip notice that the problem solves temporally. or disconect you laptop for a few minutes and it'll be boot normally and then the `laptop freeze. the chip is under a copper recover but it doesn't cool as it needs. I dont know how can i cool this part.
Posted on Jan 07, 2010
Thomas Christopher
    Genius:
  • 1,601 Answers
You have parts failing, namely the network controller.
How old is it?
Have you done anthing prior to the error?
Posted on Nov 16, 2007
Bus: 06, Device: 01, Function: 00 ERROR Resource Conflict - PCI Network Controller in Slot 02 Bus: 06, Device: 02, Function: 00 ERROR Resource Conflict - PCI in Slot 03 Bus: 06, Device: 04, Function:...
I would firstly reboot and if that doesn't clear the error run www.iobit.com asc.setup utility to remove crosslinked files and sort out a crosslinked registry. Failing that remove the driver from the Control Panel and let the OS set up a fresh driver. Make sure the driver is the correct one!
May 02, 2011 | Acer Aspire 5100 Notebook
When starting the laptop acer 5100 it tyries to start and it shows the following Bus 06, device 02 ,function 00 error resource conflict pci in slot 03 bus 06 device 04 function...
If it just started doing this all of a sudden, then it is a good bet that *********** board is fried. If you just installed some memory or a communications card or new drive, then take it out and see if it still does it. If not, check the installation instructions to make sure it was put in right.
Sep 08, 2010 | Acer Aspire 5100 Notebook
Al encender mi ACER Aspire 5100 suenan 2 pitidos y en la pantalla me pone: Sistem BIOS Version:V3.13 Bus:06, Device:01, Function:00 ERROR Resource Conflict - PCI in slot 03 Bus 06, Device:04, Function...
You have a n IRQ conflict meaning you have a device that is trying to use an IRQ slot that its not meant to talk on. From the looks of it you have been in the bios already so go back in and set it to factory default.
Aug 16, 2010 | Computers & Internet
I have an Acer Aspire 5100 with Vista Home Premium on it...when starting the laptop acer 5100 it tries to start beeps...and it shows the following page of errors Bus 06, device 02 ,function 00 error...
It might be possible some kinda a BIOS corruption. Let us try this first. ASA computer starts keep on tapping F2, it will enter the BIOS setup utility, then press F9 and then F10, save the seeting and restart the computer. It should resolve the issue. But if the issue still persists, then update the BIOS. Visit the webiste mentioned below:
http://support.acer.com/drivers_download.aspx
Select the model and update the BIOS.
May 07, 2010 | Acer Aspire 5100 Notebook
Acer 5102WLMi 4GB ram windows 7 Resource Conflict PCI in slot 03
I have the same fault in Exploration of the Toshiba laptop I thought that the problem in the BIOS I have to change the BIOS of the motherboard from another device is identical to him, but did not change the message. The device to restart the work or entering the BIOS. Does not enter the Hard disk or the CD-ROM or slots of the USPI. Found that the problem in the cache on the motherboard BIOS that is stored clothing and replied to her and when I unloaded as follows.
Remove the keyboard from the device you will be proud of card Remove the card below it you will notice two signs**88
When you close with some of these points and left it for 24 hours you run the laptop did not show the message again, but this may have eliminated the possibility of a password again from the BIOS as the storage room and place one empty one.
As for this model are points of discharge under the Ram, and marked with .. And be drawn into a small rectangle and the letter written by him j
Mar 06, 2010 | Acer Aspire 5100 Notebook
My laptop wil not boot. Not even in safemode . It has wndows xp that i had recently put on there.. its been doing this for a min but it would come on after a few tries.. This is exactly what happens when i...
Hello Karen
Try removing and resetting your memory modules.
Blow some air in the slots to remove any dirt trapped in there.
They are locate don the back of your laptop.
The instructions are in the manual under how to change or upgrade memory modules.
Please don;t forget to rate this answer if it helps
Jul 22, 2009 | Acer Aspire 5100 Notebook
Aspire 5100 resource conflict - pci slot 3
Yuor RAM memory conflicts with each other check RAM memory fix same frequency memory into laptop.
Thanks for using fixya.
Jul 20, 2009 | Acer Aspire 5100 Notebook
Acer Aspire 5100 Notebook Logo
8,388 people viewed this question
Ekse
Lee Hodgson
Lee Hodgson
Gustavo Ortiz
Gustavo Ortiz
