Question about LG 42LC2D 42 in. LCD HDTV
Tv standby light on but tv wont switch on screen lights up for second then back to standby.screen just went off suddenly last night no previous problems been perfect picture
When standby light is first switched on instead of steady blue light it flashes once
Posted by mr ken broadberry on
5 Related Answers
Anonymous
  • 92 Answers
SOURCE: 42 inch LG Plasma TV - Lost picture
sounds like it may be a software upgrade
Posted on Oct 31, 2007
Anonymous
  • 15 Answers
ysus pcb that supplies voltage to the panel is faulty
Posted on Dec 15, 2007
Anonymous
  • 3 Answers
Our LG 50" plasma tv screen went black after a popping noise but still had sound, after great diliberations decided to take the back off and have a peek!
We unplugged the tv and tested the fuses (there were three we could see) one had blown, the one on the left as you look at the back of the tv it also has one above it. We wrote the code/seriel number down and took the fuse to the electrical wholesalers Maplin and bought a pack of 10 fuses for £1.29 replaced the fuse in the tv and everything now fine!!!!!!
Hope this might be of use to anyone whose lost the picture after a loud popping/snacking noise but still has sound.
Posted on Jan 17, 2008
budmrtn
Bud Martin
  • 11361 Answers
SOURCE: LG 26LG30 screen suddently went blank. Light flashing blue/red
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Posted on Nov 14, 2009
Anonymous
SOURCE: LG 19 LH 2000 no picture or sound
i have exactly the same problem and my tv is just 2 weeks old !!
any soloutions?
Posted on Jan 22, 2010
We bought this tv an Olevia 542- b11 Syntax brillian lcd hdtv, back in 2009 and have not had any issues with it other then every now and then the volume would go out. we would just have to turn the tv on...
It sounds like your main board has failed, given the issue with your sound and the LED light on the front panel. These are common signs of a failed main board.
May 12, 2017 | Olevia LT42HVi 42 in. LCD Television
Have an old sony HDTV proj tv, and the picture went out last night. I heard sort of a "pop" then no picture
Pop sound shows that some thing went wrong inside TV and most probably any part got busted.
Let me know model number of your Sony TV and does its standby red light blinking? if yes, how many times it blinks between 3 seconds interval.
Nov 30, 2009 | Televison & Video
TV wont turn on. Standby light blinking 7 times in sequence.
It will most likely need the power on switch replaced its very common
Jun 21, 2009 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Wont come on
Instead of just unplugging the TV, perform a power drain:
1. Unplug the product's power cable so the device is not grounded to the house. 2. Press and HOLD the product's own power button for 1 minute to drain the capacitors. 3. Plug the product back into a wall outlet and try to turn it on.
Note: This procedure works with battery operated devices as well so remove the batteries and hold down it's power button.  Electricity can remain in capacitors and on circuit boards enough to prevent normal functionality. By clearing the residue electricity, your product will have a fresh start and many times this will resolve a buggy or non-responsive device that appears to be dead.
If the TV still won't turn on, then it appears something is wrong with it's mainboard since the TV is still receiving power because the standby light is still coming on.  The cost of fixing an older TV's mainboard could be costly or impossible if the part is discontinued.
Mar 25, 2009 | Beko 324250WN 28" TV
Loewe Vitros 6370- won't turn on!
its a power supply problem.
Jan 13, 2009 | Televison & Video
I was watching tv last night when all of a sudden the screen started going fuzzy then it just switched off and now it wont switch back on and the red light just flashes is there anything i can do?
30 YR SEVICE3 TECH
TRY UNPLUGING SET FROM THE WALL FOR ABOUT 2 MINUTES PLUG BACK IN AND TRY THE SET. IF SET DOES NOT COME ON TAKE IT TO A QUALFIED SERVICER.
APGONZO
Jan 12, 2009 | Bush 5693D 24" TV
No picture and no sound
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Mar 11, 2017 | Samsung Televison & Video
Sony FD Trinitron Wega model KV-34BR800
Sony Wega Triniton KV-32FS100 TV
For the last week my TV has been going to a black screen for 10 seconds or so then the picture returns. It has been continual. Last night it stopped going to black screen, but now the standby light flashes 5 consecutive times and the color went haywire. A lot of red and everything that is suppose to be black is green.
I did a soft and hard reset with no success. What's wrong and is it worth fixing? Bought new in November 2002.
Aug 01, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
LG 42LC2D 42 in. LCD HDTV Logo
263 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
